POV-Ray : Newsgroups : povray.binaries.images : Grass 'n' Glass Server Time
19 Apr 2026 05:29:13 EDT (-0400)
  Grass 'n' Glass (Message 1 to 10 of 12)
Subject: Grass 'n' Glass
Date: 5 Apr 2006 17:35:00
Message: <web.44343684146b5f1439c1f1d20@news.povray.org>
To be honest I'm very nervous about posting an image here as I only
discovered POVRay since the 26th.  Thoroughly enjoying it though as I've
been ill for over a year now so no longer have a job in software
development and I can't get out anymore to do my photography.  Ah well, I
think this could be a lifelong passion!
On to the image.  The reason I'm posting it is because I wrote a macro (over
the past three or four days) to create Meadow Foxtail, each one having
random differences from the others.  I completed it tonight and thought I
would post it here as others have done with their macros in the past.
Before I got round to it though I thought it was about time I actually
created a full scene, and I don't think it's too bad for an extra half hour
work (although perhaps a little tacky).  So primarily I hoped someone would
comment on the Meadow Foxgrass itself, but secondly if anyone has any
comments on the scene I would love to hear them too.
And one last thing, kindly please!  I'm only a baby pover!  :D
Tim
Download 'grass_n_glass.png' (93 KB)
Preview of image 'grass_n_glass.png'
Subject: Re: Grass 'n' Glass
Date: 5 Apr 2006 19:10:57
Message: <44344e81$1@news.povray.org>
Reminds me of a Blake's 7 episode, Shadow.
To comment on the image: it's strange seeing grass grow from a
reflective plane, but I like the effect :p
cu!
Date: 5 Apr 2006 19:13:45
Message: <44344f29$1@news.povray.org>
A great start going with a macro already. I guess some people like me still
don't take advantage of that in POV as much as should be, since it's
something fairly new that came along after so many version changes.
I wasn't sure what this plant is (nor what most anything is) so I did a
google image search for it. Pictures almost always show longer "foxtails"
than yours here. Maybe they're different in different places or times of
year?
Only thing I was going to suggest is maybe using a green to yellow variation
for the stalks, and the pictures I saw show that's possible in the actual
plants. Probably something again that varies with particular varieties and
times of year, just that plain green doesn't seem as true to life when
rendering a plant.
Looks like you used a light directly above the plant that makes most of the
tops dark. Not sure if that was your intention but guessing you tried to
show both lit and unlit sides. The lack of shadows on the ground (or water)
is interesting.
Oh, and welcome to the newsgroups and your new hobby! You're off to a
fantastic start-- even if you didn't post a reflective sphere over checkered
plane per tradition (I didn't either).
Bob H  www.3digitaleyes.com
http://3digitaleyes.com/imagery/
Date: 5 Apr 2006 20:40:00
Message: <web.443462002c9ee25b39c1f1d20@news.povray.org>
I tried to find whatever Blake 7 thing it is the picture reminds you of but
had no luck.  I like graphics where there is something subtle but obviously
(if that makes sense) "wrong" or "strange", and I'm dead chuffed you like
the effect I've used here.  Thanks for the comment.  :D
I didn't realise this was a fairly new feature.  I thought constructing
macros was a good place to start learning to pov given that I used to be a
developer, and whatever I write can be used in future pictures if they're
reusable enough.
> year?
I grew up in the Scottish countryside and this grass grows everywhere there.
 It's THE plant which makes me think of summer which is why I wanted to
model it.  I sent a copy of the picture to my father as he's clued up on
botany and nature in general and he said the same thing about the foxtails.
 I thought the same thing too, but what bothers me is that the botany site I
used as reference says they are between 5-8cm long which is exactly the
range I've used.  Last night I spent a few hours reconstructing the foxtail
to make it *appear* longer but can do no more.  So when the Meadow Foxtail
grows again I intend to check the length myself, and change it if
necessary.  My other option is to reduce the range to something line 7-8cm.
 If that doesn't help though I'm going to be at a loss whether to
inaccurately lengthen them for appearence or not.  :-/
> rendering a plant.
Again I agree with you, but again I'm going to wait until it grows so I can
check the colour variations in detail!
> is interesting.
Not being used to 3d rendering I used a typical (and very basic) lighting
setup in my closeup natural photography.  The main light is coming from the
left-rear, while a weaker light from the right-rear fills in the shadows
while retaining the texture.  At least that's the plan!  The difference in
lighting with the tops is because each foxtail is covered in about 100
(give or take) tiny cylinders at an angle (with a slight randomness).  I'm
not convinced its 100% accurate but I thought it gave a good idea to the
feel of the real plant.
Thank you loads for the comments, and I do appreciate that you've taken the
trouble to look for pictures of the real plant.  I'm off to have a go at
that great idea of an image you've suggested!  ;-)
Date: 6 Apr 2006 00:48:26
Message: <44349d9a$1@news.povray.org>
"fairly new" was a slip of the tongue. I should have worded that another
way. I've used POV-Ray for about 12 years now and the macro feature was
added to version 3.1. Sure, maybe it's been a half-dozen years since then
but I can be slow to adapt.  ;)
Back to your rendering...
Thanks for explaining the lighting used. Looking at it with higher
brightness here now, I can see them better than before. I was going to
mention potential for the well-known coincident surfaces problem, but I'm
not really able to see anything wrong concerning that so I suppose the
randomness is preventing that. The small size of those things makes it
impossible to be sure anyway, but it would show up as either blank or
speckled parts if the cylinder ends matched. It's the extreme darkness of
them that just looks wrong to me with that whiteness all around, something
'radiosity' might help with to illuminate them more.
I've tried to find out what kind of plant this reminds me of. Something I
was always plucking from the ground and tearing apart when I was a kid in
Washington (northwest US). Apparently called buckthorn but this is the only
relevant photo I could locate and it isn't a very good one. They didn't have
thorns so I don't know why the name.
http://www.plantsgalore.com/articles/weeds/images/Weed_Buckthorn.jpg
The flowering top parts can look much like the middle two in your plant
before they turn into tiny flowers. That plant just seemed to attract me to
ripping it apart, kind of like blowing on dandelion fluff did.
Date: 6 Apr 2006 06:40:00
Message: <web.4434efd32c9ee25b39c1f1d20@news.povray.org>
Hehe, looking at the picture you linked to it looks very much like a common
weed I used to rip apart as a kid!  It was as if it had a label on it
saying "Destroy Me."  Coincidentally though, halfway through writing the
macro I realised it wouldn't take much to create another macro to create
that plant.
I'm sure there's no problem with coincidence surface problems as I chose the
angles and vertical gaps to avoid that.  I think if thhat problem existed
the heads would appear as black splodges as there are just so many
cylinders.  I double checked the darkness issue and verified it is simply
because of the angles of the cylinders when the plant is turned around.  I
tried altering the radiosity but I didn't like the results.  Instead I've
ensured that none of the stems are placed at such an angle to cause the
problem.  I'm thinking (hoping) that the contrast between the stems is
going to add some depth and interest to any future landscape images I use
this macro in.
I noticed a fault with the generation of the leaf blade meshes, so rewrote
that part to provide a better and more varied curve and to stop them looing
like thin wire clones of eachother.
Finally I found a website which specifies the heads to be 9cm long so my
random value is now from 7-9cm.  That and a little jiggery pokery I did
with the seeds/cylinders and I reckon they look good now.  The picture has
grown on me now so although I know it's not up to the standard of most of
the pictures here, I'll probably post and hope for more feedback!
Tim
Date: 6 Apr 2006 11:40:00
Message: <web.443535492c9ee25b39c1f1d20@news.povray.org>
I received an email asking if I could send the macro for this, so I'm gladly
posting it into the binary utilities newsgroup.  Below is an updated image
which shows the improvements I've made.
Tim
Download 'serenity.png' (93 KB)
Preview of image 'serenity.png'
Date: 6 Apr 2006 11:48:54
Message: <44353866$1@news.povray.org>
"Tim" <tim### [at] gmailcom> wrote in message
news:web.44343684146b5f1439c1f1d20@news.povray.org...
it does quickly become an obsession :)
(over
hour
would
Nice work. For the stems, the ones that go crooked look a little too sharply
crooked. For the scene, i'd change the lighting somewhat. Maybe add a dim
fill light directly behind the camera (so as to not cast unwanted shadows),
or use some radiosity. Otherwise, it's a perfectly fine first posting to the
group.
-r
Date: 6 Apr 2006 12:35:00
Message: <web.443541ee2c9ee25b39c1f1d20@news.povray.org>
Hi Ross,
> crooked.
Hmmm, I think that must be the lighting.  For the stems I simply took a
random length within a given range, multiplied it by 16 and created a torus
with that circumference, then took 1/16th out which gave the final bend to
the stem.  This way I could use polar coordinates to find any point I
needed to.  On the other hand... :)  if you mean the angle they're leaning
to you may be right!  My intentions are to examine the meadow foxtail
directly when the time of year comes around.  And if I get the chance I'll
study it's movement in various wind conditions and add an interface to use
that information.
> group.
> -r
Your right about the lighting, there's no other word for it!  I only quickly
rendered a half hour scene last night to show the plant really.  I tried
playing with the light settings this afternoon after chatting with Bob H
but could only make it worse!  To tell the truth I gave up, deciding that
with so much light bouncing about it wasn't the best scene to learn on.
There's no denying it, I chickened.  :-/  Thanks for your comments though.
I was expecting to be cut down today as I know it can be so easy to like
anything you put alot of effort into regardless of what it looks like, and
it's nothing compared to the other images on this site, but the comments
I've received so far have been a big confidence booster.
Tim
Btw the macro is posted to the binary utilities now so I hope people can
make some use of it.
Date: 7 Apr 2006 15:53:42
Message: <4436c346@news.povray.org>
 Hiya Tim, welcome to the world of PovRay. Don't be nervous though, there
are a whole bunch of people around here with varying expertise in many
aspects of... erm, life, and CG art! If they can help in any way, they will,
so just ask away in any of the groups for your subject.
    And a passion it is. A wholehearted one for me and many, many others. I
hope you enjoy it as much as I've seen many people here enjoy it.
> (over
  I like it, and I see where you're getting that angle on the leaves from.
It's a very similar grass to the Timothy Grass we have here in the UK:
http://strubi.uni-graz.at/projects/allerg_03.jpg
> hour
> would
   Well, Googling images of the Meadow Foxtail, I notice that the actual
shape of the flower-head(?) is more of a torpedo shape, maybe you could try
that out? Generally though, your image is a nice, relaxing, mellow scene. A
good start.
  (Sheesh! Listen to me. I sound like a teacher writing a school report!
Anyway, you're A+ at the moment...)     ;)
    Ok, we'll let you off just this once...
    Oh, and don't forget the 'Reflective Sphere Over Chequered Plane' thing
that goes on around here. See if you can come up with something different.
   Liked the later image too.   :o)
       ~Steve~
> Tim
