POV-Ray : Newsgroups : povray.binaries.images : Another version of my RSOCP with media spies: problem with radiosity. Server Time
24 Aug 2025 07:01:38 EDT (-0400)
  Another version of my RSOCP with media spies: problem with radiosity. (Message 1 to 8 of 8)
Subject: Another version of my RSOCP with media spies: problem with radiosity.
Date: 11 Feb 2006 09:25:01
Message: <web.43edf2f92b3ecd292a0416a70@news.povray.org>
Continuing the RSOCP theme (see thread started at
<web.43eafcf196b04c3582fc96790@news.povray.org>), I rendered a radiosity
version, with 3 spheres. Appart from wrong settings for the media sampling
(and long render time ...), I was puzzled by the reflection of the top
sphere on the main one: the spherical pattern of the media appears black!!
And I also noticed that if I add a fourth sphere, no reflection occurs for
any sphere...
Here is the render as it was when I stopped it. If someone has suggestions
(I can post the source code if necessary).
  Bruno.
Download 'scr_rsocp_6.jpg' (69 KB)
Preview of image 'scr_rsocp_6.jpg'
Subject: Re: Another version of my RSOCP with media spies: problem with radiosity.
Date: 11 Feb 2006 10:10:01
Message: <web.43edfe2d4400fb64e46f6db80@news.povray.org>
Sounds like max_trace_level to me. I like the image.
-s
5TF!
Date: 11 Feb 2006 10:25:30
Message: <43ee01ea$1@news.povray.org>
Bruno Cabasson nous apporta ses lumieres en ce 11/02/2006 09:21:
> any sphere...
>   Bruno.
You probably need to increase max_trace_level.
Make the calculations:
Enter the first media container, reflection on the sphere, exiting the container = 3
levels
Add 3 more levels for the second sphere (2 if you only encounter the container) = 6 or
5 levels total.
Add 1 more for reaching the background.
So, you need a strict minimum max_trace_level of 7, 10 if you bounce on 2 spheres and
encounter a
third one.
Don't fear setting it to high.
WARNING: The consumption of alcohol may leave you wondering what the hell happened to
your bra and
panties.
Date: 11 Feb 2006 15:55:00
Message: <web.43ee4e6e4400fb6450912bc60@news.povray.org>
> > any sphere...
> >   Bruno.
levels
or 5 levels total.
and encounter a
> third one.
> Alain
to your bra and
> panties.
You're right. I increased max_trace_level, and it is ok for the reflection.
I should have found this myself, shame on me ;-) Now, my concern for this
scene is to set proper parameters for the media, in order to have no
artifacts and an aceptable render time.
  Bruno
Date: 12 Feb 2006 05:00:01
Message: <web.43ef06dd4400fb64a8399d8d0@news.povray.org>
like the image to. :-)
Is there any way to increase max_trace_level above 255 ? or would that
require some code changes?
the make-cloud macro's use a ton of medial layers, and I almost at 255
witch a single cloud. I can only slightly overlap clouds if they are rotated
45 degrees.
I'm using this in a 3000 frame animation, and render speed has not been a
problem until now..
Download 'wow2.png' (279 KB)
Preview of image 'wow2.png'
Date: 12 Feb 2006 11:09:08
Message: <43ef5da4$1@news.povray.org>
Jaap nous apporta ses lumieres en ce 12/02/2006 04:58:
> 45 degrees.
> problem until now..
You can use adc_bailout to limit the deepth you reach. When you exeed max_trace_level,
the colour
returned is black. When you stop due to adc_bailout, the colour returned is whatever
you have up to
that point.
You need to change the code to exeed max_trace_level 255. Probably limited by the size
of some aray.
Light travels faster than sound. That is why some people appear bright until you hear
them speak.
Date: 12 Feb 2006 16:00:00
Message: <web.43efa0c94400fb6419b3193a0@news.povray.org>
> > 45 degrees.
> > problem until now..
max_trace_level, the colour
you have up to
> that point.
size of some aray.
> Alain
hear them speak.
OK. thanks for the tip! I'll try it this night. Today I rendered the
attached image. Still some artifacts, where the media is very thin I
think). Again, I use 1 interval and 200 samples. Render tme: 18:30 hours...
for 512*384 and radiosity.
    Cheers.
       Bruno.
Download 'rsocp_7.jpg' (24 KB)
Preview of image 'rsocp_7.jpg'
Date: 14 Feb 2006 03:20:00
Message: <web.43f192534400fb6482fc96790@news.povray.org>
Here is the final 512*384 render. There remain a few little artifacts, but
I'll leave it  so.
   Regards.
Download 'rsocp_8.jpg' (73 KB)
Preview of image 'rsocp_8.jpg'
