"nemesis" <nam### [at] gmail com> wrote:
> hi, guys. I hope to contribute a bit more to the discussion of getting good
> glossy reflective metal textures in povray.
Marvellous work! Thank you very much for sharing.
jute
thanks! It was just a quick hack around Warp and Jaime methods. Using the
wood pattern surprised me so much that i had to share... probably, patterns
like marble or gradient and a bit of turbulence may produce similar
results...
Nice work, nemesis! Very useful.
I think previously i did not do Warp's method justice: it does produce nice
blurred reflections without the graininess that accompanies micronormals.
So here's a better render of it with the given supersampling setting and
doubling BlurSamples and lowering BlurAmount to .04
in the end, i guess it depends on the type of reflective metal you're trying
to achieve...
Download 'glossy_warp_better.jpg' (37 KB)
Preview of image 'glossy_warp_better.jpg'
"Smws" <smw### [at] pobox com> wrote:
> I have the most trouble when the blurred surface is concave (as
> on my spoon) and it reflects itself... or I think that's slowing it down.
Making two copies of your object one with the blurred reflection texture and
additional no_reflection attribute and the other with a less complicated
version of the texture (e.g. just plain reflective or at least less
samples) with no_image and no_shadow usually solves that problem without a
big loss in picture quality (if any).
Hope that helps!
Regards Roman
> Hope that helps!
> Regards Roman
wow! Now THAT is a nice tip! :)
Cheers! :)
Very impressive results, your method really looks realistic. I'm gonna have
to have a play with that myself!
Your random rotation might give an even better result if you use rotate
<pow(rand(S),2)*90,rand(S)*360,0> to more evenly spread the randomly rotated
wood patterns, though this is purely academic since I can't see any flaws in
your pattern!
But I have one important question: *why* does the wood pattern look good?
Tek
http://evilsuperbrain.com
"nemesis" <nam### [at] gmail com> wrote in message
news:web.454f674dce679533976a8750@news.povray.org...
> good
> I've made several tests, starting from a basic shiny metal texture and
> also
> using Warp's FAQ method and Jaime Vives Piqueres' micronormals and finally
> a little discovery i made by simply changing the used normal pattern:
> wood
> rather than the usual bumps, crackle, facets or granite one would usually
> think about. This came from the observation that "brushed" metal bears
> several scratches throughout its surface. I tried to emulate that with a
> My solution is slightly faster than Jaime's because of less normal_map
> entries, i guess.
> Here are the textures, from fastest to slowest to render:
> #declare f_reflective_metal = finish {
> ambient .2 diffuse .2
> specular 1.5 roughness .02 brilliance 2
> reflection { .6 metallic 1 } metallic
> #declare f_metal_shiny = f_reflective_metal
> // basic shiny metal
> #declare t_shiny_metal =
> texture {
> pigment { rgb .8 }
> finish { f_metal_shiny }
> /* straight from warp's method from the povray FAQ */
> #local BlurAmount = .2; // Amount of blurring
> #local BlurSamples = 10*4; // How many rays to shoot
> #declare t_metal_glossy_warp =
> texture
> { average texture_map
> { #local Ind = 0;
> #local S = seed(0);
> #while(Ind < BlurSamples)
> [1 // The pigment of the object:
> pigment { rgb .7 }
> // The surface finish:
> // This is the actual trick:
> normal
> { bumps BlurAmount
> translate <rand(S),rand(S),rand(S)>*10 //200
> scale 1000
> #declare Ind = Ind+1;
> #end
> #declare t_metal_glossy_warp_lesser =
> texture
> { #local Ind = 0;
> #local S = seed(0);
> pigment { rgb .7 }
> normal
> { bumps BlurAmount
> translate <rand(S),rand(S),rand(S)>*10/200
> scale 1000
> #end
> // *** Jaime Vives Piqueres' micronormals ***
> // + microsurface normal
> #local p_jvp_micro2=
> pigment{
> crackle turbulence 1
> color_map{
> [0.00 rgb .7]
> [0.01 rgb .7]
> [0.02 rgb 1]
> [1.00 rgb 1]
> scale 5
> #local p_jvp_micro1=
> pigment{
> cells
> turbulence .5
> color_map{
> [0.0 rgb .9]
> [1.0 rgb 1]
> scale .01
> // + average all the normals
> #local p_jvp_brushed_new=
> pigment{
> average turbulence 0
> pigment_map{
> [0.0 p_jvp_micro1]
> [0.1 p_jvp_micro1 rotate 45*x]
> [0.2 p_jvp_micro1 rotate -45*x]
> [0.3 p_jvp_micro2]
> [0.4 p_jvp_micro1 rotate 45*y]
> [0.5 p_jvp_micro1 rotate -45*y]
> [0.6 p_jvp_micro1 rotate 90*z]
> [0.7 p_jvp_micro2 rotate 45]
> [0.8 p_jvp_micro1 rotate 45*z]
> [0.9 p_jvp_micro1 rotate 90*y]
> [1.0 p_jvp_micro1 rotate -45*z]
> scale .1
> #declare n_jvp_micronormals = normal { pigment_pattern{p_jvp_brushed_new}
> .4
> #declare t_jvp_micronormal_glossy_metal = texture {
> pigment { rgb .7 }
> normal { n_jvp_micronormals scale .5 }
> finish { f_reflective_metal }
> #declare t_metal_glossy_jvp = t_jvp_micronormal_glossy_metal
> * a mix of warp's method and Jaime Vives Piqueres micronormals.
> * But with a completely unrelated and surprising pattern...
> #macro m_metal_glossy( BlurAmount, BlurSamples )
> texture { average
> texture_map {
> #local Ind = 0;
> #local S = seed(0);
> pigment { rgb .78 }
> normal { wood ramp_wave
> rotate rand(S)*30 turbulence .6
> bump_size -BlurAmount
> translate <rand(S),rand(S),rand(S)>*.02
> scale .002
> //scale 1000
> #end
> #end
> #declare t_glossy_brushed_metal = m_metal_glossy( .2, 1*4 )
> #declare t_metal_brushed_glossy = t_glossy_brushed_metal
> #declare t_metal_glossy = t_glossy_brushed_metal
> #declare t_metal_glossy_weak = m_metal_glossy( .1, 1*4 )
> // test scene
> camera { location -5*z look_at y+2*x rotate <20,0,0> angle 40 }
> light_source { 4-8*z 1.3 }
> light_source { 4-6*x 1.3 }
> plane { y, 0 pigment { checker rgb 1 rgb 0 } finish { ambient .3 diffuse
> .4
> sphere { y-7*z, 1 rotate -y*40
> pigment { rgb y }
> finish { ambient 0 diffuse .6 phong .7 brilliance .5 }
> #local n0 = normal { facets coords .04 bump_size .9 turbulence .0 scale
> 9*(z+x) scale .04 }
> box { -.5,.5 rotate y*20 translate .5*y+1.3*x scale 2 rotate -y*20
> //texture { t_shiny_metal }
> //texture { t_metal_glossy_warp }
> //texture { t_metal_glossy_warp_lesser }
> //texture { t_metal_glossy }
> texture { t_metal_glossy_weak }
> //texture { t_metal_glossy_jvp scale .04 }
> Shown are the test scenes renders. Getting as reference the basic shiny
> metal with no distortions, it can be seen that Warp's method (using huge
> normals) distorts too much the reflected environment. I made a few
> changes
> to values in order to prevent too much of it. OTOH, Warp's method is the
> fastest and the only one that looks ok without antialiasing. Jaime's in
> particular, seem to need quite a lot. I suggest +AM2 +A0.08 +J1.0 on the
> command-line. Mine and Jaime's get this.
> Jaime's seem to need yet more AA or a smaller scale, i don't know... his
> reference picture looks a lot better:
> http://www.ignorancia.org/uploads/experiments/micronormals/micro.jpg
> Although not seen here, spherical surfaces get somewhat weird at the
> equatorial area near the borders of the shape with Warp's or Jaime's, but
> do just fine with the wood pattern.
> wood patterns,
yeah, i just added some random thoughtless rotation, didn't even play with
it. I'll try that some time from now.
beats me! As i said, i just wanted to create lines in the surface,
emulating scratches from brushed metal. That's all. I first tried
gradient, but as a normal, gradient sucks. Then i hit wood and it looked
good. :)
In the meantime, here's a clearer version, by using +A0.0 and
m_metal_glossy( .04, 1*3 )
Download 'glossy_mine_polished.jpg' (37 KB)
Preview of image 'glossy_mine_polished.jpg'
> Hope that helps!
> Regards Roman
Yes! Helps very much, I will be trying this. You can see the image in
question on p.b.i now, thanks for giving me this idea. Of course it seems
obvious once you point it out...
-Stefan
