POV-Ray : Newsgroups : povray.binaries.images : more Ringworld Server Time
15 Apr 2026 21:51:05 EDT (-0400)
  more Ringworld (Message 11 to 18 of 18)
Subject: Re: more Ringworld
Date: 3 Nov 2005 06:35:00
Message: <web.4369f4d9e9e218d9731f01d10@news.povray.org>
"Joanne Simpson" <cor### [at] onewhiteravencom> wrote:
> On the other hand, if the material were purely plastic (e.g. clay or metal),
> it _might_ deform like the picture, but I suspect the slope of the mountain
> would be much shallower, and the shape of the top more flared out.
It might, of course, have different responses under different regimes of
pressure and temperature, to say nothing of varying internal structures.
Unknown materials (especially fictional ones) behave however you want!
Bill
Message: <web.4369f5a4e9e218d9731f01d10@news.povray.org>
Alain <ele### [at] netscapenet> wrote:
> If the surface gravity is aroung 1G and the air pressure at ground level is similar
to ours, then
> about 90% of that mountain is in vacuum!
Yep! Cool, eh? Unlucky for those in the immediate vicinity, but good for the
Ringworld as a whole - at least the atmosphere won't drain away and spray
into space at 770m/s.
However, in that case I should probably remove more greenery from the lower
slopes (not that you can see clearly in that image...)
Bill
Date: 3 Nov 2005 08:30:39
Message: <436a10ff@news.povray.org>
Thomas de Groot wrote:
> "Joanne Simpson" <cor### [at] onewhiteravencom> schreef in bericht
> news:web.43683abfe9e218d9dc45bc820@news.povray.org...
> metal),
> mountain
> Now, that's interesting Joanne! From a different perspective (the
> measurements of Fist-of-God on the Ringworld map in Ringworld Engineers),
> I come to the conclusion that the mountain should have the shape of a
> shield volcano, i.e. very flat.
> Consider: The *base* starts almost at sea-level and gives it a radius of
> 150,000 miles. The slopes are gentle until an altitude of about 80 miles.
> The final *cone* has a radius of 25,000 miles and ends at 1000 miles
> altitude.
> If you draw or model this you get a very flat object, with only the very
> top perhaps flaring upwards. I even suspect that the mountain is so huge
> that it would hardly be *visible* from the ground! in contradiction with
> what Niven writes in fact...
> Bill, what do you think? Do you agree with my measurements?
> Thomas
There is one inherent flaw in this reasoning.
You keep referring to the mountain as a volcano but it isn't even though
Niven describes it as one. The one thing you could/should compare it to is
a bullet hole in sheet metal.
Ger
Date: 3 Nov 2005 09:07:14
Message: <436a1992@news.povray.org>
news:web.4369f3a9e9e218d9731f01d10@news.povray.org...
> I go with Niven! His description of the mountain is very brief. He says
that
> it is "roughly conical" - nobody would describe a shield volcano as
conical
> except in the strictest possible sense (this is prose, not a mathematical
> definition!). Natives for 100,000 miles around can see the mountain
> clearly, indicating a distinctive, dramatic look. Also, Louis refers to
the
> top as a 'crater' quite early on. I used the mental picture I formed when
I
> first read Ringworld (over 10 years ago) - which was a steep, conical
> volcano like Mt Ngauruhoe in north NZ. This doesn't of course preclude it
> flattening out towards the base - which mine does, to a small degree.
I agree, in the sense that it is consistent with the story, and the dramatic
effect is paramount.
> As to whether it's visible - well, now we have the higher-precision
> pov-engine we can find out. Make an atmospheric fog ~50 miles deep and put
> your version of the mountain in it. Then look at it!
I did. It is an extremely flat pancake!!!
I shall show an image later on.
Date: 3 Nov 2005 09:45:01
Message: <web.436a21c4e9e218d9731f01d10@news.povray.org>
He does describe it as conical, though, which would almost always be a
volcano if it were formed naturally.
Good point. However, it wouldn't be quite like a bullet hole because the
asteroid in question would probably have been a dense cloud of plasma by
the time it hit the ring floor (the characters observe a foamy impact
buffer covering the underside before they land). It would certainly have
looked like a volcano; the glowing remains of the asteroid would have
sprayed forth from the tip of mountain even as it formed. Not that the
locals would have had a chance to observe the cataclysm - the shockwave
(depending on the damping properties of scrith, of course ;) ) would
probably throw the topsoil miles into the air for millions of miles around.
If scrith was like metal, the whole Ring would probably vibrate like a bell
for millennia, shaking everything to oblivion on its surface... although it
wouldn't be - the builders would surely foresee such events and want their
wonder-material to be as powerful a damper as it is strong.
Thinking about it though... bullets deform quite drastically when they
strike metal - perhaps it wouldn't be so different. What we need here is a
high-speed film of a ball-bearing striking a sheet of toffee. Anybody? :)
Bill
Date: 3 Nov 2005 10:34:43
Message: <436a2e12@news.povray.org>
My point is that volcanos can not exist on/in the ring. You need magma and
tectonic activity for a volcano to form and both are not available on the
ring
> around. If scrith was like metal, the whole Ring would probably vibrate
> like a bell for millennia, shaking everything to oblivion on its
> surface... although it wouldn't be - the builders would surely foresee
> such events and want their wonder-material to be as powerful a damper as
> it is strong.
> Bill
If you can compare the ring material to anything known now it would, in my
mind, be something like high-strength aluminum. Somewhat soft and it can be
stretched quit a bit. Were it something like carbon fibre then the mountain
would not have formed because this does not deform but it shatters.
Ger
Date: 3 Nov 2005 12:21:35
Message: <436a471f$1@news.povray.org>
Plus, there are superconductors woven all through it, so the dispersal
of heat once the meteor got through the ablative shielding would be hard
to predict.
    Neither rocks nor slush nor salted rims
    shall keep us from our appointed rounds.
Date: 24 Nov 2005 14:30:01
Message: <web.43861411e9e218d974f3166b0@news.povray.org>
> Bill
Reminds me of a bit from a different Larry Niven book (Lucifer's Hammer, so
LN/Steven Barnes, for correct attribution) - where they're comparing the
comet to a cubic mile of hot fudge sundae.
And remember: Hot Fudge Sundae falls on a Tuesdae :->
(Sorry for being OT somewhat - but you just reminded me about that bit...)
