POV-Ray : Newsgroups : povray.binaries.images : Blue Marble Server Time
26 Aug 2025 16:54:09 EDT (-0400)
  Blue Marble (Message 1 to 10 of 15)
Subject: Blue Marble
Date: 7 Apr 2005 13:20:01
Message: <web.42556b33aa9b658f3d6ca37a0@news.povray.org>
Here's one of my attempts to get a globe vaguely like NASA's Blue Marble
at http://earthobservatory.nasa.gov/Newsroom/BlueMarble/
Suggestions welcome!
Download 'earthi0.png' (144 KB)
Preview of image 'earthi0.png'
Subject: Re: Blue Marble
Date: 7 Apr 2005 13:30:00
Message: <web.42556d981db933923d6ca37a0@news.povray.org>
"PM 2Ring" <nomail@nomail> wrote:
This engraved glass globe was done using normals... and a little dispersion.
Download 'earthk1.png' (85 KB)
Preview of image 'earthk1.png'
Date: 7 Apr 2005 13:45:01
Message: <web.42556fe71db933923d6ca37a0@news.povray.org>
Here's another one in glass with dispersion, this time with photons & area
lights. I don't care if those streaks are artifacts, I think they add
character... :)
Download 'earthk5.png' (297 KB)
Preview of image 'earthk5.png'
Date: 7 Apr 2005 19:46:31
Message: <4255c657$1@news.povray.org>
PM 2Ring nous apporta ses lumieres en ce 2005-04-07 13:40:
> character... :)
I must agre with you ;)
Date: 8 Apr 2005 04:30:16
Message: <42564118$1@news.povray.org>
Very nice. Is it possible to get the source or a bigger version for
destop background?
Greetings,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
Date: 8 Apr 2005 11:23:16
Message: <4256a1e4@news.povray.org>
Very cool.  Inspired me to try it myself.  Lots of tricky settings that
really fight each other, but I finally got one I'm happy with.  Now I'm
going to spin it :-)
Thanks for the inspiration.  Keep it up!
> image
Download 'earth2.jpg' (35 KB)
Preview of image 'earth2.jpg'
Date: 8 Apr 2005 14:15:00
Message: <web.4256c88c1db9339299ddb8130@news.povray.org>
> destop background?
Thanks, Alain, Bonsai and Spock for your kind comments. I'll try tomorrow to
post the source, Bonsai. The problem is recreating the exact parameters,
because both of those glass globes were done with the same scene file...
I'm getting close, but I'm too tired, ATM.
In the meantime, here's a slightly larger one, using crackle.
#declare Shiny = finish{specular 1 roughness 3e-5}
#declare Reflective =
finish{
  Shiny
  //brilliance 3
  reflection {0.01, 1 fresnel on }
  ambient 0.1 diffuse 0.1
  conserve_energy
#declare TGlass =
texture{
  pigment{rgbf 1}
  finish{Reflective}
#declare TOcean =
texture{
  TGlass
#declare TLand =
texture{
  TGlass
  //normal{granite .1 scale  .025 bump_size 1}
  normal{crackle 1 scale  .025 bump_size 5}
#declare TPlanet =
  image_pattern{
    sys "EAlpha.bmp"
    map_type 1
    interpolate 2
  texture_map
    [.5 TOcean]
    [.5 TLand]
Download 'earthl1.png' (171 KB)
Preview of image 'earthl1.png'
Date: 10 Apr 2005 08:40:01
Message: <web.42591d411db93392ebf82b440@news.povray.org>
> destop background?
Ok, I've pretty-much reconstructed the scene file, although the photons are
not exactly the same. I think my area-light parameter AL needs to be
higher.
I only have a slow processor & 256M RAM here at home, so if someone would
like to render this at high AA 1024x768 and post it here, I would
appreciate it. I'm currently rendering a closeup version (comment out the *
1.5 in camera location).
// Persistence of Vision Ray Tracer Scene Description File
// File: EarthKA.pov
// Vers: 3.6
// Desc: Translucent globe of the Earth, 'engraved' using bump_map
//       Image file from NASA's Blue Marble page
// Date: 2004.11.23
// Auth: PM 2Ring
// +W1024 +H768 +A0.025 +AM2 +R4 -D
// -f -A0.5 +AM2 +R1
#version 3.6; //Uses photons, fresnel & conserve_energy: buggy in 3.5
#declare Radio = 1;
#declare Photons = 1;
#declare Area_Lights = 1;
global_settings {
  assumed_gamma #if(Radio) 1 #else .45 #end
  #if(Photons)
    #declare PhotonFile = "EarthKA.ph";
    photons{
      #if(file_exists(PhotonFile))
        load_file PhotonFile
      #else
        save_file PhotonFile
      count 180000 / 4
      autostop 0
  #if(Radio)
    radiosity {
      //pretrace_start 0.08
      pretrace_end   0.04
      count 180 // 250
      error_bound 1.15      //default 1.8
      low_error_factor 0.6
      adc_bailout 0.01
      always_sample off
      //normal on
  max_trace_level 50
// ---Camera & Lights----------------------
  location  <-0.25, .5, -5> * .89 * 1.5
  right     x*image_width/image_height up y
  direction 2*z
  look_at   0
light_source {
  <-8, 30, .75> * .125
  rgb 1
  #if(Area_Lights)
    #declare AL = 7; //21;
    #declare ASize = .2;
    area_light x*ASize, z*ASize, AL, AL
    adaptive 1 //3
    jitter
    circular
    orient
  photons {
    reflection on
    refraction on
    #if(Area_Lights) area_light #end
// ---Textures-----------------------------
finish{
  specular 1 roughness 1e-4
  //metallic
  reflection {0.01, 1 fresnel on}
  ambient 0 diffuse 0
  conserve_energy
#declare NLand =
normal{
  bump_map{
    jpeg "land_shallow_topo_2048.jpg"
    map_type 1
    interpolate 2
    bump_size 5
// ---Objects------------------------------
#declare Globe =
sphere {
  0, 1
  texture{
    pigment{rgbf 1}
    finish{Reflective}
    normal{NLand}
  interior{
    ior 1.5
    #if(1)
      dispersion 1.02
      dispersion_samples 5
      fade_color rgb<0,0,1>
      fade_distance  6
      fade_power 1001
    #if(!Photons)caustics .3 #end
 photons {
  target
  refraction on
  reflection on
  collect off
  //rotate y * 235      //Atlantic
  rotate y * -90        //Africa
  //rotate y * 62       //Australia
  rotate x * -6 // 22.5
#declare Rad = 10;
#declare Room =
union{
  sphere{0, Rad inverse }
  box{<-Rad, -2,-Rad>, <Rad, -1, Rad>}
  pigment{rgb .75}
  finish{ambient 0.05 diffuse .65}
//---Scene--------------------------------
object{Room}
object{Globe}
Download 'earthka7.jpg' (10 KB)
Preview of image 'earthka7.jpg'
Date: 12 Apr 2005 10:04:57
Message: <425bd588@news.povray.org>
All the spheres in this thread are great!
Where do you get/generate the spherical mapping bitmap file?
Mike
http://povray.tashcorp.net
Date: 12 Apr 2005 10:35:01
Message: <web.425bdb0e1db933923db4a54a0@news.povray.org>
Thankyou! But we still haven't replicated the Blue Marble image...
From NASA's Blue Marble page, mentioned in the opening post. There are all
sorts of fun maps there.
The one I've been using is
http://earthobservatory.nasa.gov/Newsroom/BlueMarble/Images/land_shallow_topo_2048.jpg
 (230 KB). There's also a 8192 by 4096 pixels (26.5 MB) TIFF version, if
you're really keen. :)
Here's a refractive translucent one, where the land & ocean have the same
transparency, unlike the first globe I posted.
Download 'earthe1.jpg' (34 KB)
Preview of image 'earthe1.jpg'
