POV-Ray : Newsgroups : povray.binaries.images : [Beta-test] Same transmit value, different results. Server Time
11 Apr 2026 01:54:02 EDT (-0400)
  [Beta-test] Same transmit value, different results. (Message 1 to 1 of 1)
Subject: [Beta-test] Same transmit value, different results.
Date: 21 May 2005 16:15:01
Message: <web.428f95e84516a8fe6a3607400@news.povray.org>
Hi all!
See message with same subject in p.b-t for explanations... Here's the
result, on the left with beta 5, on the right with official 3.6.1a. Source
also attached... in case i did something obviously stupid in there and both
versions just don't handle stupidity the same way  ;)
JYR
// Begin source...
// A Dice
global_settings {
    assumed_gamma 2.2
    max_trace_level 8
#declare Span = 82*y;
    location -7.2*z
    look_at -1.6*y
    rotate Span
light_source {<3, 4, -5> rgb 1 rotate Span}
// A dice with no black dots yet
#declare Scale = 1.375;
#declare Blank_Dice =
intersection {
    box      {-1, 1}
    sphere   {0, 1.6}
    cylinder {-x, x, 1 scale Scale}
    cylinder {-y, y, 1 scale Scale}
    cylinder {-z, z, 1 scale Scale}
    pigment  {rgb 1 transmit .4}
    finish  {diffuse .82 ambient .15}
// A single black dot
#declare Black_Dot =
sphere {
    -z, .15
    pigment {rgb .1}
    finish {diffuse .9 ambient .1 phong .35 phong_size 10}
// Create the dot patterns on each side of the dice
#declare Face_1 = object {Black_Dot}
#declare Face_2 =
union {
    object {Black_Dot translate < .5,  .5, 0>}
    object {Black_Dot translate <-.5, -.5, 0>}
#declare Face_3 =
union {
    object {Face_1}
    object {Face_2}
#declare Face_4 =
union {
    object {Face_2}
    object {Face_2 rotate 90*z}
#declare Face_5 =
union {
    object {Face_2}
    object {Face_3 rotate 90*z}
#declare Face_6 =
union {
    object {Face_4}
    object {Black_Dot translate  .5*x}
    object {Black_Dot translate -.5*x}
// Create the completed dice
#declare Dice =
difference {
    object {Blank_Dice}
    object {Face_1}
    object {Face_2 rotate -90*y}
    object {Face_3 rotate  90*x}
    object {Face_4 rotate -90*x}
    object {Face_5 rotate  90*y}
    object {Face_6 rotate 180*x}
// Set the dice on display
object {Dice rotate 45*y rotate 52*x}
// On a Reflective Plane
plane   {
    y, -1.6
    pigment {rgb 1}
    finish {reflection .95 diffuse .08 ambient .01}
// end source code
Download 'dices.jpg' (30 KB)
Preview of image 'dices.jpg'
