POV-Ray : Newsgroups : povray.binaries.images : Vegetation simulation WIP 1 Server Time
4 Jan 2026 23:48:58 EST (-0500)
  Vegetation simulation WIP 1 (Message 13 to 22 of 22)
Subject: Re: Vegetation simulation WIP 1
Date: 9 Jul 2006 14:25:00
Message: <web.44b148672617f1011ed69b810@news.povray.org>
> Thank you!
> In fact such a tool is always a fake. I try not to confuse it with reality -
> it only has to simulate it. This is because of the control paramenters which
> I cannot adjust in a correct way simply because I don't know them. By
> example, what is the optimum soil humidity for nettles? At least nettles
> seem to grow everywhere, so they can tolerate many conditions from sunny to
> pure shady locations. Perhaps they tolerate conditions other plants simply
> don't like, but aren't good in competing with other species. In this
> respect my model won't be very different from a pure guess.
> For water availability I got a tip of Prof. Deussen, one of the Xfrog
> authors.
> The function, which defines the ground can also serve as approximation to
> water content.
> Rocks are easy - they cast shadows. A simple image which defines shadowing
> from rocks, big plants, houses and so on is sufficient to define smaller
> and less dense vegetation near rocks. Near trees you have to consider the
> roots too, which lower water availability at those points.
> Probability maps are nice. In fact I used simple examples for some of my
> images. But with a little practice you can see the difference to an
> iterative approach.
> Norbert Kern
Yes, I understand/see the iterative process makes a major difference - what
I am wondering is if the method you are using takes into account both the
terrain and the neigboring plants, or just the latter. Anyway, now I have
time so I'll just hunker down and read the PDF.
As far as the reality of the control paramenters -- It doesn't really amtter
if they are the real numbers, does it? The look of the thing is in the
variation itself. You could use entirely fictional plants, and the process
would still give you a result that is pleasing to the eye, because it
defies the regularity of a less intensive approach. If you wanted it to be
*just* like the real world, well, I have a very nice camera you could
borrow ;) Seriously, though, it looks fantastic.
-s
5TF!
Date: 9 Jul 2006 15:25:00
Message: <web.44b1571e2617f1016d1309c00@news.povray.org>
Only plant competition was considered in WIP 1.
In the mean time I integrated water availability.
Thank you again. I fully agree with you.
Norbert Kern
Date: 9 Jul 2006 18:30:01
Message: <web.44b183032617f101a03a929d0@news.povray.org>
Not sure I understand exactly how it works but the outcome looks great..
Sean
Date: 10 Jul 2006 09:00:01
Message: <web.44b24ec92617f101c150d4c10@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote:
> Hi,
> I want to share the first results of my planned plant distribution tool.
> In principle it's an solvable problem, see
> http://graphics.stanford.edu/papers/ecosys/ecosys.pdf for a basic procedure
> example.
> First you have to check distances to all neighbors of each plant. Dependent
> of the distance and whether the neighbor is another species or not,
> increase or decrease the size of the plants. A plant will be replaced after
> several iterations or if the size becomes too small.
> The problem is to avoid checking each plant against each other on each
> iteration, because this leads to n*(n-1) checks, if n is the number of
> plants.
Wow, sounds like a neat project.  I have tp try to avoid things like that
these days, otherwise everything else I have to do suffers.  If you want to
do some more technical work on the n*(n-1) problem, have a look at this
recent thread on the random placment of non-intersecting spheres
(http://news.povray.org/povray.advanced-users/thread/%3C446b33a3@news.povray.org%3E/).
 Especially the code I put together which sets up a proximity search and
speeds things up enormously.  Good luck, and I can't wait to see more of
this in action.
-tgq
Date: 10 Jul 2006 10:50:01
Message: <web.44b268032617f1013d6a58900@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
> Wow, sounds like a neat project.  I have to try to avoid things like that
> this in action.
Thank you for the tip - it will take time to understand the details.
Norbert Kern
Message: <web.44b268952617f1013d6a58900@news.povray.org>
> Sean
Thank you, Sean.
It's a pity not to see an IRTC entry from you last round.
Norbert Kern
Date: 10 Jul 2006 11:35:31
Message: <44b273c3$1@news.povray.org>
that's fantastic. by far one of the most interesting posts here in a while.
Date: 10 Jul 2006 15:15:00
Message: <web.44b2a60b2617f1015077fe190@news.povray.org>
Thank you very much! That's encouraging.
Norbert Kern
Date: 13 Jul 2006 16:25:00
Message: <web.44b6abd82617f10135aef54c0@news.povray.org>
> Thank you, Sean.
Thanks Norbert, I did not have any good ideas for the last round or much
time to experiment but I have already started on my entry for this round..
I hope to see another scene from you, your last two entries have been
excellent!
Sean
Date: 2 Feb 2008 00:44:25
Message: <47a40339@news.povray.org>
This tool of yours, can it be downloaded somewhere? I would love to try it
out...
Sven
"Norbert Kern" <nor### [at] t-onlinede> schrieb im Newsbeitrag
news:web.44aecceb9373cf132680557b0@news.povray.org...
> Hi,
> procedure
> example.
> Dependent
> after
> plants.
> My idea is to use my favorite povray commands - 'trace' and
> 'eval_pigment'.
> For each plant a disc is defined with a cylindrical pigment. Then you
> search
> for neighbors by conducting traces. If you hit a neighboring disc, you
> check
> the pigment at this point. This way I 'linearized' the problem, at least I
> hope so.
> So I implemented aging and influences of several species - light, water,
> roots, (soils, slope...) will be considered next.
> The image shows distributions of four species after 1, 10 and 40
> iterations,
> each with equal plant parameters. A regular start distribution pattern was
> chosen to show the effect. After 40 iterations representing 2.5 average
> lifetimes no pattern is recognizable anymore.
> A simple render with four different plants shows this result.
> Norbert Kern
