POV-Ray : Newsgroups : povray.binaries.images : Earth (from EagleSun) Server Time
15 Aug 2025 07:08:45 EDT (-0400)
  Earth (from EagleSun) (Message 1 to 5 of 5)
Subject: Earth (from EagleSun)
Date: 11 Jan 2005 14:05:01
Message: <web.41e42180830ae0179011d8b10@news.povray.org>
ok, not sure what to put for subject... it's just our home planet... I think
I'm getting closer to the final that I want....
btw... I found a whole sleu of science fiction planets, and all of their
cloud maps are JPEG, and it seems like a lot of work to convert them to
PNG, invent their alpha clouds and merge them into the cloud image.  Does
anyone know a work-around that I may use the original JPEG clouds, having
transparency in the cloudless parts to see the land surface, without having
to convert them?
Download 'earth_2005-01-10.png' (522 KB)
Preview of image 'earth_2005-01-10.png'
Subject: Re: Earth (from EagleSun)
Date: 11 Jan 2005 14:27:58
Message: <41e428be$1@news.povray.org>
news:web.41e42180830ae0179011d8b10@news.povray.org...
think
having
> to convert them?
Nice!!
 to use jpg clouds with transparency, you could try with image_pattern (code
not tested, I'm running a 10 days render)
   pigment
      image_pattern
            jpeg   "your_image.jpg"
      pigment_map
         [0.0               color rgbt 1  ]
         [1.0               color rgb 1         ]
HTH
regards
Marc
Date: 11 Jan 2005 21:40:00
Message: <web.41e48df6e93c6b65b434a8a0@news.povray.org>
>    pigment
>       image_pattern
>       pigment_map
>          [0.0               color rgbt 1  ]
>          [1.0               color rgb 1         ]
Thanks for this tip... I'll try it and let you know how it goes...
Date: 13 Jan 2005 09:14:19
Message: <41e6823b$1@news.povray.org>
VERY nice...
Have you tried adding in the city lights on the nightside?
Rarius
"EagleSun" <nomail@nomail> wrote in message
> think
> having
> to convert them?
Date: 14 Jan 2005 17:25:00
Message: <web.41e846a9e93c6b69011d8b10@news.povray.org>
I apologize for a late response.... (See below).
> think
> having
> > to convert them?
> Nice!!
>    pigment
>       image_pattern
>       pigment_map
>          [0.0               color rgbt 1  ]
>          [1.0               color rgb 1         ]
> HTH
> regards
> Marc
Hi, Thanks for this tip!  Although I was hoping to avoid this paleted
situation, for now it seems like the way to go.  I don't know of any
multi-colored cloud situations on any planet... and even looking at planet
Jupiter, multicolored, are really multi-layered, and applying a different
layer with a different color scheme should work (I think).
And...
> Rarius
I'm still working on the planet, and I do plan to address that issue, as
well as reflective water....
Ron
