The attached ZIP file contains several files:
- A.pov = the POV-Ray source triggering the problem
- artifacts-ParmaPetit.png = result from A.pov
- artifacts-EngraversOldStyle.png = result with another font
- ParmaPetit-Italic.ttf = TTF file used to render the first pic
You can see the artifacts on the bottom-left part of the character: noise
below the baseline for one render, and jagged edges on the A's slope for
both.
The artifacts are much stronger with Engraver's Old Style Italic (from
Bitstream), but since it's a commercial font I can't attach it here. If you
have it you can give it a try.
The free font can be downloaded from
http://www.dafont.com/dl.php?os=win&fichier=parmapetit (gives a zip file
with several versions of the font -- no README so I took the liberty to put
a single file from the package in my ZIP archive)
Does the problem lies with the font files, or with POV-Ray? Both are
rendered ok by Windows' display engine.
Also, do I need to post an advisory on povray.bugreports, linking to the
present post?
That's all... If you need more info I'll be glad to help.
Config:
POV-Ray 3.6 on Windows NT4
Rendered at 640x480 with no AA
Here is the POV source (also found in the ZIP file):
#include "textures.inc"
background
color White
text
ttf "ParmaPetit-Italic.ttf"
"A"
.1, 0
texture { pigment { color Red } }
translate <-.3, -.8, 0>
//rotate -30 * y
light_source
<-10, 0, -10>
color White
camera
location <0, -.5, -.8>
look_at <0, -.5, 0>
Download 'textartifacts.zip' (49 KB)
ElProfesor wrote:
> Hi,
> both.
Hi !
The problem is the font and POV-Ray
An example with the font corrected (only the A):
Download 'a.png' (5 KB)
Preview of image 'a.png'
Thanks for the answer!
If I get it correctly, you mean that:
- the font is somehow invalid (eg. does not conform to some specs)
- AND that POV-Ray should handle it anyway?
Is that right? Sounds strange...
For the sake of curiosity, how did you manage to get the corrected picture?
Brought modifications to the font file?
Not a big bug anyway. It was not so easy to find a free 'corrupted' (?)
font. I wondered if it was triggered by the strong italics angle -- may be
a totally wrong explanation though.
> Hi !
