POV-Ray : Newsgroups : povray.binaries.images : Earth render with blowout atmospheric parameters for artistic look Server Time
17 Nov 2024 10:15:31 EST (-0500)
  Earth render with blowout atmospheric parameters for artistic look (Message 1 to 9 of 9)
Subject: Earth render with blowout atmospheric parameters for artistic look
Date: 5 Jun 2006 22:00:01
Message: <web.4484e07da840f375e355eb0@news.povray.org>
I have been using this basic formula below...
min(1,pow(exp(_base_scale_radius-_atm_scale_radius*sqrt(x*x+y*y+z*z)),
_hh_gamma))
First (hidden) parameter is the "Scale Height"... that is the height above
the surface of the planet where the atmospheric density changes by a factor
of e.  (E is 2.718281828...) and is generated by fancy trigonometric
operations.  In POV-Ray, it's exp(1).  In this formula, I set "base scale
radius" to be about 32 * scale height below the surface of earth, and I set
"atm scale radius" to be 32 * scale height above the surface of earth.  I
use "Scale Height" because when you do the research, information is
available... for earth, the scale height is 8.5 km.  A rocket going
straight up when reaching 8.5 km in the sky will experience a pressure of
(surface)*e^(-1), which is about 300 mbars.
However, in POV-Ray, this function may seem broken when applied to shooting
beams through media (atmosphere).  To correct it, I apply a gamma of e.
This seems to correct a bunch of things.
So.. just experimenting with some parameters and colors, I produced this
image...
Download 'asia june 2006.jpg' (426 KB)
Preview of image 'asia june 2006.jpg'
Subject: Re: Earth render with blowout atmospheric parameters for artistic look
Date: 5 Jun 2006 22:09:43
Message: <4484e3e7$1@news.povray.org>
If the terminis was a little sharper it would look perfecto.
Date: 5 Jun 2006 23:00:00
Message: <web.4484eefce4051eace355eb0@news.povray.org>
Yeah, I know what you mean... it's extremely tricky getting the parameters
right.  For each parameter I input that produces a good scene, I can
generate another scene that will make it look bad.
Yet, I found some sample photos that shows I'm actually not very far from
the perfect scene render.
Date: 6 Jun 2006 14:44:59
Message: <4485cd2b@news.povray.org>
Hmmm... Hmmmmmm.....
Hmm! I like it a lot! I think, you actually got a better atmosphere than I
got previously. I think, most of it can be kept this way. Maybe (just my
opinion) the atmosphere is just a little bit too bright. I would suggest to
reduce the brightness or ambient (or gamma) value a little bit. Please see
again the attached photo of the atmosphere. However, the appearance of the
atmosphere might differ in dependency from the distance to Earth, I believe.
Due its brightness it looks too sharp. That would be what I would give a try
to, if I had the entire source code for the atmosphere. Would you consider
to publish it?
But besides that, I really think I would prefer your atmosphere to my own
one.
Best greetings,
Sven
Download 'Planet.jpg' (100 KB)
Preview of image 'Planet.jpg'
Date: 6 Jun 2006 22:35:00
Message: <web.44863a26e4051eaccfb0a3d70@news.povray.org>
Yeah, I blew it up purposely.  It's really tricky.  Reducing the brightness
will also reduce the haze, making the surface look too clear.
> Please see
I've seen this before... Is this a photo or a render?
> to publish it?
Sure.. I would like to publish it.... be ware that it's still in a quite
volatile state, even after working on it for more than a year already.  As
soon as I publish it, it will be modified again.
Now where do I upload it to?  There are so many confusing forums to login to
and I don't want to upload it to the wrong site.
> one.
I'm quite flattered... and would like to work together with you so that we
can perfect our renders.
Here is "/include/EagleSun/worlds.inc"
Here's a challenging sample...
Download 'gpw-20050916-nasa-sts093-708-37-atlantic-ocean.jpg' (97 KB)
Preview of image 'gpw-20050916-nasa-sts093-708-37-atlantic-ocean.jpg'
Date: 7 Jun 2006 00:28:35
Message: <448655f3$1@news.povray.org>
Uihh! That render is great!
"EagleSun" <nomail@nomail> schrieb im Newsbeitrag
news:web.44863a26e4051eaccfb0a3d70@news.povray.org...
A photo. That's why I take this as target of what I want to re-create in my
renders.
> to
One of these newsgroups here, probably this one:
"povray.binaries.scene-files".
> I would like to work together with you so that we can perfect our renders.
Sure! Great! Anytime! Let's work out now, how.
Where?
Best greetings,
Sven
Date: 7 Jun 2006 09:10:01
Message: <web.4486d01de4051eac841337530@news.povray.org>
Whoah!  *blush* that's not a render... it's a photo to give us a challenge.
> > to
OK... I'll upload there... though not sure how a Pov source can be
considered a "binary"...
> Where?
OOPS!  what I mean is that I'll upload it once I know where to upload it
to... I had a dream last night that will simplify the source code.  I'm
doing a few QA renders then I'll upload it.  Look for it before 15:00 UTC
today at povray.binaries.scenes-files.
Hmm... I almost clicked on [Send] and before I clicked, I noticed a QA
render is doing quite well...
Date: 7 Jun 2006 10:45:01
Message: <web.4486e58fe4051eac841337530@news.povray.org>
I just posted it there...
Here's part of "solarsys.pov" that will render Earth.
global_settings {
 max_trace_level 20
 assumed_gamma 1.0
 ambient_light 0
/* radiosity {
  brightness 1/32
  media on
  normal on
  count 1000
 // pretrace_start 1/16
 // pretrace_end 1/128
#include "EagleSun/worlds.inc"
#declare sun_radius = 695000;
#declare venus_distance = 108200000;
#declare earth_distance = 149600000;
#declare moon_distance = 384401;
#declare mars_distance = 227940000;
#declare jupiter_distance = 778330000;
#declare saturn_distance = 1429400000;
#declare uranus_distance = 2870990000;
#declare neptune_distance = 4504300000;
#macro Earth(_distance, _hour, _year, _heading, _pitch, _bank)
 SunLight(earth_distance, sun_radius, rgb 1, 10, _heading, _pitch, _bank)
 #local _albedo=0.39; // Map is already adjusted for albedo.
 #local _radius=6370;
 #local _tilt=23.45;
 #local _tiltshift=354/365.25;
 object {
  LandSurface(_radius, 8.85, 0, _albedo, jpeg_type, "Solar
System/Earth/EarthMap_2500x1250.jpg", jpeg_type, "Solar
System/Earth/EarthElevation_2500x1250.jpg")
  TransformWorld(_distance, _hour, _year, _heading, _pitch, _bank, _tilt,
_tiltshift)
 object {
  Clouds(_radius, 9, 1, jpeg_type, "CloudMaps/EarthClouds_2500x1250.jpg",
rgbt 1, rgb 1)
  TransformWorld(_distance, _hour+1, _year, _heading, _pitch, _bank, _tilt,
_tiltshift)
/* object {
  Atmosphere(_radius, 8.5, 91/255, 117/255, 192/255, 32/65535, 1, 0)
_tiltshift)
 object {
  Atmosphere(_radius, 0.75, 173/255, 186/255, 224/255, 96/65535, 2.71828, 0)
_tiltshift)
 object {
  Atm2Sphere(_radius, 8.5, 32/255, 53/255, 145/255, 0.008, 1, 3, 91/255,
117/255, 192/255, 0.115, 1)
 // AtmSphere(_radius-0.01, 8.5, 91/255, 117/255, 192/255, 0.015, 0.25)
_tiltshift)
Stars_Crackle(105, 0, 30)
Earth(0, 16, 0.75, 105, 0, 30)
TerragenViewFrom(1, 6370*2.5, 0, 0, 0)
Date: 7 Jun 2006 17:27:37
Message: <448744c9$1@news.povray.org>
High!
> image...
Great weather in Afghanistan... except for some thunderheads over
Nangarhar and Kunar province (which are usual in summer)! Minimalist
Khyberspace in a way...
See you there!
Yadgar
