output data (*.pov). unfortunately, the orbitals look more than a polygon
than orbitals, as you can see in the attached picture...does anybody know
how to solve this problem? thanks!
Topper nous apporta ses lumieres en ce 2005-02-14 06:44:
> output data (*.pov). unfortunately, the orbitals look more than a polygon> than orbitals, as you can see in the attached picture...does anybody know> how to solve this problem? thanks!> > > ------------------------------------------------------------------------>
Those fscing are caused by the meshes used, to large/few triangles. Can you set the
number of steps
or presision of the generated meshes?
Hi Topper,
it looks like the resolution of the mesh of Your orbitals isn't high enough
to get a smooth result. Unfortunately I'm not familiar with MOLDEN. Can You
increase the triangle in the grid to get a better result. Maybe You can use
Hyperchem, Spartan or another software to export the structure including
the orbitals with a higher resolution.
Shu.
