ok, not sure what to put for subject... it's just our home planet... I think
I'm getting closer to the final that I want....
btw... I found a whole sleu of science fiction planets, and all of their
cloud maps are JPEG, and it seems like a lot of work to convert them to
PNG, invent their alpha clouds and merge them into the cloud image. Does
anyone know a work-around that I may use the original JPEG clouds, having
transparency in the cloudless parts to see the land surface, without having
to convert them?
Download 'earth_2005-01-10.png' (522 KB)
Preview of image 'earth_2005-01-10.png'
news:web.41e42180830ae0179011d8b10@news.povray.org...
think
having
> to convert them?
Nice!!
to use jpg clouds with transparency, you could try with image_pattern (code
not tested, I'm running a 10 days render)
pigment
image_pattern
jpeg "your_image.jpg"
pigment_map
[0.0 color rgbt 1 ]
[1.0 color rgb 1 ]
HTH
regards
Marc
> pigment
> image_pattern
> pigment_map
> [0.0 color rgbt 1 ]
> [1.0 color rgb 1 ]
Thanks for this tip... I'll try it and let you know how it goes...
VERY nice...
Have you tried adding in the city lights on the nightside?
Rarius
"EagleSun" <nomail@nomail> wrote in message
> think
> having
> to convert them?
I apologize for a late response.... (See below).
> think
> having
> > to convert them?
> Nice!!
> pigment
> image_pattern
> pigment_map
> [0.0 color rgbt 1 ]
> [1.0 color rgb 1 ]
> HTH
> regards
> Marc
Hi, Thanks for this tip! Although I was hoping to avoid this paleted
situation, for now it seems like the way to go. I don't know of any
multi-colored cloud situations on any planet... and even looking at planet
Jupiter, multicolored, are really multi-layered, and applying a different
layer with a different color scheme should work (I think).
And...
> Rarius
I'm still working on the planet, and I do plan to address that issue, as
well as reflective water....
Ron
