POV-Ray : Newsgroups : povray.binaries.images : Deck Server Time
24 Mar 2026 23:04:43 EDT (-0400)
  Deck (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Deck
Date: 14 Jul 2006 16:30:01
Message: <web.44b7feb0155054ac150d4c10@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote:
> Looks very nice! Do you have more of these decks to publish? Wanna see more
> of them...
> Greetings,
> Sven
Only one deck (I only own one house...)  But I can always run more renders
of the same deck.  Perhaps this weekend if I get time.  Imay even post
actual photosof the deck when it is constructed.
-tgq
Subject: Re: Deck
Date: 14 Jul 2006 16:35:00
Message: <web.44b7ff7f155054a841337530@news.povray.org>
> > of them...
> > Greetings,
> > Sven
> -tgq
Wow!
Do you use AutoCAD for this?  I've been wanting to render my house in
POV-Ray, but just not sure how to build the model.... my house looks too
complicated to begin modelling it.  I'm scared I'll have to design each
2x4, brick, panels by hand!  (Forget each blade of grass!)
Subject: Re: Deck
Date: 14 Jul 2006 16:55:15
Message: <44b804b3$1@news.povray.org>
Nice multi-level deck design. I'm sure the building dept. would like to see
that render along with the plans. Good work.
Subject: Re: Deck
Date: 14 Jul 2006 20:28:06
Message: <44b83696$1@news.povray.org>
"Anthony D'Agostino" <gam### [at] contastnet> wrote in message
news:44b804b3$1@news.povray.org...
> see
Thanks.  Actually, it's less than 2ft above grade, so I don't require a
permit here.
-tgq
Subject: Re: Deck
Date: 14 Jul 2006 20:32:19
Message: <44b83793$1@news.povray.org>
"EagleSun" <nomail@nomail> wrote in message
news:web.44b7ff7f155054a841337530@news.povray.org...
>> > more
>> > of them...
>> > Greetings,
>> > Sven
>> renders
>> -tgq
> Wow!
Yes, modelled in AutoCAD.  It's really simple if you know AutoCAD (certainly
much easier than POV, especially since I already did the design drawings in
CAD).  Then it's just a matter of exporting (usually to 3ds, then converting
to POV using another prog).  Unless you really have a lot of time or can
macro it, don't model bricks, siding, etc.  Just use image_maps (with normal
maps if wanted), it's a lot easier.  As I said earlier, the siding and
bricks on this render are from actual photos of my house.
-tgq
Subject: Re: Deck
Date: 14 Jul 2006 21:06:53
Message: <44b83fad@news.povray.org>
You can try Sketchup (free from Google). Blender is free as well. Programs
like AutoCAD, or even Rhino, are overkill for simple architectural stuff if
you don't already own them.
> my house looks too
Well, you needn't. Texture maps work fine but the most extreme closeup, and
then you need only a couple of bricks anyway.
Subject: Re: Deck
Date: 17 Jul 2006 21:42:46
Message: <44bc3c96@news.povray.org>
Nice radiosity (or HDR??).
Subject: Re: Deck
Date: 18 Jul 2006 08:25:01
Message: <web.44bcd296155054ac150d4c10@news.povray.org>
HDR and HDR-based lighting macro (~256 light sources) (HDR is made from my
actual backyard)
-tgq
Subject: Re: Deck
Date: 7 Aug 2006 09:06:50
Message: <44d73aea$1@news.povray.org>
So how do you keep the grass under your deck so green and neatly mowed? :)
DLM
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.44b78d4bef9e9909c150d4c10@news.povray.org...
> I'm planning on building a deck in my backyard.  Here is a render that
> combines several of my mini projects.  The lighting is using the HDR
> lightdome macro I'm still playing with, lit using an HDR I made of my
> actual backyard.  The deck and furniture are just meshes.  The grass,
> bricks, siding and shingles are made from image maps (the bricks and
> siding
> from actual photos of my house).
> -tgq
Subject: Re: Deck
Date: 8 Aug 2006 09:50:01
Message: <web.44d89638155054ac150d4c10@news.povray.org>
> DLM
Gnomes
-tgq
