POV-Ray : Newsgroups : povray.binaries.images : Fountains Server Time
24 Feb 2026 18:45:20 EST (-0500)
  Fountains (Message 1 to 8 of 8)
Subject: Fountains
Date: 18 Oct 2004 13:10:01
Message: <web.4173f87134580dfb5bf981ea0@news.povray.org>
I've been working on getting a good fountain effect for a while and this is
as far as I've gotten. I'm hoping someone can toss in a few comments to
help improve it since I keep thinking that it's good, but not great.
Right now the water is just textured with
        pigment { color rgbt <0.9, 0.95, 1.0, 0.9 > }
        finish { reflection {0.0, 0.7} }
Mike
Download 'example_scene.png' (358 KB)
Preview of image 'example_scene.png'
Subject: Re: Fountains
Date: 19 Oct 2004 00:26:37
Message: <4174977C.C2FE2DA7@gold.sdsmt.edu>
Is your fountain object csg?
I use the Liquid Spray include file by Chris Colefax.
http://www.geocities.com/SiliconValley/Lakes/1434/spray.html
Rune has one on his site that uses the newer features of POV (f/ex. the Trace
macro, media, etc.). http://www.runevision.com
ADB
>     texture {
> Mike
Date: 19 Oct 2004 11:28:14
Message: <4175328e$1@news.povray.org>
"Anthony D. Baye" <ant### [at] goldsdsmtedu> wrote in message
news:4174977C.C2FE2DA7@gold.sdsmt.edu...
Trace
> Regards,
> ADB
it looked to me like it was a simple geometric shape, but the actual
fountain effects were created by some fancy texture. i'd like to know how it
was made. it's interesting.
Date: 19 Oct 2004 13:49:14
Message: <4175539a@news.povray.org>
> Trace macro, media, etc.). http://www.runevision.com
> Regards,
> ADB
Anthony,
Thanks for the links to a few particle systems that do water-type effects.
See my other post on how this was created.
Mike
Date: 19 Oct 2004 14:04:41
Message: <41755737@news.povray.org>
> Trace
>> Regards,
>> ADB
> it was made. it's interesting.
Anthony and Ross,
This was created by a quick Perl script I wrote that was in essence a
particle system simulator that creates a blobbed collection of /a lot/ of
spheres in an include file. I wrote the script mostly for a mental
exercise, but then I started liking the result and got serious. The
rendering has a relatively uniform look because there's no 'jitter' in
system to preturb a uniform flight (that's next). Because it's a bunch of
blobbed spheres, it does give a good watery surface normal.
I did a separate rendering with fresnel reflection (and AA) and it gives an
entirely different result.
Mike
Download 'example_scene.png' (340 KB)
Date: 19 Oct 2004 14:39:18
Message: <41755ED0.10204@hotmail.com>
Hi Mike,
As it is the density seems to be rather uniform.
Conservation of matter would require that the number of particles is
proportional to the circumference at that level. If you take
gravity into account the lower levels will be even less populated
than the higher levels.
Date: 21 Oct 2004 12:51:23
Message: <4177e90b@news.povray.org>
andrel wrote:
> Hi Mike,
Andrel,
Yeah, that is a problem. I should be able to correct for it by tweaking the
blob threshold. Lemmie give it a go and see how it turns out.
Mike
Date: 23 Oct 2004 11:43:22
Message: <417a7c1a$1@news.povray.org>
Mike Kost nous apporta ses lumieres ainsi en ce 2004-10-21 12:51... :
>andrel wrote:
>>Hi Mike,
>Andrel,
>Mike
Modulate the strenght and the spacing of the elements. The threshold
affect the whole blob, strenght affect each element separately.
The number of element at a given radius should be constant and the
vertical spacing dependant on the vertical position.
