POV-Ray : Newsgroups : povray.binaries.images : my very first iso-surface (and second macro) :-) Server Time
17 Nov 2024 20:23:06 EST (-0500)
  my very first iso-surface (and second macro) :-) (Message 1 to 9 of 9)
Subject: my very first iso-surface (and second macro) :-)
Date: 4 Sep 2004 03:45:00
Message: <web.4139722b2521c5a8399d8d0@news.povray.org>
the thread is a single iso-surface, bold heads and nuts are CSG.
shown:
 M3 x 25
 M6 x 50
 M10 x 30
 M16 x 50
 M64 x 150
#macro thread_macro( thrOD, totalLen, solidLen, thrSpoed )
  // thrOD   : outer diameter, before "cutting" the thread.
  // totalLen: result: <0,0,0> to <0,0,-totalLen>
  // solidLen: <0,0,0> to <0,0,-solidLen> is not threaded.
  // thrSpoed: displacement per revolution (spoed) (=25.4/tpi)
  #declare thrAngle = 60;    // (degrees)
  #declare chamOut  =  0.05; // chamfer outside (part of threadDepts)
  #declare thrRad   = 0.5*thrOD;
  #declare thrs     = 1/thrSpoed;
  #declare thrDepts = 0.5*thrSpoed/tan(radians(thrAngle)*0.5);
  isosurface {
    function{ max(
      sqrt(pow(x,2)+pow(y,2))-thrRad + // cilinder
      max( min(thrDepts*max(chamOut,   // chamfered threads
      abs(mod(2+z*thrs*2+atan2(x,y)/pi,2)-1)), // threads
      max((z-solidLen)*0.25, 0)),      // = sollid part
      thrDepts+z-totalLen)             // = chamfered end
      ,2*thrOD-sqrt(pow(x,2)+pow(y,2)+
      pow(totalLen+thrOD*1.965-z,2)) )}// = dimple in end
    max_gradient 2.0
    accuracy thrOD/1000
    contained_by{box{<-thrRad,-thrRad,0>,<thrRad,thrRad,totalLen>}}
    scale <1,1,-1>
jaap.
Download 'parts3.png' (158 KB)
Preview of image 'parts3.png'
Subject: Re: my very first iso-surface (and second macro) :-)
Date: 4 Sep 2004 04:08:32
Message: <41397800$1@news.povray.org>
Wow! That looks wonderful. How long to parse & render?
=Bob=
Date: 4 Sep 2004 04:25:00
Message: <web.41397b70f757768da8399d8d0@news.povray.org>
Er.., just let me re-render it...
render time with pov 3.6: (-j +FN +a0.1)
Isosurface roots:           3554000
Peak memory used:            493921 bytes
Parse Time:    0 hours  0 minutes  1 seconds (1 seconds)
Render Time:   0 hours  6 minutes  7 seconds (367 seconds)
Total Time:    0 hours  6 minutes  8 seconds (368 seconds)
without the big M64 x 150 bold:
Isosurface roots:           1001127
Peak memory used:            485385 bytes
Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
Render Time:   0 hours  1 minutes 45 seconds (105 seconds)
Total Time:    0 hours  1 minutes 45 seconds (105 seconds)
jaap.
Date: 4 Sep 2004 04:28:30
Message: <41397cae@news.povray.org>
"Jaap" <jws### [at] yahoocom> wrote in message
news:web.41397b70f757768da8399d8d0@news.povray.org...
: "=Bob=" <robertUNDERSCOREdobbinsATmailDOTtdsDOTnet> wrote:
: > Wow! That looks wonderful. How long to parse & render?
: Er.., just let me re-render it...
: render time with pov 3.6: (-j +FN +a0.1)
: Isosurface roots:           3554000
: Peak memory used:            493921 bytes
: Parse Time:    0 hours  0 minutes  1 seconds (1 seconds)
: Render Time:   0 hours  6 minutes  7 seconds (367 seconds)
: Total Time:    0 hours  6 minutes  8 seconds (368 seconds)
: without the big M64 x 150 bold:
: Isosurface roots:           1001127
: Peak memory used:            485385 bytes
: Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
: Render Time:   0 hours  1 minutes 45 seconds (105 seconds)
: Total Time:    0 hours  1 minutes 45 seconds (105 seconds)
: jaap.
Thanks! I also took a minute and set up a scene with
your macro. Goes pretty fast! Looks great!
=Bob=
Date: 4 Sep 2004 08:07:50
Message: <kurtzlepirate-51CD78.14075004092004@news.povray.org>
In article <web.4139722b2521c5a8399d8d0@news.povray.org>,
> shown:
>  M3 x 25
>  M6 x 50
>  M10 x 30
>  M16 x 50
>  M64 x 150
>   isosurface {
>     function{ max(
>     max_gradient 2.0
>     accuracy thrOD/1000
>     scale <1,1,-1>
> #end
> jaap.
> [Image]
working on the same thing from long time... but never get the correct result
your isosurface is top !!!
just one thing : how to remove the upper cone ? (from cylinder to thread)
i try to set 'chamOut' from 0.05 to 0 but not works.
a+
louis
Date: 4 Sep 2004 15:50:00
Message: <web.413a1bb4f757768da8399d8d0@news.povray.org>
chamOut only makes the thread less sharp.
it's the "thrDepts+z-totalLen" bit you want to remove:
    function{ max(
      max((z-solidLen)*0.25, 0))      // = sollid part
you may also remove the dimpled end (sphere):
"2*thrOD-sqrt(pow(x,2)+pow(y,2)+pow(totalLen+thrOD*1.965-z,2))"
    function{
      max((z-solidLen)*0.25, 0))}     // = sollid part
and remove the solid part:
    function{
      thrDepts*max(chamOut,abs(mod(2+z*thrs*2+atan2(x,y)/pi,2)-1))}
i guess i should break it up in seperate functions before doing all
the min()/max() stuff.
replacing "thrDepts+z-totalLen"
with "thrRad+z-totalLen" will make a bold with a sharp point.
"atan2(x,y)/pi" is used to calculate how far we have completed a
revolution, witch is used to shift each thread exactly one thread
per revolution.
replacing "2+z*thrs*2+atan2(x,y)/pi" with
"10+z*thrs*2+2*atan2(x,y)/pi" should create a double thread.
the "10" is needed to keep things away from zero (the direction
of the thread will change if we cross sero with mod( ,2) )
jaap.
Date: 4 Sep 2004 16:00:00
Message: <web.413a1e4ff757768da8399d8d0@news.povray.org>
i just realized what you want, you may change the 0.25 to 10 to make the
cone from the solid half to the threaded half realy steep.
jaap.
Date: 4 Sep 2004 18:42:12
Message: <413a44c4@news.povray.org>
Nice! I'd love to see radiosity render of some of these once you get
some good textures together. :)
Arlo
Date: 5 Sep 2004 03:33:18
Message: <kurtzlepirate-115527.09331705092004@news.povray.org>
In article <web.413a1e4ff757768da8399d8d0@news.povray.org>,
> jaap.
  yes it is !!!
  very, very good job.
  thanks
