POV-Ray : Newsgroups : povray.binaries.images : Radiosity - I love it! Server Time
15 Nov 2024 00:19:20 EST (-0500)
  Radiosity - I love it! (Message 1 to 6 of 6)
Subject: Radiosity - I love it!
Date: 15 May 2006 08:00:01
Message: <web.44686c92293b371731f01d10@news.povray.org>
There are plenty of pictures like this in tutorials, etc, but this doodle
turned out to be such a nice demonstration of how radiosity can make an
image come alive that I thought I had to share it.
Leftmost image - no radiosity, single light source.
Middle image - (fairly) basic radiosity, identical geometry, single light
source.
Rightmost image - (slightly) tweaked radiosity, (slightly) improved
geometry, background, single light source.
Although there are still quite a lot of artifacts, the increase in realism
is breathtaking.
Actually, the third image is a double-pass render, the reasons for which may
be interesting to some. You should be able to see (from reflections, etc)
that there is glass in all the openings. I found that using radiosity with
the glass darkened the whole image considerably, because the radiosity
samples destined for the sky were being intercepted by the glass panes.
Using a first pass without glass corrected this to some extent, although
obviously supplementary samples will again be intercepted. Does anyone know
of another way to avoid this problem? Hopefully I'm missing something
bleedin' obvious... :)
Bill
Download 'radios.jpg' (152 KB)
Preview of image 'radios.jpg'
Subject: Re: Radiosity - I love it!
Date: 15 May 2006 08:35:00
Message: <web.446874e3a3cfb9296dafe8a70@news.povray.org>
I've had to do the same thing. I haven't tried this, but if you use
no_radiosity (megapov), it may leave the glass out of all radiosity
calculations
altogether - but I'm not sure it will give the result you want.
I've been a fan of the two pass since my last IRTC entry - so in my opinion
that's the way to go.
-S
5TF!
Date: 15 May 2006 10:40:01
Message: <web.446891e9a3cfb929da5ae7f0@news.povray.org>
Thanks Bill, nice work! Are you able to share this scene file?
George
Date: 16 May 2006 02:56:26
Message: <4469779a@news.povray.org>
news:web.44686c92293b371731f01d10@news.povray.org...
may
know
Yes, the double pass like you describe it,  is the best way to go about it.
I learned that from Tim Nikias's "Windows Room" which was the basis for my
ice age scene last year.
Date: 16 May 2006 05:15:00
Message: <web.44699763a3cfb929731f01d10@news.povray.org>
I'll finish it up to a 'final' state over the next few days and post it
then. If it's just the radiosity settings you're interested in, I've gone
over to using the two-pass recipe detailed on Tim Nikias' excellent site:
http://www.nolights.de/projects/radiosity/radiosity.html
Bill
Date: 16 May 2006 05:15:01
Message: <web.446997cca3cfb929731f01d10@news.povray.org>
Oh well. I think I need two-pass radiosity on scenes like this anyway...
switching some objects on and off at the same time is no extra trouble
really!
Bill
