POV-Ray : Newsgroups : povray.binaries.images : Mosquee in progress Server Time
8 Nov 2024 06:25:34 EST (-0500)
  Mosquee in progress (Message 1 to 4 of 4)
Subject: Mosquee in progress
Date: 17 May 2005 04:05:02
Message: <web.4289a43ae0926a1b624d32510@news.povray.org>
Hi everybody,
Since my last post I made some trials to select better camera settings and
add some artifacts.
In version 4, I suppress the column in foreground,
In version 5 I follow one advice to render in vertical direction
These 2 versions are using 75 lights with fade power an no interaction with
media, plus an external parallel light (without fade power) interacting
with media. No media yet, except the 150 glowing candles that are made with
emitting media.
Version 6 is my favourite version for camera setting
And finally, version 7 is an attempt I made with scatteing media and an
older version of the building. I used the same lights as I used for 4 and
5, but it is definitively too slow (rougthly 2,5 days to render) and the
sample value should be increased. I think also that there are too many
visible beams, Do you have any idea to have better image and faster
rendering?
Thanks for comments,
Pascal.
Download 'mosquee.zip' (617 KB)
Subject: Re: Mosquee in progress
Date: 17 May 2005 08:33:59
Message: <4289e4b7@news.povray.org>
Pascal,
The fisheye lens leaves me all at sea ;)
It'd be great if you could persuade your camera to give non-curved
verticals. Even parallel verticals.
I'll leave the horizontals to your sensibilities.
DLM
"chaps" <cha### [at] yahoocom> wrote in message
news:web.4289a43ae0926a1b624d32510@news.povray.org...
> Hi everybody,
> add some artifacts.
> with
> with
> emitting media.
> rendering?
> Pascal.
Date: 17 May 2005 13:40:00
Message: <web.428a2b39afaae255624d32510@news.povray.org>
> Pascal,
> DLM
OK, that's how it look like without fish eye. Verticals are not parallel. I
gess I should use hortographic camera to get this result, but I'm not sure
I'll like it.
If you could see my home, you 'd know that I like curvy walls :o)
Pascal.
Download 'mosquee8.jpg' (126 KB)
Preview of image 'mosquee8.jpg'
Date: 18 May 2005 08:25:29
Message: <428b3439$1@news.povray.org>
news:web.428a2b39afaae255624d32510@news.povray.org...
>> Pascal,
>> DLM
> I
> I'll like it.
> Pascal.
Pascal
That seems better to me! And in defense of your curves, you've still got
plenty in the arches, the candelabra and so on.
Now what does this look like with the external light sources media and so
on? I'm sure the illusions of crossed and curved light beams will go away
and interact well with the foreground.
DLM
