POV-Ray : Newsgroups : povray.binaries.images : Vegetation simulation WIP 1 Server Time
19 Mar 2026 19:00:27 EDT (-0400)
  Vegetation simulation WIP 1 (Message 1 to 10 of 22)
Subject: Vegetation simulation WIP 1
Date: 7 Jul 2006 17:10:01
Message: <web.44aecceb9373cf132680557b0@news.povray.org>
I want to share the first results of my planned plant distribution tool.
In principle it's an solvable problem, see
http://graphics.stanford.edu/papers/ecosys/ecosys.pdf for a basic procedure
example.
First you have to check distances to all neighbors of each plant. Dependent
of the distance and whether the neighbor is another species or not,
increase or decrease the size of the plants. A plant will be replaced after
several iterations or if the size becomes too small.
The problem is to avoid checking each plant against each other on each
iteration, because this leads to n*(n-1) checks, if n is the number of
plants.
My idea is to use my favorite povray commands - 'trace' and 'eval_pigment'.
For each plant a disc is defined with a cylindrical pigment. Then you search
for neighbors by conducting traces. If you hit a neighboring disc, you check
the pigment at this point. This way I 'linearized' the problem, at least I
hope so.
So I implemented aging and influences of several species - light, water,
roots, (soils, slope...) will be considered next.
The image shows distributions of four species after 1, 10 and 40 iterations,
each with equal plant parameters. A regular start distribution pattern was
chosen to show the effect. After 40 iterations representing 2.5 average
lifetimes no pattern is recognizable anymore.
A simple render with four different plants shows this result.
Norbert Kern
Download 'vegetation wip1.jpg' (332 KB)
Preview of image 'vegetation wip1.jpg'
Subject: Re: Vegetation simulation WIP 1
Date: 8 Jul 2006 01:50:51
Message: <44af47bb$1@news.povray.org>
Wow! That's amazing.
DLM
"Norbert Kern" <nor### [at] t-onlinede> wrote in message
news:web.44aecceb9373cf132680557b0@news.povray.org...
> Hi,
> procedure
> example.
> Dependent
> after
> plants.
> 'eval_pigment'.
> search
> check
> hope so.
> iterations,
> Norbert Kern
Date: 8 Jul 2006 03:55:03
Message: <e8noc4$j3a$1@chho.imagico.de>
Norbert Kern wrote:
> Hi,
Very nice.
> hope so.
I assume you use a union of discs and trace it. This is not really
linear but you probably reduced it to O(n*m) where only n is calculated
in interpreted code and m is in the builtin trace() (it could probably
actually be O(n*log(m)) but the bounding structures are not yet
generated at parse time AFAIK).
BTW if you generate cones/spheres instead of discs you could avoid the
additional pigment evaluation and determine the distance from the
vertical coordinate/normal.
A hardcoded implementation of this would still be way faster since you
could store the plants in a spatial data structure.
http://www.imagico.de/ (Last updated 01 Jun. 2006)
Date: 8 Jul 2006 05:57:44
Message: <44af8198@news.povray.org>
dlm spake:
> DLM
I agree!
Going to make it available soon? My mouth is already watering. It will look
very good in a scene I'm currently working on.
Nicely done,
Stefan Viljoen
Polar Design Solutions
Date: 8 Jul 2006 11:25:00
Message: <web.44afcd642617f101b0eea8730@news.povray.org>
> linear..
Thank you for the hint! Now I know, why my render time rised with a power of
two whereas I assumed the contrary. But I've an idea to overcome this
challenge.
What is a spatial data structure?
Norbert Kern
Date: 8 Jul 2006 11:40:00
Message: <web.44afd0fe2617f101b0eea8730@news.povray.org>
Thank you!
To publish the plant distribution tool will take time, because first I've to
solve some speed issues, then I need experience with my plant parameters and
finally I want to implement new features...
But if you want to use it as it is now I can send you the code.
Norbert Kern
Message: <web.44afd18e2617f101b0eea8730@news.povray.org>
> DLM
Thank you very much!
Norbert Kern
Date: 8 Jul 2006 12:41:10
Message: <44afe026$1@news.povray.org>
news: web.44aecceb9373cf132680557b0@news.povray.org...
> Hi,
Wonderfull!!
I think you used it for your  IRTC Light and Fog entry and not for the Music
round.
Marc
Date: 8 Jul 2006 12:55:01
Message: <web.44afe30b2617f10158f44e3c0@news.povray.org>
I'm being told to get offline, so I haven't gotten more than a page into the
PDF, but I assume there is some way of determining how a plant is replaced?
Can it depend on elevation, or water concentration? That is, do I get to
make an image (or something) that would allow variations in the ecosystem,
have a higher plant density at a creek and lower on rocky ground, with
varaiation in the type of population in each area? It seems like it would
be too hard to give the replacement a type given a probability map for the
set of possible plants. I just going off the top of my head here, but this
is really, really cool - it's got me excited.
Thanks for showing it to us.
-s
5TF!
Date: 8 Jul 2006 16:50:01
Message: <web.44b01a322617f101b0eea8730@news.povray.org>
"M_a_r_c" <jac### [at] wanadoofr> wrote:
> Wonderfull!!
> round.
Thank you, Marc!
In my 'Music' entry I used a single gradient pigment to control distribution
of grass, shrubs and trees. The flowers were meant to look like outpoured
notes from the violin. They were placed with the help of masks.
In my new entry for the 'Light and Fog' round I intended to use a plant
distribution tool in fact, but there was no time to accomplish it.
Now I want to demonstrate to myself, that I'm able to create such a tool.
There are good plant and tree generators and some have written excellent
landscape generators for povray. I hope to close the gap betwen them.
Norbert Kern
