POV-Ray : Newsgroups : povray.binaries.images : The De Groot Islands Server Time
13 Apr 2026 20:57:24 EDT (-0400)
  The De Groot Islands (Message 11 to 11 of 11)
Subject: Re: The De Groot Islands: Foaming seas
Date: 1 Feb 2005 08:49:10
Message: <41ff88d6@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> schreef in bericht
news:41ff523f@news.povray.org...
> Hi Thomas,
> I'm not quite sure but I believe conversion from image to function with
> .gray takes rgb but  filter and transmit as well.
> And transmit is at 1 out of the image  zone to make it transparent.
> What I do is crappy : invert the image in an image editor  then  multiply
> the function by a negative factor in the texturing process.
> But here you don't use bitmaps, do you?
> You are using  functions. So the function factor in the texturing process
> should be positive.
> For my POVComp entry, I had only to evaluate distance from a central point
> (I won't spoil more ;-)
> I took the lazy path using cylindrical pattern but you can change for any
> function.
Hello Marc,
This sounds very promising! I shall look more deeply into your sea code
(without drowning, I hope). I am working on a scene where foam should play a
role. I'll be back, with questions, or (I hope) a satisfying image!
Thanks a lot!
Waiting for the POVComp results! I did not send in myself, but I am curious
to see what was produced.
