How do I get corrugated roofing to work in this image? I can get the texture
effect to work using normals but the roof does not corrugate
Download 'platform.jpg' (24 KB)
Preview of image 'platform.jpg'
I'm not sure that this is exactly what you are after, but can you use a
height field and an internal bitmap?
Here is an example:
location <0, 0, -200>
look_at <0, 0, 0>
rotate <45, -45, 0>
light_source {
<-2000, 4000, -3000>
color rgb 2
height_field {
function 400, 400 {
pattern {
marble
turbulence .075
scale .25
translate <-.5, 0, -.5>
scale <100, 10, 100>
color rgb .5
finish {
specular .5
roughness .005
reflection { 1, 1 }
sphere {
<0, 40, 0>
20
color rgb <.75, 0, 0>
finish {
specular 1
roughness .005
reflection .25
Not exactly perfect, but it is something to work from.
If only a normal is used you can only see it as light/shadow changes on an
otherwise flat surface. Faster to render. Example:
normal {function {abs(x)} sine_wave scale 0.1}
Best way would be to use a sine wave function in an isosurface to get the
actual shape. Here is a 3' by 16' panel.
#declare Freq=20;
isosurface {
function {
y-sin(x*Freq)/25
contained_by {
box {<-1.5,-1,-8>,<1.5,1,8>} // could change x and z (W and L)
max_gradient 2 // adjust
open // make surface only
pigment {rgb 1}
scale 1
I see Aaron Gillies has replied, too, about using HF. Which is certainly
another possibilty, although not as easy and convenient.
Mike Williams has a isosurface tutorial (much suggested reading) showing a
way to create a thickness, too, if that might matter. See last example at:
http://www.econym.demon.co.uk/isotut/substitute.htm
Bob H.
> #declare Freq=20;
> isosurface {
> function {
> y-sin(x*Freq)/25
> contained_by {
> pigment {rgb 1}
> scale 1
Cheers, I'll be sure to give you cred in my IRTC entry, but if I forget,
here it is.
Download 'platform.jpg' (44 KB)
"Bathurstfreak" <bat### [at] hotmail com> wrote in message
news:web.41d2a62a9b0fd5ad127a3fdf0@news.povray.org...
No need to do that. Was just a simple bit of help.
Your roof here looks much like the carport roof I built with the same kind
of corrugated metal that I included in a model of my home made in POV-Ray,
which is how I knew about the way to make it. Is 20' L by 16' W with five 4"
X 4" posts on one side and other, higher side, attached to the home.
About your rendered image... Will you be using light source fading? Right
now I can't tell much about the lighting, it has a high ambient appearance,
or perhaps a shadowless light source.
