POV-Ray : Newsgroups : povray.binaries.images : a molecule Server Time
29 Dec 2025 15:35:19 EST (-0500)
  a molecule (Message 1 to 9 of 9)
Subject: a molecule
Date: 7 Sep 2004 09:05:01
Message: <web.413db0a8c89378cb6b3522e90@news.povray.org>
The name says everything.
P.S. The real name of it is :
2,2',2'',2''',2'''',2''''',2'''''',
2''''''',2'''''''',2''''''''',2'''''''''',
2'''''''''''-[2,8,14,20-Tetrapentylpentacyclo-
[19.3.1.13,7.19,13.115,19]octacosa-1(25)
,3,5,7(28),9,11,13(27),15,17,19(26),21,23-
dodecaene-4,5,6,10,11,12,16,17,18,22,23,24-
Have fun, Shu.
Download 'pyrc5ac.jpg' (155 KB)
Preview of image 'pyrc5ac.jpg'
Subject: Re: a molecule
Date: 7 Sep 2004 09:39:03
Message: <413db9f7@news.povray.org>
er...yeah... I think THAT name DOES say a fair bit!
Doesn't that have a catelogue number or something? LOL.
Fantastic image tho...
Andrew @ home.
Date: 7 Sep 2004 10:33:45
Message: <413dc6c9$1@news.povray.org>
	Prepared with povscript+ ?
	- NC
Date: 7 Sep 2004 11:45:01
Message: <web.413dd6b057995eb56b3522e90@news.povray.org>
Hi, no povscript has been used. I only took the pov-output from ORTEP3
and changed the scene. That's all.
There is also an animation with an flyby around the molecule, but only the
scene-file is available, the movie was too big to post :(( .
Shu
Date: 9 Sep 2004 10:30:00
Message: <web.4140680457995eb56b3522e90@news.povray.org>
and a side-view of it.
Shu
Download 'pyrc5ac_side.jpg' (211 KB)
Preview of image 'pyrc5ac_side.jpg'
Date: 9 Sep 2004 14:37:27
Message: <4140a2e7@news.povray.org>
If I'm not mistaken, those ellipsoids are a representation of the confidence
region for the position of the nuclei. Could you replace them with simple
spheres (proportional to Van der Waals radii, for example)? Or maybe make
all spheres and cylinders (bonds) the same size?
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 9 Sep 2004 15:21:01
Message: <4140ad1d$1@news.povray.org>
Never. The confidence region for the nuclei is spheric. The confidence
region for the electrons is much more complex. Have a look at the
Orbitron for renders of most common electron-clouds:
http://www.shef.ac.uk/chemistry/orbitron/
Date: 9 Sep 2004 15:42:20
Message: <4140b21b@news.povray.org>
>> confidence region for the position of the nuclei. Could you replace them
>> with simple
Erm... Those are not "confidence regions", they are orbitals, which are a
different thing. Well, they're a similar thing, but the whole beast (sum of
all orbitals) would be the "electron density", which does not have such a
funny shape. The electron density of the molecule would be much more
similar to a POV-Ray blob.
And I'm not really sure the confidence region for the nuclei should be
spheric, maybe you mean the nuclei themselves are spheric? That's not
necessarily true, by the way, there are oblate and prolate nuclei... I've
found those ellipsoids are called "thermal ellipsoids" and everything seems
to indicate that they're regions where there's a high probability of
finding a *nucleus*.
Date: 9 Sep 2004 18:00:00
Message: <web.4140d19057995eb56b3522e90@news.povray.org>
Ok, it would take me quite a long time to explain the basics of single
crystal x-ray diffraction, but i'll try to give a short overview.
X-Ray diffraction is a technique to obtain the structure of a molecule in a
single crystal and it's packing. Every atom in a molecule is swinging
because of it's own energy. The whole molecule is dithering a thousend
dithering and thermal movement of the atoms in the molecule is reduced and
then you can try to obtain it's real structure. Every molecule likes to
have a conformation in the lowes energy state, like we. We like to sit
instead of jumping around all the time. So lets come to the technique. You
irradiate a little crystal (best is a perfect grown crystal without any
disordering, wich means perfect packing and stacking of the molecules in
the crystal) with a x-ray and the ray is diffracted because it interacts
with the electrons of every atom in every molecule. But due to a perfect
packing of the molecules and interferrences during the diffraction you
obtain a special pattern of scattered or diffracted x-rays which can be
detected by a simple film (like a photograph) or much better with a
ccd-detector. Then You make a fourier synthesis to try to obtain the phase
information, because every ray has it's own phase but this information is
lost during the measurement. If the computer finds a solution for this
problem You are on a good way to find out the stucture of a molecule.
Because if the computer solved the phase problem, then You obtain a first
model of the molecule and then You refine Your model against the measured
dataset and if the abberation becomes lesser Your model is getting better
and better. Good abberations are around 5% or less. Well, i think it makes
no sense to continue but for interested people there is a good link :
http://shelx.uni-ac.gwdg.de/xtal/xtal.htm
And yes, the thermal ellipsoids can be replaced by simple spheres or sticks
or spheres representing the van der Waals radii.
So far, bye, Shu.
Download '1,4inin001.jpg' (53 KB)
Preview of image '1,4inin001.jpg'
