POV-Ray : Newsgroups : povray.binaries.images : Tiling Problem Server Time
23 Feb 2026 06:29:44 EST (-0500)
  Tiling Problem (Message 1 to 2 of 2)
Subject: Tiling Problem
Date: 17 Sep 2005 15:35:01
Message: <web.432c6f78ebd7f4116fa503590@news.povray.org>
Hi all,
I am working on a macro to generate tiled floors (or walls) and stumbled on
a problem I had before. When using superellipsoids I get strange black
strips on certain tiles (in the example you can see them on the centered
tiles).
Does anyone have an idea what causes this and how I can get rid off it?
Here's the code:
camera
 location <0, 6, -20>
 look_at  <0, 0, 0>
 right x * image_width / image_height
global_settings
 ambient_light rgb <1, 1, 1>
#declare singleTile =
 difference
  superellipsoid
   <0.2, 0.2>
  box
       <-1.2, -1.6, -1.2> <1.2, 0.8, 1.2>
  translate <0, -0.8, 0>
  scale <0.5, 0.5, 0.5>
sky_sphere
 pigment
  gradient y
  color_map
   [0.0 rgb <1, 1, 1>]
   [0.2 rgb <0.8, 0.9, 1.0>]
   [0.5 rgb <0.6, 0.7, 1.0>]
   [0.8 rgb <0.8, 0.9, 1.0>]
   [1.0 rgb <1, 1, 1>]
light_source
  0 * x
  color rgb <1,1,1>
  translate <-20, 40, -20>
plane
 y, 0
 pigment
  rgb 1
#macro tiledFloor(tileWidth, tileDepth, tileSpace, xTiles, zTiles,
isCentered)
 #declare zPos = 0;
 #if (isCentered = 1)
  #declare xCenter = ((tileWidth + tileSpace) * xTiles) * -0.5;
  #declare zCenter = ((tileDepth + tileSpace) * zTiles) * -0.5;
 #else
  #declare xCenter = 0;
  #declare zCenter = 0;
 #while (zPos < (xTiles * (tileDepth + tileSpace)))
  #declare xPos = 0;
  #while (xPos < (xTiles * (tileWidth + tileSpace)))
   object
    singleTile
    pigment
     rgb <0.8, 0.9, 1.0>
    scale <tileWidth, 1, tileDepth>
    translate <xCenter + xPos, 0, zCenter + zPos>
   #declare xPos = xPos + (tileWidth + tileSpace);
  #declare zPos = zPos + (tileDepth + tileSpace);
tiledFloor(12, 12 , (3/8), 10, 10, 1)
Have a fine day, nUMBc
We don't stop playing because we get old; We get old, because we stop
playing!
Download 'tiles001.jpg' (112 KB)
Preview of image 'tiles001.jpg'
Subject: Re: Tiling Problem
Date: 18 Sep 2005 02:43:47
Message: <nHOa+CApmQLDFwqn@econym.demon.co.uk>
Wasn't it nUMBc who wrote:
>Hi all,
>tiles).
I could be wrong, but it might be related to this bit of the
superellipsoid documentation, even though your values aren't really what
I would call "very small".
    Very small values of e and n might cause problems with the root
    solver (the Sturmian root solver cannot be used).
You could make small changes to the values, <0.18, 0.2> seems to render
cleanly in this case, but the artefacts might possibly come back when
you move the camera.
Alternatively you could use the isosurface f_superellipsoid which uses a
different solver and doesn't seem to exhibit the problem.
In this particular case the isosurface superellipsoids render just as
fast as the CSG ones.
#include "functions.inc"
 isosurface {
  function { - f_superellipsoid(x,y,z,0.2,0.2)}
  contained_by {box {<-1,0.8,-1> <1,1,1>}}
  max_gradient 1
Mike Williams
Gentleman of Leisure
