> Your comments are as welcome as always.
Fantastic as all the pictures of your project you posted. I'm really
impressed on your patience with this, you have been modelling on the
ship for quite some time now. And the level of detail - wow, I mean, you
simply care about everything :)
So how many lines of SDL is right in the whole ship by now?
Keep up the great work!
Florian
Minimum Requirement #10: The mouse is there to rest your hand upon when
you're not typing (WEB.DE help-wanted ad: Linux Guru)
[------------ http://www.torfbold.com - POV-Ray gallery ------------]
Subject: Re: U.S. Brig Nigara WIP -- Rope & Rigging
Date: 3 Sep 2004 16:06:59
Message: <4138cee3@news.povray.org>
web.41378497536dc0949a303f820@news.povray.org...
> I pretty much took the summer off from this project. However, I'm ready to
> get moving on it again. I have been working on a series of rigging macros
> textures. Your comments are as welcome as always.
> Tim
Hey you are digging deep in all microscopic details!!! great!
I think you can get spiral pattern a bit longer. Your ropes are hemp colored
and I don't know if hemp allows so tight strands.
Keep up the excellent work!!!
Marc
I altered the macro to count the spheres in the rigging assembly and came up
with 723. Some of them are out of the image boundaries.
Hope that helps.
"=Bob=" <robertUNDERSCOREdobbinsATmailDOTtdsDOTnet> wrote:
> "Tim McMurdo" <jod### [at] woh rr com> wrote in message
news:web.41379f144c54077e9a303f820@news.povray.org...
> : It is made up of scaled spheres with a spiral pattern applied. They are then
> : rotated and translated to place.
> About how many spheres to make the picture?
> =Bob=
So far...that is a tough one as the SDL is contained in many include files.
I looked through 2 of the largest and came up with about 25,000 lines.
Thanks for your positive comments.
> Florian
Thank you for your comments Marc. I too have concerns with the pitch of the
spiral and will continue to tinker with it.
> > Tim
> Marc
news:web.4138d3654c54077e9a303f820@news.povray.org...
: I altered the macro to count the spheres in the rigging assembly and came up
: with 723. Some of them are out of the image boundaries.
: Hope that helps.
Thanks, just curious. That seems efficient.
=Bob=
In case I forgot to thank some body. I do appreciate all of your comments.
Your kindness and excellent criticisms help motivate me to keep this
project going.
Attached is an image that shows the rigging configurations that are built
into the macro so far. As i progress further on the ships rigging, I
anticipate that there will be many more.
The core of the macro is a heavily modified Link.inc file originally created
by Chris colefax.
I can clean up the code and make it available if anybody is interested.
Thanks,
Tim
Download 'riggingtest-3.jpg' (124 KB)
Preview of image 'riggingtest-3.jpg'
> get moving on it again. I have been working on a series of rigging macros &
> Tim
Is there a particular reason for having the running lines through the blocks
left-hand laid and the straps on the blocks right-hand laid? Also, I find
it odd that the running rigging is integral with the straps rather than
being seized.
Just nit picking :)
Btw, it looks like you've got the catenary built into the macro - if so,
nice work!
Abe
> being seized.
Hmmm... good comments. The 2 errors come from the fact that I am not a real
sailor (I was on a submarine inthe Navy).
1. I can correct how the ropes are laid. Which is correct? Right hand or
left?
2. If I understand correctly, the strap running around each block should
have a loop in it and the running rigging should then go through & then
loop back on its self.
3. THe cantenary is there and is part of the original macro by Chris
Colefax.
Thanks for helping make it accurate.
> Just nit picking :)
> nice work!
> Abe
> left?
I'd guess right, although I'm no nautical historian. Something google
came up with:
http://home.att.net/~ShipModelFAQ/ResearchNotes/smf-RN-Shrouds.html
(though maybe not directly applicable to the question at hand)
Sounds right. I took a peak at Ashley's book and it shows rigging a
block something like the attached illustration.
Abe
Download 'block.jpg' (12 KB)
Preview of image 'block.jpg'
