POV-Ray : Newsgroups : povray.binaries.images : wallpaperstuff, no idea how to name this ;-) (~200kB) Server Time
15 Apr 2026 18:09:51 EDT (-0400)
  wallpaperstuff, no idea how to name this ;-) (~200kB) (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: wallpaperstuff, no idea how to name this ;-) (~200kB)
Date: 6 Dec 2005 21:49:12
Message: <43964da8@news.povray.org>
"Roman Reiner" <lim### [at] gmxde> wrote in message
news:web.4395da06880ce8cba3509ba00@news.povray.org...
> Hi There!
> Nothing spectacular... I rendered this one a few days ago because i got
> bored of my wallpaper. And the longer i look at it the more i like it :-)
> So i decided to post it here.
> Maybe someone likes it too
> Regards Roman
Hi, I *love* these sort of scenes.  I allways struggle with them though :)
Is there any chance I could take a peek at the code?
Cheers Dre
Date: 6 Dec 2005 22:10:35
Message: <pan.2005.12.07.03.10.30.724469@nospam.com>
Very nice, I'm with Dre, would be very interested in seeing the source
files if you're so inclined. :-)
Jim
Date: 7 Dec 2005 01:05:53
Message: <43967bc0@news.povray.org>
Roman Reiner spake:
> Hi There!
> Regards Roman
Agreed - defnitely my new wallpaper too.
Stefan Viljoen
Polar Design Solutions
Date: 7 Dec 2005 09:35:01
Message: <web.4396f07bbadd071c8af771770@news.povray.org>
Hi there!
Thank you all very much for your nice comments!
Sure! but i told you there isn't something spectacular in there ;-)
here it is:
[codeblock]
  location 1.2*<-2.5,10,-5>
  look_at 0
  angle 65
background { rgb 1 }
light_source {
  <-5,15,-5>
  rgb 1.5
plane {
  y, 0
  pigment { rgb 0 }
  finish { reflection 1 }
    //I don't see any reflections in the image, do you? but it
    //looks different with only a white plane ore just with a
    //white background... *weird*
global_settings {
  max_trace_level 32      //looks veeery ugly without that :D
//creating the boxes (superellipsoids)
#declare H = seed(27);
#declare S = seed(13);
#declare f = .1;
  //parameter adjusting the "roundness" of the superellipsoids
#declare i=-10;  //from left
#while (i<14)    //to right
  superellipsoid {
    <f,f>
      //"roundness" of the box
    pigment { rgb 1+<0,.25*rand(S),rand(S)> transmit .8 }
      //color is a little bit randomized. mainly blue
    scale .25*rand(S)
      //nothing to say here :D
    scale y*2.5*(1+rand(H))
      //the fact that the height is scaled separately
      //and with an other seed is a relic of an older version ;-)
    #local j = 2.5*pow(rand(S),1.5);
      //the amount how much the box is translated from
      //the middle axis (towards upper/lower side of the image)
      //pow is used to "bundle" the objects at the center
      //results in smoother outlines since only very
      //big (almost 1) values stay big. smaller values
      //are scaled towards the center
    translate <i,0,j>
      //move it finally
    no_shadow
      //spares a lot of rendering time ;-)
  superellipsoid {
    //the same thing on the other side of the centerline
    <f,f>
    pigment { rgb 1+<0,.25*rand(S),rand(S)> transmit .8}
    scale .25*rand(S)
    #local j = -2.5*pow(rand(S),1.5);
    translate <i,0,j>
    no_shadow
  superellipsoid {
    //and a few other blocks with some different values
    //(also in pairs)
    <f,f>
    scale .25*rand(S)
    #local j = 5*pow(rand(S),1.5);  //and again
    translate <i,0,j>
    no_shadow
  superellipsoid {
    <f,f>
    scale .25*rand(S)
    #local j = -5*pow(rand(S),1.5);
    translate <i,0,j>
    no_shadow
  #if(mod(10+i,.1)=0)  //that's meaning not so many ;-)
    superellipsoid {
      <f,f>
      scale .25*rand(S)
      #local j = 7*pow(rand(S),2);
      translate <i,0,j>
      no_shadow
    superellipsoid {
      <f,f>
      scale .25*rand(S)
      #local j = -7*pow(rand(S),2);
      translate <i,0,j>
      no_shadow
  #if(mod(10+i,.2)=0)  //that's meaning even less
    superellipsoid {
      <f,f>
      scale .25*rand(S)
      scale y*4*(1+rand(H))
      #local j = 10*pow(rand(S),2);
      translate <i,0,j>
      no_shadow
    superellipsoid {
      <f,f>
      scale .25*rand(S)
      #local j = -10*pow(rand(S),2);
      translate <i,0,j>
      no_shadow
  #declare i=i+.05;
//that's it
[/codeblock]
Regards Roman
Date: 7 Dec 2005 13:21:00
Message: <pan.2005.12.07.18.20.56.550763@nospam.com>
On Wed, 07 Dec 2005 09:32:18 -0500, Roman Reiner wrote:
> here it is:
I attempted a render with 3.61, and got:
--- snip ---
File: blocks.pov  Line: 6
File Context (5 lines):
  look_at 0
  angle 65
--- snip ---
It looks like the line right after the block listed has a } that is never
opened - is something missing from the top of the file?
Thanks again,
Jim
Date: 7 Dec 2005 17:07:22
Message: <43975d1a$1@news.povray.org>
news:web.4396f07bbadd071c8af771770@news.povray.org...
> Hi there!
> here it is:
<snip>
Thank you very much!  It may not be very spectacular (to you), but I allways
learn new things when looking at scenes like these :)   Great work!
Btw, it renders fine with my version (Windows 3.6)..
Cheers Dre
Date: 7 Dec 2005 17:29:24
Message: <pan.2005.12.07.22.29.20.303780@nospam.com>
Interesting, I'll give it another try. :-)
Jim
Date: 7 Dec 2005 17:31:56
Message: <pan.2005.12.07.22.31.52.348620@nospam.com>
Ah, found the problem, newsreader wrapped the lines funny, and it saw the
"}" as a quote character and assumed the next (blank) line needed it as
well.  Off to file a bug. :-)
Rendering now, looks very good.
Jim
Date: 8 Dec 2005 01:37:14
Message: <4397d499@news.povray.org>
Roman Reiner spake:
> Hi there!
> here it is:
> [codeblock]
Wonderful! Short, sweet and sassy looking when done - just the way I like
it.
Thanks for posting the code!
Stefan Viljoen
Date: 8 Dec 2005 06:20:00
Message: <web.43981662badd071c8af771770@news.povray.org>
Thank you again for your comments!
When you intend to render modified versions (which of course you may) i'm
looking forward to see those!
Regards Roman
