POV-Ray : Newsgroups : povray.binaries.images : Architectural visualisation Server Time
17 Nov 2024 04:16:33 EST (-0500)
  Architectural visualisation (Message 1 to 10 of 20)
Subject: Architectural visualisation
Date: 5 Jan 2005 08:45:00
Message: <web.41dbeeffcabc0cadb0aac12c0@news.povray.org>
Trees are generated with "meshtree" macro by Paul T. Dawson. Car comes from
3dcafe.com and the building is modelled with Autocad. I've used Poseray to
translate all objects to Povray. Any suggestions?
Przemek
Download 'np01.jpg' (152 KB)
Preview of image 'np01.jpg'
Subject: Re: Architectural visualisation
Date: 5 Jan 2005 08:57:19
Message: <41dbf23f@news.povray.org>
news:web.41dbeeffcabc0cadb0aac12c0@news.povray.org...
from
> Przemek
Nice!
Who is working on sunday though?
Only one car on the park....
Marc
Date: 5 Jan 2005 11:10:00
Message: <web.41dc103f7fd832bfb0aac12c0@news.povray.org>
> Marc
The real reason why there are only two cars (second one not visible here) is
that I was unable to change the color for each car. It would look strange
if the car park was full of blue cars only. Models exported from Poseray
have only one big mesh with internal by-triangle texturing. So it is
impossible to define separate texture for each copy of the object unless
you parse the file many times (it takes too much time for me).
Przemek
Date: 5 Jan 2005 11:48:23
Message: <41dc1a57$1@news.povray.org>
>>Marc
> Przemek
I'm thinking you could import the car with PoseRay then in each of the
include files for each of the cars, add a #include  to the top of the
file to bring in the materials for each indv. car...
Just a thought.
~Mike
Date: 5 Jan 2005 11:48:42
Message: <41dc1a6a$1@news.povray.org>
"Przemek Loesch" <nomail@nomail> wrote in message
news:web.41dc103f7fd832bfb0aac12c0@news.povray.org...
> is
> Przemek
Yeah, I discovered this last night. It can be dealt with, but when you're in
that deadline 'crunch' the last thing you want to do is become a
data-editor.
This is the type of work that there is a large calling for, Przemek.
Especially, if you can gain a little more photorealism out of it.
Did you use straight AutoCAD, or Architectural Desktop? AD made me lazy
(ha!).
- Grim
Date: 5 Jan 2005 12:15:00
Message: <web.41dc1ef27fd832bfb0aac12c0@news.povray.org>
> Just a thought.
> ~Mike
Yes, it will work in this way but this solution has two disadvantages:
1. You have to parse the file one more time for each object and this is time
consuming when the model is large.
2. Each copy of the object has to be declared with unique name and requires
new memory. When the number of copies is large it is a problem.
Przemek
Date: 5 Jan 2005 12:35:01
Message: <web.41dc24717fd832bfb0aac12c0@news.povray.org>
> (ha!).
> - Grim
Straight Autocad - the good old 2002. I haven't been working with any
version of ADT so far. Maybe it is high time to give it a try - the new ADT
2005 looks very interesting, except its price of course ;-) BTW - from your
own experience - is it much easier and/or faster to make a coplete
documentation of the building with ADT? Can it produce from 3d-model ready
elevations and sections with dimensions, windows, doors and other symbols
automatically or you have to do it by hand?
Przemek
Date: 5 Jan 2005 12:50:01
Message: <web.41dc28437fd832bf46d22db00@news.povray.org>
In my Architecture class, we had contests to see how quickly we could get
Autocad to crash. Good times.
It looks good, and the building looks great, but I agree that it would be
nice to make it look more realistic.
Date: 5 Jan 2005 13:07:14
Message: <41dc2cd2@news.povray.org>
is
What you could try is to remove all texture definitions which would paint
blue on the triangles, an easy "Replace..." should suffice. Then, declare
the object once. If you now place it via object{Car}, you can put a texture
inside the object{} and it should get applied to all untextured objects.
This is more or less guesswork though, so it might have some side-effects.
But if it works, you can place several cars with different colors without
having to parse several large meshes.
"Tim Nikias v2.0"
Date: 5 Jan 2005 13:10:40
Message: <41dc2da0@news.povray.org>
> Any suggestions?
Like it very much, though there's a very empty parking lot... Posted a
suggestion along the thread with the car-issue.
Another addition would be to use less clean textures. E.g. the red could be
a brick-pattern, or at least get some small bumps for lighting. The garage
could look a little dirty, and the glass windows should be less blue, and
more reflecting. Also remember to use conserve_energy to make the
reflection-transparency-combo more realistic. Maybe making the windows
darker and no transparency would help as well, you'd have to experiment. It
looks like the building is very empty (which it is, coming from AutoCAD),
dark windows and reflectivity would hide that.
"Tim Nikias v2.0"
