POV-Ray : Newsgroups : povray.binaries.images : Media Woes? Server Time
18 Feb 2025 17:17:13 EST (-0500)
  Media Woes? (Message 1 to 7 of 7)
Subject: Media Woes?
Date: 20 Jan 2005 13:55:01
Message: <web.41effd8fb0cdf922acb32c570@news.povray.org>
I thought a nice experiment would be to create a telescope to apply to the
Niagara images. When I did, the reults were surprising. I do not understand
Media enough to know why the media cirrus clods change the light in the
lense. Can anybody help? The only thing changed between renderings is the
cirrus clouds.
Here is the lens code:
#declare R = .00007 ;
#declare Lens =
        union{
                intersection{
                        sphere{<0,0,0>, R translate<0,0,-R/1.0071>}
                        sphere{<0,0,0>, R translate<0,0,R/1.0071>}
                        cylinder{<0,0,.005>,<0,0,-.005>,0.00002}
                        texture{pigment{rgbt<1,1,1,1>} }
                        interior{
                                ior 1.52
                difference{
                        cylinder{<0,0,.0000005>,<0,0,-.0000005>,0.0000083}
                        cylinder{<0,0,.0000006>,<0,0,-.0000006>,0.00000785}
                        texture{T_Brass_3B}
Here is the cirrus cloud code straight out of Jamies Tierra inc file.
  Persistence of Vision Ray Tracer Scene Description File
  Tierra v1.0 - Cirrus shell include
  Jaime Vives Piqueres, Apr-May-Jun 2004.
#if (use_cirrus)
// basic cloud pigment maped spherically
#declare d_base=
density{
   Cirrus_Density
   color_map{
     [0.00 rgb 0]
     [(1-Cirrus_Level) rgb 0]
     [(1-Cirrus_Level)+Cirrus_Border rgb 1]
     [1.00 rgb 1]
   warp{spherical}
   // changing default orientation to match scene orientation
   rotate 90*x
   rotate 360*rand(r_clouds)*z
// density with a tiny layer of clouds
#declare d_clouds=
density{
 spherical
 density_map{
  [0.0 d_base]
  [Cirrus_Flatness d_base]
  [Cirrus_Flatness rgb 0]
  [1.0 rgb 0]
// shell sphere with media cirrus
difference{
 sphere{0,1}
 sphere{0,1-Cirrus_Flatness}
 hollow
 texture{pigment{rgbt 1}}
 interior{
  media{
   intervals Clouds_Intervals
   absorption .04*5
   scattering{1,.04}
   density{d_clouds}
 // scale somewhat like earth in km
 scale 6800
 translate (-6800+Cirrus_Height)*y
Thanks for your help,
Tim
Download 'without-clouds.jpg' (125 KB)
Preview of image 'without-clouds.jpg'
Subject: Re: Media Woes?
Date: 20 Jan 2005 14:10:01
Message: <web.41f0014e7efaf3facb32c570@news.povray.org>
Here is the second image....can anybody tell me how to post 2 images in a
single post?
Tim
Download 'with-clouds.jpg' (227 KB)
Preview of image 'with-clouds.jpg'
Date: 20 Jan 2005 14:34:38
Message: <41f007ce$1@news.povray.org>
Are you sure that max_trace_level is high enough to pass through lenses and
clouds?
"Tim Nikias v2.0"
Date: 20 Jan 2005 20:40:01
Message: <web.41f05cc77efaf3f6e93bf990@news.povray.org>
> clouds?
> "Tim Nikias v2.0"
> Homepage: <http://www.nolights.de>
Tim, it was set at 34, but I tried several settings up to 255 with no change
in the image. Anything else I should check?
Date: 20 Jan 2005 20:43:23
Message: <41f05e3b$1@news.povray.org>
Tim McMurdo nous apporta ses lumieres en ce 2005-01-20 14:06:
> single post?
> Tim
Just attach the first image, then attach the second. No change since the Netscape 3
days.
Download 'pov logo chrome.png' (7 KB) Download 'pov logo.png' (8 KB)
Preview of image 'pov logo chrome.png'
Preview of image 'pov logo.png'
Date: 20 Jan 2005 21:11:23
Message: <41f064cb@news.povray.org>
Your lens is very thin. After a ray hits a transparent surface, I believe it
travels a slight distance ahead before it resumes testing for surfaces, to
avoid reintersecting the same surface. It's possible that this little jump
is longer than the depth of the lens, causing the ray to think it's still
inside the lens. This could mess up media. I also notice that your sky looks
different within the lens even in the first image. I'm not sure why this
would cause the lens in the second image to appear *darker*, but this may be
to blame in some non-obvious way. (This problem, if it is a problem, would
also cause your lens refractions to be incorrect.)
Try making your lens much larger and just moving it farther away to
compensate.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Jan 2005 01:28:01
Message: <41f0a0f1@news.povray.org>
news:web.41f05cc77efaf3f6e93bf990@news.povray.org...
change
Maybe it's silly but it could be worth trying your lens hollow.
Marc
