POV-Ray : Newsgroups : povray.binaries.images : Bozo blob (23KB) Server Time
5 Mar 2026 00:00:00 EST (-0500)
  Bozo blob (23KB) (Message 1 to 10 of 15)
Subject: Bozo blob (23KB)
Date: 8 Oct 2000 19:32:34
Message: <39E103B3.7EE3B0A9@hotmail.com>
I have to admit that one week ago I played
around with MegaPOV's eval_pattern to see
if I could make a 3D-pattern "visible" with
a blob.
The image enclosed is one of the results
from experimenting with the bozo pattern.
The code I used to make it did not work
quite as I expected, so I didn't like the
result back then.
But I have had a second look at the image,
and now I think I like it.
Btw.:
Is there a way in MegaPOV to have a
"pattern surface" ? (I.e. make the surface
of a 3D-shape appear where a pattern have
a certain threshold value.)
Tor Olav
mailto:tor### [at] hotmailcom
Download 'blobpattern02_.jpg' (24 KB)
Preview of image 'blobpattern02_.jpg'
Subject: Re: Bozo blob (23KB)
Date: 8 Oct 2000 20:08:07
Message: <39e10c67$1@news.povray.org>
That's really lava-lampesque.
You can use a pigment function to define an isosurface.
#define pigfunc = funcion{pigment{bozo color_map{[0 rgb 1][1 rgb 0]}};
isosurface{
    function{pigfunc(x*xfactor,y*yfactor,z*zfactor)*Some_factor}
http://www.capital.net/~hhawkins
Date: 8 Oct 2000 20:08:36
Message: <39e10c84$1@news.povray.org>
    Um... Isosurface? #declare the pattern as a function and use it that
way? Maybe I don't understand the question...
Date: 8 Oct 2000 20:10:49
Message: <39e10d09$1@news.povray.org>
I mean #declare of coarse!
(that's a c/c++ism)
Date: 8 Oct 2000 20:35:35
Message: <slrn8u24ap.58r.steve@zero-pps.localdomain>
Fase clock animate dude.
  1:24am  up 10 days,  3:44,  2 users,  load average: 1.02, 1.01, 1.00
Date: 8 Oct 2000 20:39:06
Message: <chrishuff-567263.19413608102000@news.povray.org>
In article <39E103B3.7EE3B0A9@hotmail.com>, Tor Olav Kristensen
The isosurface is perfect for this...
#declare Func =
function {
    pigment {bozo color_map {[0 rgb 0][1 rgb 1]}}
isosurface {
    function {Func(x, y, z)}
    threshold 0.5
    contained_by {
        box {<-1,-1,-1>, < 1, 1, 1>}
Christopher James Huff
Subject: Re: Bozo blob -> isosurface bozo (47KB)
Date: 8 Oct 2000 21:48:46
Message: <39E123D3.1C989ED3@hotmail.com>
Thank you all for fast replies.
You've helped me to do what I wanted.
But I don't understand why one has to involve
pigments to determine a surface.
Why can I not define the function like this ?
function {
  eval_pattern(bozo scale <1, 1, 1>/4, x + y + z)
Please explain.
Enclosed are an image I just made.
I love isosurfaces !
Tor Olav
Download 'bozo.jpg' (48 KB)
Preview of image 'bozo.jpg'
Date: 9 Oct 2000 07:29:47
Message: <chrishuff-DA49DA.06321909102000@news.povray.org>
In article <39E123D3.1C989ED3@hotmail.com>, Tor Olav Kristensen
> function {
> Please explain.
Because nobody has added the eval_pattern() function to isosurface
functions yet. Oh, and it wouldn't be "x + y + z", it looks like you
meant "x, y, z". :-)
The eval_pattern() function would probably be a little bit faster than a
pigment function, and certainly easier to use, but I don't plan on
trying to add it to isosurfaces until a MegaPOV based on POV 3.5 is
released. Adding an isosurface function is a bit more complex than
ordinary functions, and I want to wait until the isosurface code is
cleaned up and organized better.
Date: 9 Oct 2000 16:56:35
Message: <39E23003.454939EC@online.no>
> > function {
> > Please explain.
Yes you're right. I think I misunderstood that part.
Ahh... I thought that any float expression would do. -Sorry.
Has the added complexity anything to do with the derivatives
of these iso-functions ?
Tor Olav
Date: 9 Oct 2000 17:05:12
Message: <39E231FE.909F7B5B@online.no>
What do you mean ?
That I should make an animation of it ?
Have anyone done any animations with iso-
surfaces that changes their shapes according to
a 3D-pattern that has it's different parameters
changed slowly ?
I'll have to try that some day.
Tor Olav
