has anybody got any decent isosurface brick models ie a box with roughness
from 3d noise/ pigment patterns. I have been trying to model on but as I'm
not very good with isosurfaces am having difficulties
Thanks.
Hi!
Try this one by Christoph Hormann (bottom of the page):
http://www-public.tu-bs.de:8080/~y0013390/pov/wtunnel.html
BTW, p.b.images is for posting images. Normal questions like yours
should go to either povray.general, povray.newusers or
povray.advanced-users.
HTH,
Florian
> Thanks.
The brick wall in the Innocent Shadow image is decent
as long as you don't need a closeup (code available at
the IRTC website).
The wall has bricks vertically lined up with each other
(often found in very old brick walls) but you could fix
that with a small change.
-Mark Slone
> Thanks.
Hi Vladimir,
Here is a very simple (and not too good looking) example I recently used:
#declare fnbumps = function{pigment{granite}}
#declare fntile = function{x}
#declare abrick = object
isosurface
function{fntile(x,y,z) + fnbumps(x,y,z).x * 0.112}
max_gradient 0.719
threshold 1
contained_by
box {-2,2}
rotate y*-90
scale <0.35,0.35,0.01955>
#declare wallbrick = object
abrick
material
texture
T_Stone2
finish
diffuse 0.75
ambient 0.75
scale <0.75,0.35,4>
rotate x*90
#declare wall = union
#declare xloc = -0.23;
#declare yloc = yloc + (1 * yfac) - 0.75;
#declare xfac = 1.075;
#declare zfac = 0.515;
#declare xcount = 9;
#while (xcount > 0)
#declare zloc = -0.7;
#declare zcount = 9;
#while (zcount > 0)
object
wallbrick
translate <xloc,yloc,zloc>
#declare zloc = zloc + zfac;
#declare zcount = zcount - 1;
#declare xloc = xloc - xfac;
#declare xcount = xcount - 1;
difference
object
wall
union
box {
<-1, -1, -1>, <1, 1, 1>
material {
texture
T_Stone2
scale <1.203208, 0.270298, 1.833007>
translate <-2.401552, 9.975676, 0.716774>
box {
material {
texture
T_Stone2
scale <1.794289, 0.270298, 1.256064>
translate <-6.768104, 9.975676, 1.286108>
}//Box
}//Union
}//Difference
Stefan Viljoen
Software Support Technician
Polar Design Solutions
Vladimir,
Pls have a look at my post on June 20th in this group. If this is what you
are looking
for, I may give you more info.
Rgds,
Groucho
"Vladimir" <nomail@nomail> wrote in message
news:web.411e293046c8aea5472e332c0@news.povray.org...
> Thanks.
I am posting this before looking at the links so If I say something stupid
please forgive me. I will look at them after posting this but My family is
telling me to get of the internet so they can use the phone. Firstly thanks
for the replies. from what Ive seen my questions have been answered. I
realise I have posted on the wrong board. I misread the title when I was
posting. I will post another reply When I have had chance to read the
links.
Thanks
Peter
I have finally checked out the links.
The Brick posted by stefan is very good but when I experimented I found it
only textured on one side. I think this is because the bricks were based
around the function x and I will do some more experimenting trying out
functions to produce boxes.
Groucho- your pictures are great. I would be very interested in seing the
source code for the bricks.
The bricks I will be using in my final image will be whitewashed and
therefore I am trying to create a brick that looks good with minimal
texturing.
Thanks
Peter
Here it goes:
#declare rr = seed(1234);
#macro T_Wall()
pigment {rgb (0.8+0.15*rand(rr))*<0.3+0.02*rand(rr),0.3,0.3>}
normal {
granite
scale 0.01
finish {diffuse 1.8}
#macro BlockWall(l,h,w)
#declare r=0.02;
isosurface {
function {
f_rounded_box(x,y,z,r,l/2,h/2,w/2)+0.01*f_noise3d(10*x,10*y,10*z)
contained_by {box {<-l/2,-h/2,-w/2> <l/2,h/2,w/2>}}
translate <l/2,h/2,w/2>
texture {T_Wall()}
.Groucho.
news:web.412235209f026eba14f564e0@news.povray.org...
> texturing.
> Thanks
> Peter
Thanks ,
Peter
