Using the two pass and dummy textures technique as explain Jaime Vives
Piqueres in his homepage, with Kari Kivisalo ideas too, I rendered the
following stills.
In the first I rendered with dummy textures at low resolution and a gradient
texture sphere as background and save radiosity data.
Next using the saved data I made a render without the spere and with a
texture.
Finally in the third I added a plane, it looks fine, some black stripes are
due to a low parameters in radiosity settings (my computer is a little
slow).
Using the plane at first with radiosity I never can obtain this global
illumination, so I think that in some cases could be useful if we can
specify for any object in the scene an radiosity environment, I don`t know
if it is compatible with the radiosity algorithm.
http://www25.brinkster.com/ca0s/ufowaiter/cubos3textradiosave.jpg
http://www25.brinkster.com/ca0s/ufowaiter/cubos3textradio.jpg
http://www25.brinkster.com/ca0s/ufowaiter/cubos3textradioplano.jpg
Comments and ideas are welcome.
Horacio Fagundez hfa### [at] adinetcomuy
HTTP1.1 STATUS 403 Remote Access to this object forbidden This file cannot
be directly accessed from a remote site, but must be linked through the
Brinkster Member's site.
Give us a solution. or a pic.
Bruno Gimeno
"Bruno Gimeno" <gam### [at] mixmailcom> wrote in message
news:web.3dfb057220145968c1321fe90@news.povray.org...
They were there last night, and they're there this morning too.
Try again
~Steve~
> Bruno Gimeno
>Bruno Gimeno
I get the same error.
>>Bruno Gimeno
I get to them no problem
If those pictures are referenced to from another website and the server
where they reside can detect this, you won't see them. Probably copy-pasting
the image urls into fresh browser window will help.
"Maleko" <mar### [at] ptdnet> wrote in message news:3dfb6577@news.povray.org...
cannot
> >>Bruno Gimeno
Here is the correct address excuse me.
http://www31.brinkster.com/ufowaiter/cubospov/default.htm
