I am not satisfied by the view point.
I would like to keep a large angle, what is your opinion?
(Mosaic done with arabesque, Carpet extract from a picture, all CSG)
Pascal.
Download 'mosquee.jpg' (400 KB)
Preview of image 'mosquee.jpg'
> Pascal.
Love the colours, but I'm a bit confused about the little windows
in the domes. If they are looking out onto a (very) blue sky
then I'd expect to see the outsides of the two more distant
domes through the widows of the central one. otoh if they are meant
to be false then they're rather bright, though that might be
your intention.
More realistic textures on the flat areas would help to blend the
mosaics into the picture, of course you may only intend the plain
textures as placeholders while you're working on the CSG.
As for the viewpoint, I think it comes back to those windows not
revealing what you'd expect. I like the wide angle.
Bill Hails
http://thyme.homelinux.net/
> in the domes.
You are right, if I put the camera higher, these domes appear. I knew it,
but I thought it was not so obvious. I will try to fix this. By the way I
discovered how tricky is this structure, last time I visited such a
mosquee, I didn't notice it, I was only impressed by the space feeling.
For the moment there is no work on texture, I use only some pigment map, for
test, and some plain colors to retrieve various elements of CSG.
:op
> Bill Hails
Thank you for your comments,
Pascal
