POV-Ray : Newsgroups : povray.binaries.images : The De Groot Islands Server Time
21 Mar 2026 17:18:48 EDT (-0400)
  The De Groot Islands (Message 1 to 10 of 11)
Subject: The De Groot Islands
Date: 29 Jan 2005 22:25:00
Message: <web.41fc528b2bf4362a5a9431fb0@news.povray.org>
A tribute to Thomas and his Geomorph macro:
These islands were created using Geomorph 2.2 in a random while loop (I'll
post the code).
--Ralph
Download 'islandgroup.jpg' (160 KB)
Preview of image 'islandgroup.jpg'
Subject: Re: The De Groot Islands
Date: 30 Jan 2005 03:02:25
Message: <41fc9491@news.povray.org>
"author" <ral### [at] abookscom> schreef in bericht
news:web.41fc528b2bf4362a5a9431fb0@news.povray.org...
> post the code).
> --Ralph
Oh, that's an excellent idea! Just watch out for the bounding boxes that are
visible on some of the islands. Just increase the Xsize and Zsize of the
isosurface and all will be well.
I shall plant my flag on the highest island and claim possession of the
archipelago!!  ;-)
Date: 30 Jan 2005 09:10:00
Message: <web.41fcea9abadf62355a9431fb0@news.povray.org>
> > post the code).
> > --Ralph
> archipelago!!  ;-)
> Thomas
Thanks for the tip on bounding boxes, Thomas. I was wondering about that. I
can probably fix it for this by decreasing the range of the random function
that generates the X and Y sizes.
So, now that you have the islands, write a casino-generating macro and you
will attract plenty of wealthy tourists to throw dollars and euros at you.
--Ralph
Date: 30 Jan 2005 09:20:29
Message: <41fced2d@news.povray.org>
news:web.41fcea9abadf62355a9431fb0@news.povray.org...
I
function
> --Ralph
Right, pardner! getting rich, shall we? Wallowing in hard cash from all
those poor naive tourists that shipwreck on our islands!!  :-))
(Morgan, the pirate, was my great-great-great grandfather...)
Date: 30 Jan 2005 12:15:00
Message: <web.41fd14e9badf62355a9431fb0@news.povray.org>
> Thomas
He is? I'll have to include a plank to exit the islands from then. ;-)
Here's a second go at the islands, with somewhat better camera angle and
lower X and Y parameters.
--Ralph
Download 'islandgroup.jpg' (106 KB)
Date: 31 Jan 2005 03:22:01
Message: <41fdeaa9@news.povray.org>
news:web.41fd14e9badf62355a9431fb0@news.povray.org...
Yes, this looks good. Still some bounding boxes though... hmm... you can
also decrease Diameter. See what happens. Depending on the Isolator choice
that has to be more or less drastic.
But the topography of the islands are very good.
Ah! You could try the ocean surface from Appendix 2! The waves will be a
little more 'natural' (?) looking...
Date: 31 Jan 2005 22:50:01
Message: <web.41fefba6badf62355a9431fb0@news.povray.org>
> Thomas
Okay... here's one with the ocean surface you suggested.
--Ralph
Download 'islandgroup.jpg' (214 KB)
Date: 1 Feb 2005 03:00:58
Message: <41ff373a$1@news.povray.org>
news:web.41fefba6badf62355a9431fb0@news.povray.org...
> --Ralph
Ralph!
This looks great. Impressive, isn't it? I like the texture of the islands,
by the way, as well as the sky. It's been a long time ago since I last used
Chris Colefax's macro. I shall have to 're-discover' it.
Good work!
Subject: Re: The De Groot Islands: Foaming seas
Date: 1 Feb 2005 03:08:24
Message: <41ff38f8@news.povray.org>
This image brings me to a question to the community at large:
Marc Jacquier (and others, I believe) have worked on the production of foam
in the shallow parts of seas. That was based on image-based height_field
functions, if I remember correctly, and it worked very well. I tried to use
the procedure with isosurfaces, but the only thing I got was foam over the
whole sea surface, not only in the shallows. What did I do wrong? Or how
should the expected results be obtained? Any suggestion is most welcome!!
Thanks indeed!
Date: 1 Feb 2005 04:56:15
Message: <41ff523f@news.povray.org>
news:41ff38f8@news.povray.org...
foam
use
> Thanks indeed!
> Thomas
Hi Thomas,
I'm not quite sure but I believe conversion from image to function with
.gray takes rgb but  filter and transmit as well.
And transmit is at 1 out of the image  zone to make it transparent.
What I do is crappy : invert the image in an image editor  then  multiply
the function by a negative factor in the texturing process.
But here you don't use bitmaps, do you?
You are using  functions. So the function factor in the texturing process
should be positive.
For my POVComp entry, I had only to evaluate distance from a central point
(I won't spoil more ;-)
I took the lazy path using cylindrical pattern but you can change for any
function.
Here is  my sea material code ( media set for 1 pov unit= 1 meter)
#declare T_eau=texture // free (without foam) sea texture
         pigment
            color rgbt 1
     finish
            ambient 0
            specular 1
            roughness 0.0001
            conserve_energy
            reflection
               0.0 ,3
               fresnel  on
             falloff 1
              exponent 1
               metallic 0.0
#declare T_mousse=texture  // foam texture
        {pigment{
                color rgb 1 transmit .3
         finish{ambient 0
                diffuse 1
normal{bumps 0.1 scale 0.2}
#declare P_img=
   pigment
     cylindrical
      color_map
         [0.0     rgb 1 ]
         [1  rgb 0 ]
warp   { turbulence .02 lambda 7 }
      scale 200
    // rotate 90.0 * x // decomment for Moray coordinate system
 poly_wave 0.5
#declare F_img=function{pigment {P_img}}
#declare f_crackle_moi = function {pattern {crackle  warp {turbulence 0.65
lambda 3} scale <1,1,2>*2}} //turb 0.7
#declare F_var_crackle=function{min(1, f_crackle_moi(x, y,
z)*max(0,(F_img(x, y, z).gray)*40))}
#declare M_Iso_Sea =
   material
   {  texture{
    function{F_var_crackle(x,y,z)}
    texture_map{
     [.35 T_mousse] //.4
     [.85 T_eau] //.5
      interior
         ior 1.333
         caustics 2.0
         media
            samples 1,1
            absorption rgb <1.0, 0.1, 0.18>*2
            scattering
               3 ,  rgb <1,1,0.9>*.15
               extinction 1
