POV-Ray : Newsgroups : povray.binaries.images : HELP !!!! (Wings3D) Server Time
15 Apr 2026 04:15:04 EDT (-0400)
  HELP !!!! (Wings3D) (Message 11 to 12 of 12)
Subject: Re: HELP !!!! (Wings3D)
Date: 9 Aug 2004 16:23:23
Message: <4117dd3b$1@news.povray.org>
Hugo Asm wrote:
> Now that I've taken a closer look at the image you attached, I see the
> problem is not really the "weld" feature, but the way you're building the
> mesh. You seem to be making a "one side" mesh. In other words, one that
> doesn't have a solid "inside". It's an "open mesh". Wings3D do not support
> open meshes, so all you need to do, is to make a defined interior and
> everything will work fine.
> Regards,
> Hugo
This is ther result of the "Extract Region" command or possibly he has
managed to import this geometry.
Date: 10 Aug 2004 09:40:01
Message: <web.4118cfaf5a7cc5296a4597b00@news.povray.org>
Thank you all for replys.
that was my first day in wings, I've already tried a few things like:
- trying to connect the vertices. (don't work. probably because they are on
different faces)
- [flatten] the vertices and [weld]. (the vertices are placed in the exact
same location, but when I try to weld the message "Found no faces to weld"
came up, as I've posted before)
I guess wings doesn't weld vertices of different faces.
PS: I hanen't got the time to post on wings forum, I'll try later.
Thanks again to all
_______________
Wagner - Brasil
