POV-Ray : Newsgroups : povray.binaries.images : Crackle World Server Time
17 Mar 2026 14:04:52 EDT (-0400)
  Crackle World (Message 1 to 8 of 8)
Subject: Crackle World
Date: 16 Jun 2006 08:50:01
Message: <web.4492a816d60c57a4419961c10@news.povray.org>
Just a bit of fun with an isosurface I did a while ago.
// Persistence of Vision Ray Tracer Scene Description File
// File: IsoTest
// Vers: 3.5
// Desc: Crackle world
// Date: 11 Apr 2004
// Auth: PM 2Ring
#version 3.5;
global_settings {
  assumed_gamma 1.0
  //max_trace_level 20
//----Textures, etc--------------------------------------------
#declare SkyBlue = rgb <.035, .27, .67>*.6;  //For water & sky
#declare CM_Clouds1 =
color_map {
    [0.0  SkyBlue ]
    [0.82  rgb 0.75]
    [0.87  rgb 0.85]
    [0.90 rgb 1]
#declare T_Clouds =
texture{
    crackle
    color_map {CM_Clouds1}
    warp{
      //turbulence 0.75
      turbulence 0.2
      octaves 6
      omega 0.7
      lambda 2.25
  finish{ambient 0.9 diffuse 0.2}
//Planet colour map
#declare WLevel = 0.15;
//Interpolate Levels
#macro Level(h)(WLevel + h*(1-WLevel))#end
#declare CMPlanet =
color_map{
  [0 blue .15]
  //[WLevel rgb<0,0,0.4> filter 0.2 transmit 0.5]
  [WLevel/2 rgb<0,0.55,0.55>]
  [WLevel rgb<0,0.1,0.55>]
  [WLevel rgb<.75,.65,.2>]
  [Level(0.025) rgb<.05,.5,.15>]
  [Level(0.3) rgb<.9,.8,.25>]
  [Level(0.5) rgb<.65,.45,.1>]
  [Level(0.6) rgb<.35,.25,0.2>]
  [Level(0.7) rgb .5]
  [Level(0.8) rgb<.7, .7, .725>]
  [Level(0.9) rgb .9]
  [1 rgb 1]
#declare PCrackle =
pigment{
   crackle
   //form vnormalize(<-.5,.25,.25>)
   //metric 2
   //offset 0.25
   //solid
#declare PlanetCrackle =
pigment{
  //PCrackle
  gradient y scale .95
  color_map{
    CMPlanet
//--------------------------The actual scene-------------------
#declare f_ground = function{pigment{PCrackle}}
#declare SGround =
isosurface{
  function{
    y - 0.075*f_ground(x*7, y, z*5).x
  max_gradient 1.213
  contained_by{ box{<-1, 0, -.5>, <1, .2, 1.4>} }
  accuracy 0.003 //default 0.001
  scale 12
object {
  SGround
  texture{
    pigment{PlanetCrackle}
    finish{
      brilliance 1.25
      phong 1 phong_size 100
      diffuse 0.7 ambient 0.1
#declare SkyRad = 1E3;
sphere{0, SkyRad
  inverse
  no_shadow
  texture{
    T_Clouds
    scale <1, .2, 1> * SkyRad / 5
//--------------------------Lights & camera-------------------
#declare LightLoc = <10, 40, -30> * 30;
#declare Sun = sphere{
  LightLoc, 3E2
  pigment{rgb<1,1,.8>}
  finish{ambient 1.5 diffuse 0}
light_source {
  LightLoc rgb 1
  parallel point_at 0
  looks_like{object{Sun}}
  location <0, 5, -8.0> * 2.5 * 1.1
  look_at  3.75*y
  direction z
  angle 30
//-------------------------End of file-------------------------
Download 'isoteste2.jpg' (104 KB)
Preview of image 'isoteste2.jpg'
Subject: Re: Crackle World
Date: 17 Jun 2006 14:35:01
Message: <web.44944a6aab68785ba30dd5a00@news.povray.org>
It IS fun, and super crackley too. It has a cartoon feel to it.
Date: 18 Jun 2006 09:50:01
Message: <web.44955876ab68785b1bd1c060@news.povray.org>
Thanks, Janet. And feel free to use the colour map. It's quite good for
simple
terrain generation. Here's a shot of a partially terraformed planetoid.
Download 'planete2.jpg' (101 KB)
Preview of image 'planete2.jpg'
Date: 18 Jun 2006 09:55:00
Message: <web.449559f9ab68785b1bd1c060@news.povray.org>
And here's a slightly more normal chunk of landscape using the same
colour_map.
Download 'isotutel2.jpg' (48 KB)
Preview of image 'isotutel2.jpg'
Date: 18 Jun 2006 11:30:00
Message: <web.449570fcab68785bd76f1f750@news.povray.org>
This one's nice and bizarre - twin craters - a giant number 8 fell from the
sky. What do you use to make the height field(?)
Date: 20 Jun 2006 10:29:03
Message: <4498062f$1@news.povray.org>
Looks very surrealistic. Not my style, but interesting still!
Greetings,
Sven
Date: 26 Jun 2006 08:20:00
Message: <web.449fcf9dab68785b1bd1c060@news.povray.org>
To generate the heightfield, I used an earlier version of a crater field
generator that I posted in early December last year. Here's an example
scene of ice craters, complete with the heightfield used to generate the
image. The scene file lets you select whether to render the heightfield
data as an actual heightfield, or as an isosurface.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.438b0e52708b6d64f7ce4c3a0%40news.povray.org%3E/?ttop=229667
&toff=450&mtop=221081&moff=10
The crater field generator runs on Linux. I don't have a C compiler for
Windows. Here's a link to the program (with C source and docs):
http://news.povray.org/povray.binaries.utilities/message/%3Cweb.438fbab0708b6d6491e6526b0%40news.povray.org%3E/#%3Cweb.
The old version didn't smooth the outside of craters properly, and you can
see the resulting anomolies around the 'figure-8' craters.
I suppose I could write the crater generator in POV SDL, but it would be
very slow: you need millions of craters to make a realistic scene.
Message: <web.449fd061ab68785b1bd1c060@news.povray.org>
> Greetings,
> Sven
Thanks, Sven.
