POV-Ray : Newsgroups : povray.binaries.images : Brig Niagara WIP (34k) Server Time
8 Apr 2026 21:08:49 EDT (-0400)
  Brig Niagara WIP (34k) (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Brig Niagara WIP (34k)
Date: 14 Oct 2005 04:11:54
Message: <434f684a@news.povray.org>
Very excellent, Tim! Like everybody else, I am always amazed at the details
and quality of your project. Must become obsessive, isn't it? ;-)
I have used, and adapted, your slopetexture / wornwood macro for my own
needs in my windows_room adaptation of Tim Nikias'. For what it's worth,
here it is for use and comment for everybody.
 Persistence of Vision Ray Tracer Scene Description File
 File name   : TM_SlopeTex.inc
 Version     : 3.6 / MegaPOV 1.0
 Description : a slope texture by Tim McMurdo
               (with some additions/changes by TdG)
 Date        : July 2005
 Author      : Tim McMurdo
 E-mail      : p.b.i.
 Copyright (C) 2005. All rights reserved.
/* ADDED/CHANGED FEATURES (by Thomas de Groot):
The following parameters have been added by me:
- Polish: which controls the specular of the paint finish (instead of
phong).
- WoodType: which controls the type of wood.
- WearSharp: which controls the transition between wood and paint.
- Woodscale: which controls the size of the underlying wood texture.
- Paintscale: which controls the size of the wood+paint texture. You should
first
              fix Paintscale before changing Woodscale, as the two are
linked together.
#macro
WornWood(RGB,Polish,WoodType,WearFlat,WearEdge,WearSharp,Norm,Woodscale,Pain
tscale,Rot,Tran)
        #declare Texture1 =
                            wood
                            turbulence <0.1, 0.5, 1>
                            octaves 5
                            lambda 3.25
                            scale <0.15, .5, 1>
                            rotate <5, 10, 5>
                            translate -x*2
                                color_map {
                                    [0.0 color RGB]
                                    [0.1 color RGB]
                                    [0.1 color 0.95*RGB]
                                    [0.9 color 0.95*RGB]
                                    [1.0 color RGB]
                        normal {
                          wood 0.2         // any pattern optionally
followed by an intensity value [0.5]
                          //turbulence <0.1, 0.5, 1>
                          turbulence <0.2, 0.2, 0.01>
                          octaves 5
                          lambda 3.25
                          //scale <0.15, 0.5, 0.2>
                          scale <0.5, 0.5, 0.9>
                          rotate <3, 2, 0>
                          translate -x*2
                          accuracy 0.02   // changes the scale for normal
calculation [0.02]
                          //scale 0.3       // any transformations
                        finish{
                                ambient 0
                                specular Polish // TdG
                                roughness 0.01
                                //phong 0.35
                                //phong_size 100
        #declare TWood1 =
          texture {WoodType scale Woodscale}
          texture {pigment{color rgbt <255, 155, 23,
0.999999*256>/256*0.25} }
        #declare TWood2 =
          texture {pigment{color rgbt <255, 155, 23,1.5*256>/256*0.45} }
        #declare PaintedWood1 =
            bozo
            //granite
            texture_map {
              [0          TWood1]
              [WearFlat      TWood2]
              [WearFlat+WearSharp Texture1]
              [1.0         Texture1]
            warp {turbulence 0.2}
            scale Paintscale
        #declare PaintedWood2 =
            bozo
            //granite
            texture_map {
              [0          TWood1]
              [WearEdge      TWood2]
              [WearEdge+WearSharp Texture1]
              [1.0         Texture1]
            scale Paintscale
         #declare TM_SlopeTex =
                slope { <0, -1, 0> }
                    texture_map{
                      [0 PaintedWood1]
                      //[0.1 PaintedWood1] // comment out for smooth
transition
                      [0.1 PaintedWood2]
                      //[0.4 PaintedWood2] // comment out for smooth
transition
                      [0.4 PaintedWood1]
                      [0.6 PaintedWood1]
                      //[0.6 PaintedWood2] // comment out for smooth
transition
                      [0.9 PaintedWood2 ]
                      [1.0 PaintedWood1]
                warp {turbulence 0.05}
                rotate Rot
                translate Tran
Date: 14 Oct 2005 07:45:01
Message: <web.434f997b55de2096395d82550@news.povray.org>
"Chris" <lho### [at] nwlinkcom> wrote:
> Tim,
> Great job. I like the wood texture too. According to a book I have at home
> (Steele's Elements of Naval Architecture), most of the bolts holding the
> planking to the frames would have been made of wood (oak was a favorite).
> These "treenails" are typically 1.5" to 2" in diameter and may have been
> rounded off where they poked through the interior of the hull. The reason
> for the wood was that iron was expensive and it was also very dangerous
> should a cannon ball knock the head off of the bolt and sent it flying into
> the crew.
> What a fantastic project. Keep up the good work.
> Chris Holtorf
Good morning Chris and thank you for your comments. I am familiar with tree
nails and thought they were the rule. I based the iron rivets on this photo
of the USS Constitution whish is of the sme time period.
http://www.ussconstitution.navy.mil/Bowchasers.htm
I may have to do a little more investigation on this issue. So far I have
not been able to find clear images of the interior planking on the Niagara.
Tim
Message: <web.434f99ec55de2096395d82550@news.povray.org>
Skip Talbot <Ski### [at] aolcom> wrote:
> Clever solution to your problem, and those textures look fantastic.
> Tim, the amount of work you are putting into this project is crazy, you
> know that right?  Its going to be a stunning masterpiece when its done
> though.  How are you planning on showing off the final result?
> Skip
Thanks for the encouragement Skip. I do know I am a bit crazy, but it is
very relaxing for me. I have a very stressful job and being able to lose
myself in this project has been wonderful.
I have in mind a web site dedicated to the project. I will post details in
the future, but I am currently working on written content.
Tim
Date: 14 Oct 2005 07:50:00
Message: <web.434f9a5955de2096395d82550@news.povray.org>
> Thomas
Thomas!
I am pleased to see somebody using the worn wood macro...better yet,
improving on it. I love the changes you have made. I am seriously
considering using your changes in my own work. Thank you!
Me? Obsessive? Sometimes!
Tim
Date: 14 Oct 2005 18:15:00
Message: <web.43502d7c55de2096d5e23d330@news.povray.org>
> > Thomas
> Thomas!
> Tim
Looks good. You must try the wood's finish parameters and light.
Thomas, can you post a samplet for this macro?..
Hasan.
Date: 15 Oct 2005 03:07:38
Message: <4350aaba$1@news.povray.org>
"Tim McMurdo" <jod### [at] wohrrcom> schreef in bericht
news:web.434f9a5955de2096395d82550@news.povray.org...
<grin>
You are welcome! Often one builds a macro for a specific task, and then
changes are needed for another one. So it keeps growing and mutating. Very
fascinating.
I am sure you can yet again improve further on the macro :-)
btw, I wondered about the Norm parameter that is there in your original
macro, but without any use, are/were you considering uv_mapping at some
stage?
Date: 15 Oct 2005 16:05:02
Message: <web.4351606455de2096395d82550@news.povray.org>
> fascinating.
> stage?
> Thomas
Thomas,
The Norm is reguired by the the slope function.
Date: 16 Oct 2005 02:59:44
Message: <4351fa60@news.povray.org>
news:web.4351606455de2096395d82550@news.povray.org...
I am not sure I understand this. Because in your original example Norm did
not seem to be used.
Do you mean that Norm is what in the docs is called  the <Direction> of
slope? That would make sense to me.
Date: 16 Oct 2005 08:38:02
Message: <435249aa@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> schreef in bericht
news:4351fa60@news.povray.org...
That works fine indeed....! I feel rather stupid :-(
The truth is that I didn't pay attention in the first place to what Norm was
for as it seemed not to be used in the macro. Didn't think further on a
little smarter level... :-)
Date: 17 Oct 2005 04:35:15
Message: <43536243@news.povray.org>
"Hasan3" <PRO### [at] Yahoocom> schreef in bericht
news:web.43502d7c55de2096d5e23d330@news.povray.org...
Here is an example of what the macro does.
Download 'SlopeTexTest.jpg' (54 KB)
Preview of image 'SlopeTexTest.jpg'
