POV-Ray : Newsgroups : povray.binaries.images : T_Stones ref charts Server Time
10 Apr 2026 16:11:33 EDT (-0400)
  T_Stones ref charts (Message 1 to 8 of 8)
Subject: T_Stones ref charts
Date: 11 Sep 2005 09:25:01
Message: <web.43242e97c626dadf77d3bc6c0@news.povray.org>
Here is a scene file that produces a couple of images containing all the
standard T_Stone textures from stones.inc on numbered superellipsoids. Run
it as a single image to get T_Stone1 to T_Stone44 in one file, or run it a
two or three frame animation to get T_Stone1 to T_Stone25 in frame 1,
T_Stone25 to T_Stone44 in frame 2. and T_Stone1 to T_Stone44 in frame 3.
I hope this is useful to someone. :)
// Persistence of Vision Ray Tracer Scene Description File
// File: Boxes.pov
// Vers: 3.5
// Desc: Show T_Stone textures on numbered superellipsoids in ZX plane
// Date: 24 Apr 2004
// Auth: PM 2Ring
//  -F +A0.5 +AM2 +R2
//  -D +A0.1 +AM2 +R2 +KFF3
global_settings {
  assumed_gamma  1.0
// T_Stone1 - T_Stone44
#include "stones.inc"
#declare MK=44;   //Number of complete stone textures defined in stones.inc
//Build a stone names array. We do this in an include file,
//since we can't manipulate identifiers directly
#declare FileName = "StonesArray0.inc";
#if(!file_exists(FileName))
  #debug concat("\n\nBuilding include file, ", FileName, "...\n")
  #fopen MyFile FileName write
  #write (MyFile, "#declare StonesArray = array[", str(MK,0,0), "]{\n  ")
  #declare Sep = array[2]{",\n  ", ", "}  //output separator sequences
  #declare K=1;
  #while (K<=MK)
    #write (MyFile, concat("T_Stone", str(K,0,0), Sep[!!mod(K,5)]))
    #declare K=K+1;
  #write (MyFile, "\n}\n")
  #fclose MyFile
#else
  #debug concat("\n\nInclude file, ", FileName, " already exists.\n")
//Load our stone names array
#include FileName
//Rounded box, with cutout in front face
#declare Scale = <3, 2, 1>;
#declare SScale = vlength(Scale)/sqrt(3);
#declare RBox =
difference{
  superellipsoid {
    <0.4, 0.4>
    scale Scale
  //Cutout
  superellipsoid {
    <0.1, 0.1>
    scale Scale - .5
    translate -1.25*z
#macro TextBox(Str)
union{
  object{RBox}
  text {
    ttf "timrom.ttf" Str .975, 0
    scale 3
    translate <-1.25, -1.125, -.975>
#macro BoxGrid(MJ, MI, K0)
union{
  #declare K=K0;
  #declare I=0;
  #while (I<MI)
    #declare J=0;
    #while (J<MJ)
      object{TextBox(str(K+1,2,0))
        texture{StonesArray[K] scale SScale}
        translate <2*J-MJ+1, 2*I-MI+1, 0> * (Scale * 1.15 * <1, -1.2, 1>)
      #declare J=J+1;
      #declare K=mod(K+1, MK);
    #declare I=I+1;
//Select stones based on frame number
#switch(frame_number)
  #case(1)
    #declare GX = 5;
    #declare GY = 5;
    #declare K0 = 0;
  #break
  #case(2)
    #declare GX = 5;
    #declare GY = 4;
    #declare K0 = 24;
  #break
  #else
    #declare GX = 7;
    #declare GY = 6;
    #declare K0 = 0;
  #break
BoxGrid(GX, GY, K0)
  //orthographic
  location  -10 * max(GX, GY) * z
  look_at   0
  right     x*image_width/image_height up y
  direction z
  angle 40
light_source {<-5, 15, -20>*20 rgb 1}
background{rgb .5}
Download 'stoneblocksa1s.jpg' (78 KB)
Preview of image 'stoneblocksa1s.jpg'
Subject: Re: T_Stones ref charts
Date: 11 Sep 2005 09:35:00
Message: <web.43243152891e529177d3bc6c0@news.povray.org>
And here is frame 2.
Download 'stoneblocksa2s.jpg' (78 KB)
Preview of image 'stoneblocksa2s.jpg'
Date: 11 Sep 2005 15:30:00
Message: <web.43248543891e52914d4af1dc0@news.povray.org>
Soaps! Lot's of them! In all flavours! ;-)
Really nice! Thank you!
Henrik Fisch
Date: 12 Sep 2005 01:14:40
Message: <43250ec0$1@news.povray.org>
I do like how the stones are specifically numbered.  The original
include demo scenes would definitely benefit from this.  I find myself
hunting through the array in the source trying to match up the stone
texture with the render.
Skip
Date: 12 Sep 2005 18:30:00
Message: <web.4326015a891e529193db03e80@news.povray.org>
They have something like this already in the scenesportfolio folder in your
install directory.  It does most all the obects, paterns, colors, finishes,
textures, shapes that are included.  Everything is sorted by it's include
file and  name.
Date: 14 Sep 2005 08:45:00
Message: <web.43281a92891e5291505e02d50@news.povray.org>
Glad you like them, Henrik. BTW, you're not the first person to say they
look like soaps. :)
Date: 14 Sep 2005 08:50:00
Message: <web.43281b8a891e5291505e02d50@news.povray.org>
And I'm sure you can guess that's what motivated me to create this scene,
Skip. I just got sick of matching up the array in the demo source with the
texture in the .inc files. OTOH, it's certainly instructive to browse
through the .inc files themselves.
Date: 14 Sep 2005 09:10:01
Message: <web.43282066891e5291505e02d50@news.povray.org>
> install directory.
Very true, Mienai, although I like the convenience of my simple image files.
The 'soap' shape displays the stone textures well, IMHO, and it's nice to
see how well the different stones work with text. Also, I did the first
versions of this scene before I discovered portfolio.
> file and  name.
Thanks for reminding me about portfolio, Mienai. I've just had another quick
look at it. It certainly looks quite comprehensive - Ingo has yet again
done an impressive job. It's also not as scary-looking as it was when I
first saw it. :)
I *was* in the process of convincing myself to run the whole portfolio on
this slow old beastie, and then POV 3.6 became available. Now, I'll
probably wait until the official POV 3.7 is out. Then I'll run it on my
fast machine at work and put the results onto my flash drive.
Then I'll have a portable portfolio of POV pieces. :)
