Mike Sobers nous apporta ses lumieres en ce 18/08/2006 17:26:
> This is my first scene with photons. I used "spacing 0.02" in the
> declaration block, with this on the Rocket only:
> photons { // photon block for Rocket
> target 1.0
> refraction on
> reflection on
> No photons declared for the other objects in the scene. I like the result,
> but I'm not sure what effect is due to the photons, so I'm in the process
> of re-rendering it without them to compare.
> Trivia - there are 52 reflection levels, but I decided to set max trace to
> 15 to speed things up a bit.
> Any suggestions, content, technique or otherwise?
> BTW, the environment is an office map generated by Jaime Vives Piqueres.
> Thanks,
> Mike
Your floor is very reflective. It makes the protons barely visible, if at all.
Try rendering again but without photons and see if there is a notable
difference. Rename your current image to preserve it and make it easier to compare.
Fighting for peace is like screwing for virginity.
- The Bayou, Baton Rouge , LO
Darren New <dne### [at] san rr com> wrote:
> Very artistic, except having an office reflected in your solar system
> seems somehow anticlimactic.
> Darren New / San Diego, CA, USA (PST)
> This octopus isn't tasty. Too many
> tentacles, not enough chops.
Well, not if you're a rocket scientist ;) I was going for a tabletop
display look, so I made it an indoor scene. Any other ideas for the
surrounding? I'm open to suggestions...
Mike
You're right, I'm thinking about changing the tabletop surface. Here's
another render, and you can see a slight effect in the shadow of the rocket
(near Earth's reflection). I like the effect, and if I change the surface I
think it will be more visible.
> Alain
That statement is so silly it's not even worth responding to. But I will
anyway, since I'm from Baton Rouge and I don't want anyone to think we have
that mindset. Very, very few people from there are so narrow minded. Maybe
no one should have fought against Hitler. I'm sure we'd all be living in a
much more peaceful world.
Mike
Download 'rocketplanets_nophotons.jpg' (66 KB)
Preview of image 'rocketplanets_nophotons.jpg'
A starfield springs to mind. It might need large brightly coloured nebulae
to be visible, though...
Bill
Or a planetarium/observatory type building? Where you could see the
reflection of a large telescope in the planets? Something like the
middle picture of http://en.wikipedia.org/wiki/Telescope
That's a grand idea. It also gave me another idea - maybe have everything
floating in freefall inside the Shuttle or ISS? Now to get to work ...
Mike
Mike:
I loaded your two images into Gimp as layers and did a difference between the two.
After adjusting
the color curve a bit, here's the result. You can easily find the differences now.
(Some of it may
be due to conversion to the jpg format.)
Kyle
Download 'RocketplanetsDiff.jpg' (113 KB)
Preview of image 'RocketplanetsDiff.jpg'
Mike Sobers nous apporta ses lumieres en ce 20/08/2006 18:02:
>> Alain
> Mike
That's a random quote from a long list. In no way can it relect the mindset of
everybody, it was lifted from a public toilet wall.
Here's another one below.
Don't cry because it is over, smile because it
happened.
Kyle <hob### [at] gate net> wrote:
> Mike:
After adjusting
(Some of it may
> Kyle
Cool. Thanks!
Mike
> Alain
> happened.
Much more optimistic! I'll have to remember that one.
Mike
