POV-Ray : Newsgroups : povray.binaries.images : graphing calculator - why not :) Server Time
18 Feb 2025 18:02:51 EST (-0500)
  graphing calculator - why not :) (Message 1 to 10 of 17)
Subject: graphing calculator - why not :)
Date: 15 Dec 2005 15:20:01
Message: <web.43a1cea9363166ed2ed1de200@news.povray.org>
All I can say is "why not." Calculators cost money but you can make one for
free.  Actually I have my old HP48 but wanted to do this anyway.
Where I got stuck before (this is an old project which I recently came back
to) was that I needed to be able to have a whole arbitrary expression as a
string that I could display as well as evaluating it to a float that I
could plot.  val() of course can convert a string literal to a float, but
val("2+2") returns the number 2.
It seemed somewhat cumbersome to do so, but I finally gave in and outputted
strings to a file, to be read back in as a macro holding an expression.
Here's that macro to create the temp file:
#macro Make_Temporary_Expression_Macro_File(Eq)
        #fopen  Calculator_Temp_Expression_File
"Temporary_Expression_Macro_File.tmp"  write
        #write (Calculator_Temp_Expression_File, "/* This is a temporary
file generated and used by calculator.pov and can be deleted without harm.
*/n")
        #write (Calculator_Temp_Expression_File, "#macro Evaluate_Eq_For_X
(X)  n")
        #write (Calculator_Temp_Expression_File, "      #declare Eq_Y = " )
        #write (Calculator_Temp_Expression_File, Eq ) //the function
        #write (Calculator_Temp_Expression_File, "; n#end n" )
        #fclose Calculator_Temp_Expression_File
#end // end  Make_Temporary_Expression_Macro_File
Any better ideas?  The little temp file gets written over once for each
function and once for each expression.
The way it is now the calculator will display up to 10 funtions, and 10
expressions with their evaluated answers.  Functions can be displayed as
either lines or dots, line thickness can be set for each function as well
as how frequently along the x-axis the funtion is evaluated. (200 times
seems like a good number for most.)
The viewable region is adjustable (-2*pi to 2*pi for x and -2 to 2 for y as
displayed here) and each funtion will only be plotted where they coincide
with that region; they do not get scaled independantly as they don't have
independant ranges.  I also haven't gotten around to making auto-adjusting
hash marks for the axis yet.
Thanks,
Charles
Download 'calculator.png' (79 KB)
Preview of image 'calculator.png'
Subject: Re: graphing calculator - why not :)
Date: 15 Dec 2005 20:06:40
Message: <43a21320$1@news.povray.org>
> */n")
> (X)  n")
I did something like this for an AmigaBasic program about a dozen years
ago.  I had the program use RPN for the expressions, because they're
much simpler to parse.
John
Date: 16 Dec 2005 00:55:00
Message: <web.43a2562411ef9f355c0503730@news.povray.org>
Hehe I like reverse polish on my HP, but I wanted to take advantage of
whatever POV already knew how to do... E.g. any function or user created
macro that can return a float will work.   For a while I was considering
making a string parser (a string parser within a parsed-string/sdl!) to
read in the numbers digit by digit and so on, but I thought that'd be a lot
more work than doing this writing a file and reading it back.  Actually
back in college I did write such a parser for a C class but it only
supported the basic +-/x%
Date: 16 Dec 2005 01:27:44
Message: <43a25e60@news.povray.org>
Is reverse polish done with something like this??
finish{
	phong -1
Cheers!
Rick Measham
Date: 16 Dec 2005 02:15:00
Message: <web.43a2694e11ef9f35dc45bc820@news.povray.org>
> finish{
>  phong -1
> Cheers!
> Rick Measham
almost...
#declare notation =
finish{
 phong -1
        roughness 1
Date: 16 Dec 2005 05:36:53
Message: <43a298c5$1@news.povray.org>
"Joanne Simpson" <cor### [at] onewhiteravencom> wrote in message
news:web.43a2694e11ef9f35dc45bc820@news.povray.org...
> > finish{
> >  phong -1
> > Cheers!
> > Rick Measham
> almost...
> #declare notation =
> finish{
>  phong -1
>         roughness 1
I'm quite sure roughness has no effect on phong, only on specular, but I
might be wrong of course :)
cu!
Date: 16 Dec 2005 09:22:20
Message: <43a2cd9c$1@news.povray.org>
news:43a298c5$1@news.povray.org...
I think you're right, IIRC, the corresponding parameter for phong is
phong_size
Marc
Date: 16 Dec 2005 16:36:15
Message: <43a3334f@news.povray.org>
Hash: SHA1
>>finish{
>> phong -1
> almost...
> #declare notation =
> finish{
>  phong -1
>         roughness 1
	Nonono, reverse polish is done with this:
- -1
phong
1
phong_size
finish
		Jerome
*      Jerome M. Berger      *
*  mailto:jeb### [at] freefr   *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFDozNOqIYJdJhyixIRAub+AKCf98kThdJ8BoEUINFQ9dmf4QA1RwCfYkRB
rC3rYx13ylcG23xj9aicVt8=
=xhQQ
-----END PGP SIGNATURE-----
Date: 16 Dec 2005 17:38:26
Message: <43a341e2$1@news.povray.org>
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
High!
> - -1
> phong
> 1
> phong_size
> finish
Hehe... the whole sub-thread wouldn't have started if Charles had used
an upper case "p" for his "polish"... back in 1984, I read in the
then-popular German computer magazine "RUN" an article about Forth, a
programming language which just had been made available for the
Commodore 64. I really do not know much about Forth, but I remember that
its design strongly is based on stacks, which leads to a syntax which is
rather strange compared to other programming language: the "Inverted
Polish Notation". Obviously, (one of) the mathematician(s) who invented
Forth hailed from Poland...
See you in Khyberspace!
Yadgar
Now playing: Tel Aviv (Duran Duran)
Date: 16 Dec 2005 20:45:53
Message: <xRl$LQAK02oDFwQQ@econym.demon.co.uk>
>> Hash: SHA1
>High!
>> - -1
>> phong
>> 1
>> phong_size
>> finish
The term "Reverse Polish Notation" was coined by Hewlett-Packard
engineers to describe the method used in their early calculators. I
guess they had trouble pronouncing "Reverse Lukasiewicz Notation". (The
"L" should be pronounced something like a "W")
http://www-history.mcs.st-and.ac.uk/Mathematicians/Lukasiewicz.html
Mike Williams
Gentleman of Leisure
