POV-Ray : Newsgroups : povray.binaries.images : Re: Full CRASH!!! BUG!!! Server Time
13 Nov 2024 17:48:22 EST (-0500)
  Re: Full CRASH!!! BUG!!! (Message 1 to 1 of 1)
Subject: Re: Full CRASH!!! BUG!!!
Date: 6 Jun 2004 23:30:00
Message: <web.40c3df23bbaa0a8127ef152a0@news.povray.org>
Alain <aze### [at] qwertygov> wrote:
> The problem seems to be the nested normals. Your hexagon normal pattern
> contain 2 other normal patterns.
> Alain
According to the docs, using a normal list with a block pattern
is a-ok, see sections (6.7.2.2) and (6.7.11.19).  According to
the latter section, "Three separate colors _should_ be specified"
with hexagon (not 'must', my emphasis).  Specifying two colors
works fine when using hexagon with pigments... but trying to
render the scene from the original post with only two normals
specified gives me a crash (I am using windows version 3.5).
Adding a third normal to the list fixes the crash, viz:
plane
    y, 0
    texture
        pigment{ color rgbf <0.2, 0.2, 0.2, 0.9> }
        finish{ reflection 0.3 diffuse 0.2 specular 0.2}
        normal{ cells scale 0.5 }
        normal{
            hexagon
            normal{ agate 3 scale 0.7 }
            normal{ cells 3 scale 0.2 }
            normal{ bumps scale .2 } // 1 line added
works fine for me.
Perhaps any further discussion should be moved to a different
list?
Yours,
--Brian
