POV-Ray : Newsgroups : povray.binaries.images : Re: Ice Planet (final?) [111k] Server Time
28 Dec 2025 21:07:09 EST (-0500)
  Re: Ice Planet (final?) [111k] (Message 1 to 6 of 6)
Subject: Re: Ice Planet (final?) [111k]
Date: 22 Sep 2000 22:33:01
Message: <slrn8so5h6.64f.steve@zero-pps.localdomain>
On Fri, 22 Sep 2000 20:45:05 -0500, David Fontaine wrote:
>I'm still not happy with it, but it's trying my patience. I'll come back
>to it I guess.
It's really looking good, there's always more that can be done to an image,
so sometimes the trick is knowing when to stop.
>It looks washed out. I think the snow needs higher specular and the
>rockface lower...
Try lowering the gamma just a touch in the global settings, it might
save you a lot of work.
>The tracks are kinda cheap but it's the best I can do.
The set of tracks closest to the camera could do with being a bit more uneven
but they look good as they are, especially those converging tracks further
away.
>I'm probably overly self-critical though. Does it look like it has
>progressed?
Yes certainly.
  3:16am  up 32 days,  7:30,  1 user,  load average: 1.99, 1.53, 1.51
Date: 22 Sep 2000 22:45:33
Message: <39CC17DB.49E160A6@faricy.net>
Thanks! Hmm... I think you're right.
Okay, thanks! Which one though (assumed, display...), I really don't know much of
how POV handles gamma.
> away.
Someone else just said the same thing. :) It's a bump_map (duh) so I can easily
distort it in the graphics editor (duh).
> >progressed?
> Yes certainly.
After a bunch of overnight renders I'm more frustrated that it's not looking like
my mental picture rather than viewing it objectively ;-/
Date: 22 Sep 2000 22:49:11
Message: <39CC18B6.4DA8CEA8@faricy.net>
BTW the black level has a real effect on this one. If you have lots of glare
try blocking the light and see if it looks any better.
Date: 23 Sep 2000 00:16:36
Message: <39cc2ea4@news.povray.org>
news:39CC0B21.E4E45459@faricy.net...
| rockface lower...
| progressed?
Self criticism can be either a good or bad thing.
Assuming this were an adjusted photo or as seen through a helmet then it
looks fine to me.
Except for one minor detail.  The lightness of the domes shadowed areas is
brighter than that of the snow.  Common sense says the snow should be the
brighter of the two things even though the dome gets more ambience from the
surroundings, since it is a shade darker to begin with.
Date: 23 Sep 2000 01:52:28
Message: <39CC43A8.6932ABD6@faricy.net>
I noticed that right off! :-/
Actually, the left side of the domes there isn't actually in shadow, it's a
very shallow angle, but you're right, the shadow area is still lighter. I was
using brilliance to lighten the snow but I should use less of it and more of
ambient.
Date: 23 Sep 2000 11:33:53
Message: <39cccd61@news.povray.org>
I like the way this is working out.  The vehicle in the foreground looks
best... not sure why, perhaps the lighting.  The tracks, despite what you
said, actually look pretty good to me.  Something about the rock texture
bothers me, but I can't put my finger on it.  Nice work Dave!
- Doug Eichenberg
  http://www.getinfo.net/douge
  dou### [at] nlsnet
