Jim Charter <jrc### [at] msn com> wrote:
> Very promising first post. Technically accomplished. For me the main
> stopping point is a relatively minor thing, the grass. What you have
> just doesn't correspond to anything familiar to me. The rest is quite
> believable.
Thanks you very much!
The following link shows grass, which is pretty close to the type of grass
that I meant. I hope, it begins looking more familiar? ;-)
http://www.kieserite.com/effects/bilder/Weide-Gras-1.jpg
>>believable.
okay but that reference doesn't really give a sense of the scale which
is the basic problem for me. Thing is, I can well imagine that
somewhere, somehow, there is some botanical form which corresponds to
your grass. But I have a difficult time placing it in a garden setting
like that. For instance the fat, spiky appearance sort of reminds me of
a dense type of flower you find on hardwood forest floors called dogwood
or trillium. Or I can think of different grasses that are fat and spiky
like that, especially in the US SE like Florida, but the scale would be
smaller by at least 1/2. At the scale you show I would expect the grass
to be thinner and a little 'softer" or bent over.
I really don't want to get anal about it. It is just the part of the
picture that stops me from projecting into the illusion. May not be a
problem for others. But one observation you might take away from the
conversation is to recognize that while your picture has an admirable
degree of complexity for a raytracing, there still are only a small set
of elements that comprise it. So the believability of each element
counts for a lot
> counts for a lot
I thought a bit about what you said and I think you are right. I will have
to play around with the grass. I will make it thinner.
I rendered a bigger picture with radiosity and AA. It took 1d14h34m22s!! The
grass is still unchanged. The shadow is brighter now and I think, it looks
much better. I'm looking forward to your comments!
frozen
Download 'chess.jpg' (115 KB)
Preview of image 'chess.jpg'
Very Nice Image.
As I see other people have mentioned the grass I thought I would too. It
may be be correct but at first glance it puts the viewer off of the image.
I've had the same thing when I've presented images including reflection. I
had a wooden table that reflected wallpaper, people around me said I was
nuts because tables dont do that. I got so mad I ended up buffing a table
and moving it over to the wall to prove my point. But in the end I realised
I may have been technically right but, the image didn't "look" right to the
observer.
"frozen" <fro### [at] thefrozen no-ip com> wrote in message
news:web.414dcefe90d95b228d45c69f0@news.povray.org...
> The
I like it better. Even so, I think the radiosity count could be higher, and
error_bound could go lower. But that's one of those times when you have to
begin to be realistic. I've played around with scenes involving grass with
a high radiosity count, and you quickly realize that it will never render in
your life-time. ;-)
I can't tell for sure, but did you put "ambient_light off" in your
global_settings block? Some of those stones in the shadowed area seem a
little bright. Also (I think I've made this mistake before), make sure that
your global_settings block is before your #include's, or they will still end
up with ambient light values, which you generally don't want in a radiosity
scene.
It's looking good though! Personally, I love outdoor scenes: grass, stones,
sky... :-D
Jeremy
www.beantoad.com
frozen wrote:
> This is a small "preview" I rendered last night. The picture still requires
> some work.
Very nice! I'm wondering how you got that pattern of stones on the wall.
It's not brick and it's not crackle, but it's actually a rather common
pattern around the city I'm in (San Diego).
Darren New <dne### [at] san rr com> wrote:
> > some work.
It's created from superellipsoids by the mur.inc file from Steven Pigeon.
You can get it from the following page:
"Jeremy M. Praay" <sla### [at] hotmail com> wrote:
> [...] I've played around with scenes involving grass with
> your life-time. ;-)
It renders for 1 to 2 days even just as it is right now... The wall is, what
renders slowest...
> scene.
Thank you for these ideas! Unfortunately I think, I will take the rendering
that now runs, as final, because it renders sooooo long and I don't like
playing around with parameters when I have to wait 2 days to check the
results..
> sky... :-D
Thank you very much! I personally like outdoor scenes too, but I notice more
and more, that these aren't easy..
frozen
The newest version with thinner grass.. I am away for a few days but I will
read and write here from to time. When I'm back, I will use another tree on
the right side and add a few butterflys and have a look at this chess
figure, which seems to be inside the board with one half... Comments
welcome!
frozen
Download 'chess.jpg' (111 KB)
> welcome!
> Regards,
> frozen
That grass looks very more believable to me.
vis-a-vis your superellipsoid slowness issue.
one possible solution might be found in the fact that
a) superellipsoids can be gotten with isosurfaces
here Mike Williams talks about it:
http://www.econym.demon.co.uk/isotut/builtin1.htm#super
and
b) isosurfaces can be redone as meshes courtesy of Kevin Looney
http://www.geocities.com/qsquared_1999/pubfiles/pubfiles.html
Mike Williams on that:
http://www.econym.demon.co.uk/isotut/approx.htm
