POV-Ray : Newsgroups : povray.binaries.images : The letter, progressing. Server Time
14 Apr 2026 22:47:17 EDT (-0400)
  The letter, progressing. (Message 11 to 16 of 16)
Subject: Re: The letter, progressing.
Date: 29 Jul 2006 16:20:01
Message: <web.44cbc286317cf5d047d3ae5e0@news.povray.org>
Artemia Salina <y2k### [at] sheayrightcom> wrote:
> On Sat, 22 Jul 2006 09:37:00 -0400, Artemia Salina wrote:
> P.S. If that is not satisfactory you may need to create your own wood
> texture. Take a look at section 3.5.12.6.1 Black Hole Warp in the POVRay
> manual. The warp pattern modifier will let you make knots in wood textures.
This one proved to be really tough imo... I look at the "Still with bolts"
image (one of my favs in HoF), but I just dont GET IT! HOW can this be
done!?!?!?
For the moment, lets just say the guy only used the middle of the trees he
chopped down... :(
Im gonna model something very square now...
Date: 3 Aug 2006 13:32:25
Message: <pan.2006.08.03.17.32.23.530965@sheayright.com>
> done!?!?!?
> chopped down... :(
I'm not familiar with the image you mention. Do you have a link to it?
Today's Alliterative Monomania Headlines:
Hairbrained Hesitatory Hysterophyte Hardily Hates Halcyon Herbarian
Dellacruscan Discomfortable Decameter Dismally Dites Davidic Defendee
Misogynous Meliphagan Maladdress Moderately Maunders Methodic Magister
Date: 3 Aug 2006 14:23:55
Message: <44d23f3b@news.povray.org>
news:pan### [at] sheayrightcom...
http://hof.povray.org/boltstill3.html
Marc
Date: 4 Aug 2006 03:04:25
Message: <pan.2006.08.04.07.04.25.310329@sheayright.com>
Wow!
Yellow Yellow Yahwist Yawningly Yends Yellow Yard
Jimp Jaggy Jadeite Jantily Jockeys Jubilant Janglery
Falconine Flat-headed Faquir Frothily Fells Fleshly Farding-bag
Date: 5 Aug 2006 14:17:29
Message: <pan.2006.08.05.18.17.28.767279@sheayright.com>
>> texture.
> done!?!?!?
If you go to: http://www.ignorancia.org/en/index.php?page=Sources_map
you can download the scene file for "Still With Bolts" from the artist,
Jaime Vives Piqueres. If you want to re-render the scene you'll also need
his "Lightsys 4" macros from the same page.
He is basically using a height_field to get the wood grain for his table,
but instead of using an image file in the height_field he is using a
function which supplies a brick patterned pigment.
height_field{
 function 1000, 1000 {
  pigment{ brick color 1 color rgb 0 mortar 2 rotate 90*x scale .001 }
 water_level 0.1
 translate -0.5
 texture{........}
Good luck!
Moonless Monogenic Macaw Monthly Masks Misguiding Magistracy
Dilettantish Dogged Decompound Dingily Domiciliates Deprehensible Demagogism
Light-armed Libelous Law-fall Literally Litters Leptiform Law-fall
Date: 6 Aug 2006 15:29:34
Message: <44d6431e@news.povray.org>
> height_field{
>  water_level 0.1
>  translate -0.5
>  texture{........}
   Sorry, but this was the metallic grill from the second version. The
wooden version is that one:
#declare p_base_wood1=
pigment{wood turbulence .05 scale .5 translate 33}
#declare p_base_wood2=
pigment{wood turbulence .05 scale .1 translate 333}
#declare p_wood=
pigment{
  wood turbulence 1
  pigment_map{
   [0.00 p_base_wood1]
   [1.00 p_base_wood2]
  scale .05 rotate 90*y
height_field{
  function 512,512{
   pigment{p_wood}
  translate -.5
  scale <50,.1,50>
  texture{t_wood}
Jaime
