POV-Ray : Newsgroups : povray.binaries.images : Unclear images Server Time
23 Sep 2025 06:21:48 EDT (-0400)
  Unclear images (Message 1 to 10 of 10)
Subject: Unclear images
Date: 9 Sep 2005 09:25:01
Message: <web.43218afb8fc75ab5cc92659a0@news.povray.org>
I have created some PoV-Ray model which generated 2D diagrams for me based
on parameters that I supply. The diagrams use a lot of lines and text
objects. However, the output of the diagrams is quite unclear. I would like
to see sharp lines, and sharp text objects. Now I see text which is
something so very unclear that element of the characters are not shown. For
example +-signs sometimes miss their vertical line!
I tried changes in scene configuration for anti-alias settings, and jitter
off but to no avail. Is what I want not possible? Or what am I doing wrong?
Please help. I'm doing workarounds now by generating at a very high
resolution and then downsizing the result...
I have attached a sample diagram in which the described behaviour shows.
Lo van den Berg
lov### [at] gmailcom
Download 'test.jpg' (30 KB)
Preview of image 'test.jpg'
Subject: Re: Unclear images
Date: 9 Sep 2005 09:55:02
Message: <dfs43t$863$1@chho.imagico.de>
You need higher quality aa settings, try something like:
+a0.05 +am2 +r4
Also note lines much thinner than a pixel will inevitably appear in low
intensity.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 9 Sep 2005 14:58:35
Message: <4321db5b$1@news.povray.org>
Is the fuzz from jpeg compression or is it also present in the original
output?
Date: 9 Sep 2005 15:24:13
Message: <op.swun8w0s05glvk@localhost.localdomain>
Frankly pov-ray is far from ideal for what you are trying to do. You're
really working with vector data, so I'd look at some sort of PDF or SVG
oriented solution.
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Date: 11 Sep 2005 00:36:07
Message: <pdb_NOSPAM-D64E7B.14360411092005@news.povray.org>
Putting aside the perversity of using PovRay for this, I use it
reasonably often for diagrams where the programming language
allows precise effects to be created, for example the latest
diagrams for a paper are here
   http://astronomy.swin.edu.au/~pbourke/tmp/jjw/
all but "diagram" are using Pov.
I suspect you are having touble because the structure you are
trying to represent is around the same scale or smaller than a
pixel. Try thickening the geometry or rendering at higher resolution
possibly with higher antialiasing settings. If you are doing these
for publication then the higher resolution isn't such an issue since
the publishers will want that anyway.
ps: I suggest you don't use jpg for these, but then that may just
have been for posting. png or tiff would be better.
Paul Bourke
pdb_NOSPAMswin.edu.au
Date: 12 Sep 2005 08:40:00
Message: <web.4325769fa2b8d117cc92659a0@news.povray.org>
> oriented solution.
Hi Tyler,
I used PoV-Ray only because it has such a nice programmable coordinate
system. I don't know about other systems that have this feature.
Lo
Date: 13 Sep 2005 13:58:23
Message: <op.sw1yvrqe05glvk@localhost.localdomain>
On Mon, 12 Sep 2005 08:37:51 -0400, lovandenberg <lov### [at] gmailcom>
>> oriented solution.
> Hi Tyler,
> Lo
Any decent drawing library will really probably be easier to use than POV
for anything non-trivial. You might want to look at, say, ReportLab for
Python (PDF), or any SVG library for your language of choice. 2d != 3d,
and you are being poorly served by using the latter to generate the former.
Date: 16 Sep 2005 09:07:22
Message: <432ac38a$1@news.povray.org>
"lovandenberg" <lov### [at] gmailcom> wrote in message
news:web.43218afb8fc75ab5cc92659a0@news.povray.org...
> Hi,
> wrong?
How about turning OFF antialiasing completely, and turning off jitter too?
Date: 16 Sep 2005 10:05:02
Message: <web.432ad0dba2b8d117cc92659a0@news.povray.org>
> > Hi,
> > wrong?
Hi EagleSun,
turning OFF antialiasing and jitter gives even worse results, but that is to
be expected. I'm reasonably happy with the results now by using a very low
anti-aliasing threshold and more depth.
thanks for the suggestions,
Lo
Date: 16 Sep 2005 10:40:03
Message: <jruqv2-713.ln1@badulaque.unex.es>
Among other things, lovandenberg saw fit to write:
Try with something like MetaPost:
http://wiki.contextgarden.net/MetaFun
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
