"Bruno Cabasson" <bru### [at] alcatelaleniaspace fr> wrote:
> LOL!!!
> Seen from the side in the original render, the head was looking quite fine
> .... Obviously, it is not the answer to your problem. Perhaps if you rescale
> some of the components it could be OK for the catapult (the lion's head is
> small wrt to the whole thing).
Haha, I just flipped when I saw it.
Here's a somewhat modified test version.
Maybe it can go as a bear? If you look with your bad yey... :)
Download 'caapult.jpg' (81 KB)
Preview of image 'caapult.jpg'
The wide nose makes it look like a very angry pig :p.
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
Eero Ahonen <aer### [at] removethis zbxt net invalid> wrote:
> RusHHouR wrote:
> > Maybe it can go as a bear? If you look with your bad EYE... :)
A wild boar perhaps? ;)
Maybe I should just put some spikes there... :/
Meshes are so... complex!
> Once you have the mesh built lion head, why convert it to a hight field? You
> only need to place 2 instances of that mesh in your scene and you're done.
> Alain
> Agnostic: Shit might have happened; then again, maybe not.
Yes, you can just use the mesh directly (clipped as needed). But using as a
height field, you can smooth/blur the image and otherwise modify it to look
more like stamped tin. The mesh wiil be full 3 dimensionbal, whereas a
stamped tin relief would, in essence be more like a heightfield (i.e. only
one y value for each x-z point)
-tgq
Hmm, yeah.
It could go as a bear (as you said), if the nose was a bit thinner.
Surely they are. I haven't even tried.
Eero "Aero" Ahonen
http://www.zbxt.net
"RusHHouR" <gee### [at] mail nu> schreef in bericht
news:web.450848846d4b72ce47d3ae5e0@news.povray.org...
Oh! This is very nice indeed!!! Goes perfectly with the catapult!!
news:web.45085e466d4b72ce47d3ae5e0@news.povray.org...
not really!! You can make it as clomplex as you want. It's like everything,
once you start things become easier. It's a different approach, that's all.
I can recommend Wings3D for a start.
web.45035cbfb1f300bf47d3ae5e0@news.povray.org...
> Below are the original image of the catapult that Im trying to clone,
> and the progress so far. I wish I could say the top one was mine, but it
is
> of course not.
> Anyways, Im looking at the metal details now, and the two lion heads
roaring
> in the front pussles me... I tried using a height_field from a adjusted
> googled image... but, well, it's not that great as you can see.
> Any ideas on how to create a lion head like that?
> Or any teqniques on transforming "real" images to usable height_fields?
> Kaplonk!
Here is a link to a 16bit tga height_field image of a lion head (1.17MB)
http://marc.jacquier.free.fr/Pics/lionhead_hf_gen.rar
You'll have to
scale <0.82,1,1.25>* whatever_ratio_you_need
rotate x*-20
and adjust the water_level
HTH
Marc
Cousin Ricky wrote:
> "Marc" <jac### [at] wanadoo fr> wrote:
>> LOL after I saw the piano explode in fire, I expected to hear the car play a
>> chord :-p
> Well, that's only a Hollywood myth. In real life, pianos usually do not
> explode on contact. ;-)
Dump enough gasoline in them & they do... ;)
> You'll have to
> rotate x*-20
> HTH
> Marc
Wow, that will probably work really well. A big THANKS, mate!
