POV-Ray : Newsgroups : povray.binaries.images : Tunnel #3 (79k before post) Server Time
3 Mar 2026 16:01:13 EST (-0500)
  Tunnel #3 (79k before post) (Message 1 to 10 of 11)
Subject: Tunnel #3 (79k before post)
Date: 16 May 2001 00:10:43
Message: <3b01fdc3@news.povray.org>
This is starting to become random city! I modeled a 30 polygon blade of
grass in Rhino, then exported it as a pov ini file. The grass in the picture
has been randomly scaled, randomly translated, randomly rotated and randomly
coloured.
Download 'Tunnel 2.JPG' (79 KB)
Preview of image 'Tunnel 2.JPG'
Subject: Re: Tunnel #3 (79k before post)
Date: 16 May 2001 17:36:13
Message: <MPG.156d113146427e2498977d@NEWS.POVRAY.ORG>
In article <3b01fdc3@news.povray.org>, Thomas Lake says...
> coloured.
If I may write down just a bit of criticism: why do you show so much of
the dark (and probably less interesting) part of the tunnel? Isn't the
streaking ligt the effect you want to show? I like the whole idea very
much :))
Regards,  Sander
Date: 16 May 2001 17:39:24
Message: <3b02f38c$1@news.povray.org>
I have thought of changing the aspect ratio so there would be less dark, and
the resolution of the image would acsentuate the tunnel effect. However it
is preciesly the fact that you can see the dark parts of the tunnel that
make the light stream as effective as it is.
> much :))
Thanks!: )
> Regards,  Sander
Date: 17 May 2001 02:28:36
Message: <MPG.156d8df8acce9a698977f@NEWS.POVRAY.ORG>
In article <3b02f38c$1@news.povray.org>, Thomas Lake says...
You are probably right there. It has atmosphere!
Regards,  Sander
Date: 17 May 2001 02:50:30
Message: <3b0374b6@news.povray.org>
Nice going. I'd put cracks on the edges of those slabs.
Nekar
#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);blob{#while((K-N).
x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(vlength(N-K)<vlength(
X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N,1,1 scale.02}sphere{
<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1 scale.01 }#end
pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}// Nekar Xenos
"Thomas Lake" <tla### [at] homecom> wrote in message news:3b01fdc3@news.povray.org...
> coloured.
Date: 17 May 2001 03:18:00
Message: <3B037B4C.689B6F98@gmx.de>
> coloured.
That grass looks very neat, i just wonder about the white gap between
foreground and mountains.
Date: 17 May 2001 14:17:50
Message: <slrn9g7ji1.j5f.steve@zero-pps.localdomain>
>coloured.
The walls look very dry, and the angle between grass blades in the same clump
looks uniform (maybe it isn't but that's the way it looks).
It's comming along nicely.
  1:57pm  up 104 days, 14:45,  2 users,  load average: 1.00, 1.00, 1.00
Date: 17 May 2001 14:17:51
Message: <slrn9g7jmp.j5f.steve@zero-pps.localdomain>
PS: and how about a file name that isn't lightly to clash with other
pos stuff that I've saved over the years?
Date: 17 May 2001 20:01:24
Message: <3b046654@news.povray.org>
That's true I don't usually give much thought to my file names. I hope you
don't count my image amongest the "pos" stuff.
Date: 17 May 2001 20:03:30
Message: <3b0466d2$1@news.povray.org>
Yeah I've noticed that too. The problem is that I'm using a lightsource with
rgb 5 translated 93,000,000 units away. So anything I place out there just
gets washed out.
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
