This is the best I could get.
Is there no other way than to take a picture with a digicam ?
This is my first picture with POV-Ray.
Download 'shelter.jpg' (157 KB)
Preview of image 'shelter.jpg'
Hans-Werner wrote:
> I?ve tried to generate a military looking texture.
> I?ve tried all patterns of POV-Ray, but it doesn?t helped.
Why don't you scale and move the texture itself until you get the desired
look?
Hope this helps.
Txemi Jendrix
www.txemijendrix.com
Well, I did something using the crackle pattern. I'm not sure if it's
any closer to what you are trying to achieve, but I thought I'd post it
anyway...
The texture part of the scene file goes like this :
#macro ColorSpan(col, Span) // Macro to clarify the color_map...
[MapInd rgb col]
#declare MapInd = MapInd+Span;
[MapInd rgb col]
#declare Military =
texture
pigment
crackle solid form <1,0,0>
// Liked this form more than the default, but it's
// really a matter of what you want to mimic...
color_map
#declare MapInd = 0;
ColorSpan(<0.2,0.3,0.3>,0.45)
ColorSpan(<0.2,0.8,0.1>,0.1)
ColorSpan(<0.7,0.2,0.1>,0.45)
warp{turbulence 0.4 octaves 2}
// Just to add some irregularities in the shapes
Hope this helps
Vincent
Download 'military.jpg' (14 KB)
Preview of image 'military.jpg'
The textures they use in armies are mostly done by hand IIRC. They are
supposed to break the form apart and prevent recognition by the (human) eye.
It might be hard to do a very good military texture, but who knows there is
someone around here who will crack the case of course....
> look?
I meant something like this. If you find it useful, I can post the code.
Bye
Txemi Jendrix
Download 'militarr.png' (81 KB)
Preview of image 'militarr.png'
Code posted in povray.text.scene-files
Bye
Txemi Jendrix
Subject: Re: Shelter with Military Texture
Date: 28 Sep 2004 18:35:23
Message: <4159e72b@news.povray.org>
Ooops... I just realised that form has no influence whatsoever on
crackle when solid is specified...
I really don't know what was the difference I saw when I wrote the
scene. Just my imagination !
One could play with metric instead in this case...
sorry again
Vincent
Take a look at this thread:
http://news.povray.org/povray.binaries.images/thread/%3C3d57ee8a@news.povray.org%3E/?ttop=186611&toff=2000
The texture there might fit your needs with little changes and diferent
colors.
Best regards.
