POV-Ray : Newsgroups : povray.binaries.images : Vegetation simulation WIP 1 Server Time
6 Jan 2026 08:32:45 EST (-0500)
  Vegetation simulation WIP 1 (Message 21 to 22 of 22)
Subject: Re: Vegetation simulation WIP 1
Date: 13 Jul 2006 16:25:00
Message: <web.44b6abd82617f10135aef54c0@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote:
> Thank you, Sean.
> It's a pity not to see an IRTC entry from you last round.
Thanks Norbert, I did not have any good ideas for the last round or much
time to experiment but I have already started on my entry for this round..
I hope to see another scene from you, your last two entries have been
excellent!
Sean
Date: 2 Feb 2008 00:44:25
Message: <47a40339@news.povray.org>
This tool of yours, can it be downloaded somewhere? I would love to try it
out...
Sven
"Norbert Kern" <nor### [at] t-onlinede> schrieb im Newsbeitrag
news:web.44aecceb9373cf132680557b0@news.povray.org...
> Hi,
> I want to share the first results of my planned plant distribution tool.
> In principle it's an solvable problem, see
> http://graphics.stanford.edu/papers/ecosys/ecosys.pdf for a basic
> procedure
> example.
> First you have to check distances to all neighbors of each plant.
> Dependent
> of the distance and whether the neighbor is another species or not,
> increase or decrease the size of the plants. A plant will be replaced
> after
> several iterations or if the size becomes too small.
> The problem is to avoid checking each plant against each other on each
> iteration, because this leads to n*(n-1) checks, if n is the number of
> plants.
> My idea is to use my favorite povray commands - 'trace' and
> 'eval_pigment'.
> For each plant a disc is defined with a cylindrical pigment. Then you
> search
> for neighbors by conducting traces. If you hit a neighboring disc, you
> check
> the pigment at this point. This way I 'linearized' the problem, at least I
> hope so.
> So I implemented aging and influences of several species - light, water,
> roots, (soils, slope...) will be considered next.
> The image shows distributions of four species after 1, 10 and 40
> iterations,
> each with equal plant parameters. A regular start distribution pattern was
> chosen to show the effect. After 40 iterations representing 2.5 average
> lifetimes no pattern is recognizable anymore.
> A simple render with four different plants shows this result.
> Norbert Kern
