POV-Ray : Newsgroups : povray.binaries.images : Tree trunk Server Time
26 Aug 2025 23:01:43 EDT (-0400)
  Tree trunk (Message 1 to 4 of 4)
Subject: Tree trunk
Date: 10 Mar 2005 05:20:01
Message: <web.42301e81754917e6f6440bf00@news.povray.org>
This is my first attempt with making something nice with isosurfaces (and
first image post here). I think it looks pretty good. :D
I'm planning on making a water type faucet and sticking it in the side with
some liquid dripping out. Weee!
#include "textures.inc"
#declare debugin = false;
global_settings{
  max_trace_level 5
  #if (debugin = false)
  radiosity {
      pretrace_start 0.08
      pretrace_end   0.04
      count 20
      nearest_count 5
      error_bound 0.2
      recursion_limit 1
      low_error_factor 0.5
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness 1
      adc_bailout 0.02
background{White}
  location<1, 1.6,-2.5> look_at<0,0,0> //topish view
light_source {
  <-200,320,15>, rgb 0.7 //adaptive 1
union{
  difference{
    isosurface { //whole trunk and bark
      function{-f_cylindrical(x,y,z)-f_agate(x*5,y*1.43,z*5)/8 + 0.2}
      threshold 0
      contained_by{box {<-1,-1,-1>,<1,1,1>}}
      max_gradient 3
      pigment {  //color bark depending on radius
        wood
        color_map{
          //dark ring color divided by 2.3
          [0.0 color rgb 2*<0.5019, 0.25, 0>/2.3]
          //dark ring color divided by 3.5
          [1.0 color rgb 2*<0.5019, 0.2, 0>/3.5]
          //test colors to show gradient
          //[0.0 color rgb<1, 0, 0>] //red
          //[1.0 color rgb<0, 0, 1>] //blue
        scale 0.08
        rotate x*90
        rotate y*30
        turbulence 0.06
        phase pi/2  //adjust so highest are dark
      finish{reflection 0.001 diffuse 0.4 crand .3 ambient 0}
    isosurface { //cut out trunk
      function{-f_cylindrical(x,y,z)-f_agate(x/.2,y/.7,z/.2)/14+.26}
      threshold 0
      contained_by{box {<-1,-1.1,-1>,<1,1.1,1>}}
      max_gradient 2
      pigment{Tan} //give cut mark tan color in hopes of sap appearence
  isosurface {  //add trunk back in with different texture
    threshold 0
    contained_by{box {<-1,-1,-1>,<1,1.1,1>}}
    max_gradient 2
      wood
      color_map{
        [0.0 color rgb 2*<0.5019, 0.25, 0>]
        [0.4 color rgb 2*<0.5019, 0.25, 0>]
        [1.0 color rgb 2*<0.5019, 0.2, 0>/2]
      scale 0.08
      rotate x*90
      rotate y*30
      turbulence 0.04
    finish{diffuse 0.4 crand .2 ambient .1}
    normal{
      average
      normal_map{
        [0.2 wrinkles 1 scale 1 scale y*2]
        [1.4 granite 1 scale 0.08 scale y*0.45]
Download 'log_single.jpg' (60 KB)
Preview of image 'log_single.jpg'
Subject: Re: Tree trunk
Date: 10 Mar 2005 05:43:53
Message: <423024e9$1@news.povray.org>
A bit dark but really very nice!
Paolo
with
Date: 10 Mar 2005 10:50:00
Message: <web.42306b6aea433198a3fcf12a0@news.povray.org>
The shape of the trunk is very nice. The texture isn't great, though, and
kind of ruins the effect. The color is too orange, and there are not enough
rings: only 11 indicates that this tree was eleven years old when it died.
This doesn't match with the very rough/rugged looking bark on the trunk.
 - dan B hentschel
Date: 14 Mar 2005 20:45:00
Message: <web.42363e05ea433198b9c7e1030@news.povray.org>
>  - dan B hentschel
Thanks dan, you told it like it was. I appriciate that. :)
You're right about the rings. I was going for redwood bark, so, I should
probably add a couple thousand more :P
Recalibrating my lcd made the brightness and color problems obviouse. Looks
much better now.
Thanks,
brandon
