POV-Ray : Newsgroups : povray.binaries.images : indoor lighting (radiosity) Server Time
18 Feb 2025 17:10:47 EST (-0500)
  indoor lighting (radiosity) (Message 1 to 10 of 16)
Subject: indoor lighting (radiosity)
Date: 24 Oct 2006 12:05:00
Message: <web.453e38ad89ca60aad8ef73430@news.povray.org>
Hello,
I'm new to this newsgroup. I'm very interested in learning indoor lighting
and rendering using lights and radiosity. I have been working with POV for
a long, but I can't render images with impressive lighting like these:
http://www.pacificommultimedia.com/architecture.html
http://www.artvps.com/gallery/1/architecture.htm
At the moment, the best image I rendered is this. I think that it is not
very bad, but seems a little dark. If the brightness parameter is
incremented then the image is burn.
Suggestions are well received.
Thanks,
jsr.
Download 'indoor lighting.jpg' (350 KB)
Preview of image 'indoor lighting.jpg'
Subject: Re: indoor lighting (radiosity)
Date: 24 Oct 2006 12:34:57
Message: <453e40b1$1@news.povray.org>
"JSR" <jsr### [at] gmailcom> wrote in message
news:web.453e38ad89ca60aad8ef73430@news.povray.org...
> Hello,
> Thanks,
> jsr.
 the amount of light coming in looks like a slightly overcast day outside.
are the lights just rgb <1, 1, 1>?
Date: 24 Oct 2006 12:55:49
Message: <453e4595$1@news.povray.org>
"Ross" <rli### [at] speakeasynet> wrote in message
news:453e40b1$1@news.povray.org...
>> Thanks,
>> jsr.
    That's what I was going to say. And yes, if that's the case, then the
room is lit well imo.
    ~Steve~
Date: 24 Oct 2006 12:58:44
Message: <453e4644@news.povray.org>
JSR wrote:
> Hello,
> Thanks,
> jsr.
Your image looks great! As for the blotchiness of some of the lighting,
I'd suggest you take a look at a small experiment I made some time ago
on researching the two-pass-radiosity-technique that was "developed" by
several members of the newsgroups, my research also went a little into
photons, using shadowless for the light-objects etc.
As for the images you linked to, I expect some of them make use of
post-processing or even HDRI techniques, which POV-Ray doesn't natively
support (yet, I guess, it'll sure be there someday). I often use the
original image, raise the contrast stupendously, then put a heavy blur
on it, and finally layer that on top of the original image using
additive-composition. This softens the image considerably, but depending
on how much you blur, how much you add it and how much color you retain
(all subject to tweaking), you get effects close to glaring highlights
or colored saturation, which IMHO often improve the image, if not overdone.
Tim
aka "Tim Nikias"
Date: 24 Oct 2006 17:40:01
Message: <web.453e878b3cae5eb8df99e4fd0@news.povray.org>
Thanks to all for your fast repost,
The color light I use for the image is <0.75, 0.72, 0.53>, it's to say,
yellowish white. The idea was to represent a sunset and I use this color
because it's the recomended by Jeremy Birn in his "color table":
http://www.3drender.com/glossary/colortemp.htm
I think that this image...
http://www.nolights.de/stills/gallery/images/prep4company.jpg
..... is very beautiful and lighting is very realistic, I would like to see
the source pov code of this image in order to have an idea of what was
wrong in my image, comparing the materials, lights, radiosity,...
JSR
Date: 24 Oct 2006 20:59:51
Message: <453eb707$1@news.povray.org>
JSR nous apporta ses lumieres en ce 24/10/2006 17:37:
> JSR
Your "sun" may not be bright enough. Try multiplying it's value by something
around 1.5 to 2. This won't change the colour.
The shadow of the window looks to sharp, I'd use an area_light.
Disc space -- the final frontier!
Date: 24 Oct 2006 23:30:01
Message: <web.453ed99e3cae5eb8da53d9e40@news.povray.org>
"JSR" <jsr### [at] gmailcom> wrote:
> Hello,
> Thanks,
> jsr.
I have to say I like your image a lot, but perhaps you didn't want light
from an overcast day?
I don't have any direct experience, but some of my favorite POV interiors
are by Jaime Vives Piqueres, like the ones here:
http://www.ignorancia.org/en/index.php?page=Modern_interior
Especially this one:
http://www.ignorancia.org/uploads/images/modern_interior/wips/interior2-060819-1.jpg
I think Jaime manages to get bright daylight without the image blooming and
losing color definition. My (limited) understanding is that for the lights
in some images he uses several sources: large area_lights on each
window/outside door, to simulate the diffuse light from the sky and
environment, and one brighter light at the sun-position for the actual
sunshadows. This gives better results than the pure sunlight+radiosity that
is perhaps closer to reality, IMO. Of course he also gets good fading
distance and light values from his LightsysIV light simulation system.
(If any of this is wrong, sorry, some is just speculation.)
Good luck- you have a nice interior to experiment with!
-Stefan Sittler
Date: 25 Oct 2006 03:32:57
Message: <453f1329$1@news.povray.org>
>> say, yellowish white. The idea was to represent a sunset and I use
>> this color because it's the recomended by Jeremy Birn in his "color
>> table": http://www.3drender.com/glossary/colortemp.htm
>> to see the source pov code of this image in order to have an idea of
>> what was wrong in my image, comparing the materials, lights,
>> radiosity,... JSR
> something around 1.5 to 2. This won't change the colour.
Indeed, I found the key is to get the ratio of brightness between the sun
light and the sky colour correct.  You can look at photos of similar scenes
to make an estimate.  Make sure your gamma settings are correct.  If you
want your indoor scene to be well exposed then both the sun and sky colour
will likely need to be above <1,1,1>.
Date: 25 Oct 2006 04:05:01
Message: <web.453f1a403cae5eb8c4455c690@news.povray.org>
> JSR
Sure, I'm at the university right now, but when I get back home, I'll see
what I can do. The chair and sofa are big meshes though, so I guess I'd
have to take those out of the scene-file and replace them with something
simpler (low-res, probably), but you'll get the materials and lighting.
Tim
Date: 25 Oct 2006 07:00:51
Message: <453f43e3$1@news.povray.org>
   Me too! I think JSR managed to get a very good lighting here (apart
from a very nice room and furniture), but some more intensity on the
sunlight will help further.
   Actually, this images uses another alternative to the "realistic"
sunlight+rad approach: ambient boxes in place of the window glasses,
with coloring dependent on the sky color from skylight.inc. So it's
still sunlight+rad, but helped a bit with these emitting surfaces and a
recursion level of 2. When using two-pass rad, you can put back the real
glass for the final render.
   No, you are right: I really used area lights on the first images...
but it was too slow for my patience.
Jaime
