POV-Ray : Newsgroups : povray.binaries.images : crash on modified sample file Server Time
13 Jan 2026 23:55:10 EST (-0500)
  crash on modified sample file (Message 1 to 9 of 9)
Subject: crash on modified sample file
Date: 12 Dec 2001 17:04:49
Message: <spkf1ugdk9ffq6q3shrfs0f1sqrgf8v9se@4ax.com>
I have placed 1000 wooden spheres inside this woodbox but it was too much :-)
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Download 'crashbox.jpg' (127 KB)
Preview of image 'crashbox.jpg'
Subject: Re: crash on modified sample file
Date: 12 Dec 2001 17:11:10
Message: <3c17d5fe@news.povray.org>
No wonder 8-|
What in the world were you doing with 1000 wooden spheres? <g>
Date: 12 Dec 2001 17:18:06
Message: <tqlf1uotj3gn59g3pnadei41fpjsvqsifh@4ax.com>
abacus with hardware memory ?
ABX
Date: 12 Dec 2001 17:21:00
Message: <3c17d84c@news.povray.org>
where lies the secret of the non-intersectional balls? in the
trace()-function? is there a way for this in v3.1?
Date: 12 Dec 2001 17:40:16
Message: <dpmf1uoe65u11c5th7om3oipcns0iverkt@4ax.com>
On Wed, 12 Dec 2001 23:22:43 +0100, marabou <not### [at] availableyet> wrote:
> trace()-function?
partially yes
if you don't know what 'trace' does check description under
http://www.povray.org/working-docs/id000136.html#6_1_4_6
yes but you have to know some basic algorithms connected with finding ray's
intersection with objects (i.e. sphere)
iirc you can find some description of it within 'raytracer' part of new
documentation at http://www.povray.org/working-docs/id000107.html#4_2
ABX
Date: 13 Dec 2001 01:19:02
Message: <3C18493A.9846C93C@faricy.net>
How 'bout an abacus that does symbolic integration?
Date: 13 Dec 2001 01:25:54
Message: <cdig1uodkgvsa5uleig5l9u52251vur5up@4ax.com>
On Thu, 13 Dec 2001 00:22:50 -0600, David Fontaine <dav### [at] faricynet> wrote:
As you see from my picture such operation provides to des-integration.
ABX
Date: 13 Dec 2001 13:03:49
Message: <5NvJ8CAtFGG8Ew+1@econym.demon.co.uk>
In 3.1 you just keep an array of the positions of the balls (and an
array of their sizes if different). Each time you try to add a sphere at
a random position, you check to ensure that vlength(newposition-
oldposition) is less than the sum of the two radii for each of the
existing spheres.
Mike Williams
Gentleman of Leisure
Date: 13 Dec 2001 19:34:38
Message: <3C194A04.801F9846@faricy.net>
Hehe, whooo, man... I went into shock that joke was so bad.  ;)
