"RusHHouR" <gee### [at] mail nu> wrote in message
news:web.44c1c9e3a3cb6ace47d3ae5e0@news.povray.org...
> The table. It should be made by some poor but still kind of skilled Ural
> handyman from the 1900th century.
Good progress!
questions...
Would a skilled craftsman lay planks across the table or lengthwise?
Would he use modern, narrow, regular floorboards instead of broader planks?
DLM
"fls13" <fls### [at] netzero net> wrote:
> How'd you do the candlelight? A union? Lighting is great. Wall texture
> should be no problem, and I'd suggest a gnarlier wood for the table.
> Looking great!
Thanks, the candlelight (in this pic) is two scaled cones :)
> Very nice indeed.
> You know there are a couple of macro's around for making books (with
> titles)?
> There is one by Gilles Tran:
> http://www.oyonale.com/ressources/english/sources07.htm
> The other is by Sonya Roberts: http://www.geocities.com/SoHo/Lofts/1022/
> They are both very useful.
> Thomas
I'll check them out, but most likely not use them. For once Ive already made
my own books. And, it's more fun to have ur own.. :) Will have a look
though, probably better than my version. Thanks for the tip!
> Good progress!
> questions...
> DLM
Thank you! :) And I dont know much about craftsmanship... You tell me! But
it may just be that he used a little magic or sumthin'..(!) :P
Artemia Salina <y2k### [at] sheayright com> wrote:
> On Sat, 22 Jul 2006 09:37:00 -0400, Artemia Salina wrote:
> P.S. If that is not satisfactory you may need to create your own wood
> texture. Take a look at section 3.5.12.6.1 Black Hole Warp in the POVRay
> manual. The warp pattern modifier will let you make knots in wood textures.
This one proved to be really tough imo... I look at the "Still with bolts"
image (one of my favs in HoF), but I just dont GET IT! HOW can this be
done!?!?!?
For the moment, lets just say the guy only used the middle of the trees he
chopped down... :(
Im gonna model something very square now...
> done!?!?!?
> chopped down... :(
I'm not familiar with the image you mention. Do you have a link to it?
Today's Alliterative Monomania Headlines:
Hairbrained Hesitatory Hysterophyte Hardily Hates Halcyon Herbarian
Dellacruscan Discomfortable Decameter Dismally Dites Davidic Defendee
Misogynous Meliphagan Maladdress Moderately Maunders Methodic Magister
news:pan### [at] sheayright com...
http://hof.povray.org/boltstill3.html
Marc
Wow!
Yellow Yellow Yahwist Yawningly Yends Yellow Yard
Jimp Jaggy Jadeite Jantily Jockeys Jubilant Janglery
Falconine Flat-headed Faquir Frothily Fells Fleshly Farding-bag
>> texture.
> done!?!?!?
If you go to: http://www.ignorancia.org/en/index.php?page=Sources_map
you can download the scene file for "Still With Bolts" from the artist,
Jaime Vives Piqueres. If you want to re-render the scene you'll also need
his "Lightsys 4" macros from the same page.
He is basically using a height_field to get the wood grain for his table,
but instead of using an image file in the height_field he is using a
function which supplies a brick patterned pigment.
height_field{
function 1000, 1000 {
pigment{ brick color 1 color rgb 0 mortar 2 rotate 90*x scale .001 }
water_level 0.1
translate -0.5
texture{........}
Good luck!
Moonless Monogenic Macaw Monthly Masks Misguiding Magistracy
Dilettantish Dogged Decompound Dingily Domiciliates Deprehensible Demagogism
Light-armed Libelous Law-fall Literally Litters Leptiform Law-fall
> height_field{
> water_level 0.1
> translate -0.5
> texture{........}
Sorry, but this was the metallic grill from the second version. The
wooden version is that one:
#declare p_base_wood1=
pigment{wood turbulence .05 scale .5 translate 33}
#declare p_base_wood2=
pigment{wood turbulence .05 scale .1 translate 333}
#declare p_wood=
pigment{
wood turbulence 1
pigment_map{
[0.00 p_base_wood1]
[1.00 p_base_wood2]
scale .05 rotate 90*y
height_field{
function 512,512{
pigment{p_wood}
translate -.5
scale <50,.1,50>
texture{t_wood}
Jaime
